If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 114 of 115 FirstFirst ... 1464104112113114115 LastLast
Results 2,826 to 2,850 of 2857
  1. #2826
    Join Date
    Apr 2007
    Oak Lawn, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: New Hangar 9 1.50 P-51 Build
    Sorry I do not understand are you saying to balence it at 5 5/8 inches from leading edge?
  2. #2827
    Join Date
    Apr 2007
    Hamilton, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    One inch (1") back from the leading edge of the wing at the wing tips
    Graeme
  3. #2828
    Join Date
    Nov 2004
    Fort Wayne, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mine will snap on the downside of a split S if I get too heavy handed on the elevator. Bigger airplane means bigger everything. Higher loops and split S's so that you have time on the downside to be gentle. At least that's my experience with her.
    Dave
  4. #2829
    Join Date
    Apr 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    At the C/G setting that i have mine set at you would be hard pressed to get mine to snap .
    Used to snap badly until i moved the balance forward , used to think that the beast had a bad fault ,
    but really good now unless i get really slow, and i mean slow with flaps downand a 90 Deg cross wind .
    Sharp pull up to avoid hitting the ground is clean with no hint of a snap at high speed .
    Graeme
  5. #2830
    Join Date
    Nov 2004
    Fort Wayne, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Interesting Graeme! Will take a look at the possibility of moving mine forward. A heavier gasser hanging up there vs the 220 will help in that area.
    Dave
  6. #2831
    Join Date
    Apr 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I kinda think that theDLE 30 will, be lighter than the 220 you have in it now , that is how i found the c/g was out on mine .
    Anyway you will be impressed just how much better it flies .
    Graeme
  7. #2832
    Join Date
    Nov 2004
    Fort Wayne, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Graeme,
    I just did some quick checking and I think you are correct. The Saito 220 is 40.5 ounces with the muffler. The DLE30 is 38.3 ounces with the muffler and ignition. The saito is 3.5hp and the DLE30 is 3.7hp. And a whole lot cheaper to run than glow fuel.
    Thanks! This is giving me a lot to think about!
    Dave
  8. #2833
    Join Date
    Apr 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You can help get the Balance forward by using two batteries .
    I usetwo 2800Li-ion Batteries with a Powerbox switch and a touch of lead (15 grams) to fine tune the setup , remembering you need a Nicad to run the box also .
    you should get it spot on that way
    I use about 300ma per flight , so you need large capacity cells for the servos and RX
    Graeme
  9. #2834
    miklos's Avatar
    Join Date
    Apr 2004
    Meriden, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok, just for clarification, you are saying to balance it 1" back from the leading edge of the wingtip not where the wing root meets the fuselage?
    Is that correct?
  10. #2835
    Join Date
    Apr 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes , that is correct.
    Graeme
  11. #2836
    Join Date
    Feb 2007
    floodwood, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a RCGF 32cc
    with 20x10 prop / only flow it twice / seems to have more than enough power/ only problem ,had to replace gear /cut the throttle to early
    keep a little power on till the wheels touch
    good luck
  12. #2837
    Join Date
    Nov 2004
    Fort Wayne, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Folks,
    I'm considering the DLE 30... On my Saito 220 I'm using a Dave Brown Spinner that I will want to reuse with the DLE30. Not sure what adapter to get for that as I'm sure the threads are probably different.
    Dave
    Never mind, called Dave Brown Products and got the info...
  13. #2838
    Join Date
    Nov 2004
    Fort Wayne, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Graeme or Capt G, I picked up a DLE 30 and wondered if you you had any pictures of how you mounted it to get the prop shaft in the middle? No lines on the firewall so I was just going to draw lines between the existing mount to place the X on the firewall and then do the same on a piece of paper of the DLE 30 mount extensions and then just overlay the X on the paper with the X on the firewall. The mount extensions end up right up against the fuse on the port side. Sound about right?
    Dave
  14. #2839
    Capt G's Avatar
    Join Date
    Jan 2002
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Find something to put in the fuse so you can hang it vertical. Then set the motor on the standoffs on the firewall with the spinner backplate on it and mark where the holes need to go.
  15. #2840
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Have you guys thought of the DLE 35? 10% more horsepower, rear-pointed exhaust. Thin profile. From what I read on TH the rear-pointed exhaust might be specifically for tuned pipes, so maybe not for this plane. But might be worth speaking to TH about.
  16. #2841
    Join Date
    Dec 2009
    Forest City, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just had the maiden flight of my Frankie. It could not have went any better. Smooth climb out.and three clicks of down elevator was the only trimming needed.
    PTE36 engine ran great. Robart electric retracts worked and looked great. She settled right in for a smooth scale looking landing.Thanks for all the free advice on this forum.
  17. #2842
    SBrian's Avatar
    Join Date
    Apr 2006
    Bedford, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Where did you get that great looking pilot for you P51?
    Steve
  18. #2843
    Join Date
    Apr 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Quote:' Find something to put in the fuse so you can hang it vertical. Then set the motor on the standoffs on the firewall with the spinner backplate on it and mark where the holes need to go.
    Like he says
    I turn 4 grub screws to a sharp point on one end , screw them into the standoffs , eyeball the spinner Smack it with a Hammer and job done
    Graeme
  19. #2844
    Join Date
    Nov 2004
    Fort Wayne, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Graeme! What an easy idea! I think I was overthinking this one.
    Dave
  20. #2845
    Join Date
    Apr 2007
    Oak Lawn, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    has anyone had a issues with the stab fulling off. Someone at the field said that I should not trust the screws and I should epoxy them in, any ideas?
  21. #2846
    Join Date
    Jan 2013
    Everett, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello,
    I have complete Hanger 9 1:50 Mustang still in box. Comes with Saito 36cc gas, Keleo exhaust, Ifltaiies pilot, Robart retract tailwheel, all the JR servos with Spektrum Dx-8 radio with spektrum case. Everything still in box, health issues forces sell. Have other kits in giant scale for sale 1/5 T/F Corsair, Mustang, and P-40 arfs. Didn't mean to interupt forum, can't seem to download on "Buy & Sell". Thank you Steven.
  22. #2847
    Join Date
    Apr 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Quote Originally Posted by thrawn150 View Post
    I can assure you that the Stab will not fall off if you fit a wooden Dowel in the tube, then fit the screws, glue them in with Cyno .
    Mine have been in for years .
    Poor thing is falling apart from all the use it has had .
    Graeme
  23. #2848
    Gentlemen - not to revive such an old thread - but looking for a cowl for this bird. I recently acquired this old gal and am toying with idea of a different engine than the included DLE 30. If anyone has one laying around. please let me know. Thanks Scott
  24. #2849
    Join Date
    Apr 2007
    Oak Lawn, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I found one on ebay from AU. 20 bucks for shipping.
  25. #2850
    just saw and nothing found when searched.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
