pica p 40 1/6 scale
WI
pica p 40 1/6 scale
any body else building one of these. i have the wing joined and am about to start sheeting. any helpful hints are welcome. also has any one flown it and what did you use for power?
pica p 40 1/6 scale
Hi rumble2, I have looked at some Pica kits before and they appear to be very nice, I would like to build the P-40 one day (1/5), so how has the kit been so far as putting it togather? Bud..
WI
pica p 40
thanks for the reply bud. i have limited experience with kits having only finished two a fw 190 top flite and sea fury direct connection kit. the pica is lazer cut like the D.C. kit was and every thing fits very good not much sanding. the T.F. kit was a lot more work. the wood quality on the pica is good but the instructions don't compare to the T.F. or D.C. kits. if the pica had instructions like the T.F. it would be a great match. if i had to rate these 3 kits {3= T.F. 2= pica 1= D.C. that is if the pica flys great the T.F. and D.C. both are very easy flyers. { at least it was until i put it in } FW 190 rest in peace my fault!
