Hanger9 F4U Corsair 60 w/retracts
#51
RE: Hanger9 F4U Corsair 60 w/retracts
Yea mate you wont regret the extra channels espeically if u start on the bigger birds and run a channel for each aileron ect. Goodluck and let us no how it goes as i am also deciding weather or not to get this bird or the H9 Hellcat,i prefer the corsair but the gear probs scare me.
Goodluck!
Goodluck!
#53
MN
ORIGINAL: Jarrah
Goodluck!
Goodluck!
#54
Ohhh thats interesting, well in this case ill prolly go for the corsair, now i just have to check that there arnt any other H9 corsairs at my field. Either way these are both great planes and if the gear probs have/can be fixed then i think i shall go out and order one for my birthday bahaha.
Im only looking for "scale" power here no need for wild aerobatics ect, should i couple with the saito 100 or 91?? As far as im concerned i dont want/need a motor for this plane which has so much power that i drive round at 1/2 or less throttle all the time.
Cheers
Cheers
#56
MN
All three of those engines will fly the plane great. I myself would opt for the 100 for emercency power considerations and since it will turn a bigger, more scale prop. If you are going to go with anything much bigger than the 100 you might want to reinforce the firewall. Some guys have put O.S. 120's on their's and ripped the firwalls right out. I have a Supertigre G-90 in mine and there is no hint of the firewall giving out. I test for firewall weakness before every flying session and after every rough landing or nose-over.
#57
ok this is interesting, ill be keeping it under 1ci i think as seeing as i already have an 82 i might go for the 91, but i didnt think about the larger prop on the 100. could anyone give me idea 3 blade prop sizes for the 91 and 100 cheers. i would be erring towards max dia and minimum pitch
thanks for all the help.!!
#58
My Feedback: (90)
Mine was Saito .91 powered, swinging a 3 blade Master Airscrew 14 x 7. That same engine/ prop combo was transferred to my H9 Hellcat. Both planes flew GREAT with that combo, the Saito .91 has all the power (and more) that you will need for scale flight. Takeoffs are quick, climbout very good, and enough power to execute those large, scale loops with ease.
I also love the Saito .82, BUT a Master Airscrew 3 blade 13 x 8 is probably as big of a prop that it will handle. Due the the large cowl diameter of the H9 Corsair and hellcat, I like being able to use the 14" props.
#59
Yes i totally agree about the larger diam props. Well I think ill have to go down to my LHS tmoz and put the Corsair and Saito 91 on order
CorsiarJock. How do the two planes fly in comparison and bad habits that would deter you from either?? Because i love both these models.
thanks
thanks
