Which gas engine size for WM G.S. P-51? (Zenoah or Fuji?)
I would like a gas engine that does NOT use nicads so I am considering the Zenoah's or Fuji's on the World Model 80" Mustang. But I do not know what HP the plane needs. WM says flying weight is 13.8 lbs.
Here are the stats:
G-26 ..?.......@ 3.3 lbs
G-38 2.5 hp @ 4.19 lbs
G-45 3.3 hp @ 4.31 lbs
Fuji BT-32A 2.2 hp @ 3.74 lbs
Fuji 50SA 5.2 hp @ 5.28 lbs
Would I be able to install smoke on all of them? (yes, I know smoke on a warbird is unconventional )
Do you think the plane would be underpowered with the Fuji 2.2 hp one?
Help me out gas guys Thanks!
Here are the stats:
