CMPro F4u Corsair
Old 12-20-2006, 07:02 AM
I-Aquatic
I-Aquatic's Avatar
Default CMPro F4u Corsair
I just thought of sharing some pictures of my Corsair build which started in august 2006
This is my first 120 size warbird I build. But before anyone comments on the wheel direction, [&o] I know they are facing the wrong way. Got them fixed right already
Brand: CMPro
Model: 120 F4u Corsair
Engine: Saito 150
Retracts: Robart
ID:	580575   Click image for larger version
ID:	580576   Click image for larger version
ID:	580577   Click image for larger version
ID:	580578   Click image for larger version
ID:	580579   Click image for larger version
ID:	580580   Click image for larger version
ID:	580581   Click image for larger version
ID:	580583   Click image for larger version
ID:	580584   Click image for larger version
ID:	580585   Click image for larger version
Old 12-20-2006, 07:07 AM
I-Aquatic
I-Aquatic's Avatar
Default RE: CMPro F4u Corsair
I'm not very good in explaining in detail about my build unlike some of the great build threads here in RCU, but if anyone has any question about my build I'll be glad to explain it.
ID:	580588   Click image for larger version
ID:	580589   Click image for larger version
ID:	580590   Click image for larger version
ID:	580591   Click image for larger version
ID:	580592   Click image for larger version
ID:	580593   Click image for larger version
ID:	580594   Click image for larger version
ID:	580596   Click image for larger version
ID:	580597   Click image for larger version
ID:	580598   Click image for larger version
Old 12-20-2006, 07:10 AM
I-Aquatic
I-Aquatic's Avatar
More pictures
ID:	580600   Click image for larger version
ID:	580601   Click image for larger version
ID:	580602   Click image for larger version
ID:	580603   Click image for larger version
ID:	580604   Click image for larger version
ID:	580605   Click image for larger version
ID:	580606   Click image for larger version
ID:	580608   Click image for larger version
ID:	580609   Click image for larger version
ID:	580610   Click image for larger version
Old 12-20-2006, 07:23 AM
I-Aquatic
I-Aquatic's Avatar
This warbird was supposed to have maiden many times before but there were always somthing not right that stoped me from flying. It was the rain, or the grass was too long... bla bla bla. But 2 weeks ago, our group drove up to Malaysia to a Micro Lite flying area with a great long runway and thats where I maiden my bird!
ID:	580612   Click image for larger version
ID:	580613   Click image for larger version
ID:	580614   Click image for larger version
ID:	580615   Click image for larger version
ID:	580616   Click image for larger version
ID:	580617   Click image for larger version
ID:	580618   Click image for larger version
Old 12-20-2006, 07:26 AM
I-Aquatic
I-Aquatic's Avatar
Here a the pictures of the maiden flight
ID:	580621   Click image for larger version
ID:	580622   Click image for larger version
ID:	580623   Click image for larger version
ID:	580624   Click image for larger version
ID:	580625   Click image for larger version
ID:	580626   Click image for larger version
ID:	580627   Click image for larger version
ID:	580629   Click image for larger version
ID:	580630   Click image for larger version
ID:	580631   Click image for larger version
Old 12-20-2006, 07:44 AM
Edwin
So how did the flight go? I had heard cmp retooled this plane and was wondering about the fiberglass on the wing, how is it holding up. Retract rails strong enough and cg location?
Edwin
edit- Nice job, looks good. You ARE gonna fix those wheels arent you!!
Old 12-20-2006, 07:59 AM
I-Aquatic
I-Aquatic's Avatar
The flight went well. Much better than expected. The landing was very nice and slow without the flaps. But this was because there was good wind on that day. The standard mount for the retract was weak as usual but after reading that allot of guys modify the mount on their CMPro planes, I did the same from the start. I cut the retract ray out and epoxied plywood to area. Now its really strong.
The wing feels solid and the finishing is nice Matt look to. I had the old silver cmp P47 and the fuse was really soft and the wing wrinkles allot under the sun. I gave up on CMP until I saw the improvements they did on the newer planes. My and my buddy just got the 140 P40 and I got the 120 zero and it looks fantastic!
Yes I did! Actually only just now when I had time.
ID:	580635   Click image for larger version
ID:	580636   Click image for larger version
Old 12-20-2006, 08:03 AM
I-Aquatic
I-Aquatic's Avatar
I actuall moved the retract forward a bit to try to prevent nose over when landing.
This was my first robart retract and I made the wheels to retract a bit too slow. So on the maiden flight, I had had a huge problem to get them down and locked. I tried opening and closing, flying in a bouncing manner in the air trying to get it down. NO luck. Realised that it could be because it tuned to slow and in addition this (pic) was not helping either. So I closed the retract. Then just before I did a stall turn I engaged the retract. Did another fly by and it was locked and good for landing.
Old 12-20-2006, 10:06 AM
Edwin
I've got the zero too. Its pretty much finished except for retracts. Waiting on money and time for that one so its sitting out of the way for now. I repainted mine cause the finish was chipping off too much. Its powered by a saito 180. I also have the spitfire. It flys pretty good and scale on a saito 120.
Edwin
ID:	580653   Click image for larger version
Old 12-20-2006, 10:12 AM
Edwin
Oh! Dont feel TOO embarassed about the wheels. I did it too. Got all the way to the field and set it up. Noticed it one second before others did. Some things you never live down.
Edwin
Old 12-20-2006, 10:18 AM
Edwin
Is that their hardware or did you replace it all! Looks like what I had on a world models cub awhile back, it was pretty good. Sounds like they've improved the corsair quite a bit. I dont think the first one had flaps did it! This is good cause thats a good size for a corsair. Do you think a saito 120 or 125 would power it ok?
Edwin
Old 12-20-2006, 10:47 AM
I-Aquatic
I-Aquatic's Avatar
ORIGINAL: Edwin
Edwin
Actually the hardware for the zero was much better than the f4u but this was not the reason why I got my own hardware. The only reason is the once thay gave were white and it would stand out on the blue. So I got the better black ones. Also the elevator rod is wooden (f4u) compared to the zero fiber rod.
CMpro have really improved allot. Most new planes come with the stickers already done! Only thing that bugs me a bit is they put their CMpro logo on the plane.
I chose 2 servos for the elevator only because I did not want to buy more servos. I already had 2 3kg serovs for each elevator. This should be enough.
I have some buddies flying the 120 warbird with a 120 saito without any problems and flies good too.
Old 12-20-2006, 10:50 AM
I-Aquatic
I-Aquatic's Avatar
ORIGINAL: Edwin
Edwin
What was embarassing about it was a young chap (14yrs old i think) in our group spotted this mistake
The kid in blue [:@]
Old 12-24-2006, 12:25 PM
I-Aquatic
I-Aquatic's Avatar
Merry Christmas to all!!!
Just wanted to share the video clip of my maiden flight.
http://www.rcuvideos.com/view_video....7006e5d1672887
Old 12-24-2006, 12:44 PM
ZXPilot
I-Aquatic,
Very good job on the plane and the video!! I think the word "inspirational" sums it up. [8D]
Thanks for sharing.
Have a very Merry Christmas everyone!
Old 12-24-2006, 03:26 PM
Sturtz
My Feedback: (20)
Sturtz's Avatar
Great video !!!!! TWO THUMBS UP !!!!!
Merry Christmas to you and your's.
Old 12-24-2006, 04:46 PM
LDM
My Feedback: (15)
great job , agree on CMP , I have the 73" p40 , they are great planes , they have stepped up quality !!!!!!!!!!!!!!!
Nice flying and video
Old 12-24-2006, 09:45 PM
I-Aquatic
I-Aquatic's Avatar
This video was done by our sifu Steven Wong in our club. Thanks steven for this great Video production!
Old 12-24-2006, 10:00 PM
Jarrah
Jarrah's Avatar
After watching this vid i want this plane. wat size gasser would u want to run in it??
Cheers
Old 12-25-2006, 01:38 AM
vasek
vasek's Avatar
Nice vid!
I am glad to see the CMP F4U in flight. I love the Corsair, but read stuff about staying away from this CMP model...
I have the CMP Zero, have ordered the Warhawk & would love to have the Corsair.
Can anyone confirm CMP has upgraded the F4U?
If yes, how do you tell the New ARF from the Old?
V.
Old 12-25-2006, 02:06 AM
I-Aquatic
I-Aquatic's Avatar
ORIGINAL: Jarrah
Cheers
Probably a 26 would be more than enough. I'm not to sure about gas engines.
Old 12-25-2006, 08:26 AM
LDM
My Feedback: (15)
The only way you will know is to ask and buy from a reputal dealer like (akm ).(they sell the lasot cut su27 kit that is all over RCU ) Its either AK or AKm , do a google search . They turn a ton of inventory and they will know . I recently went to the Giant scale planes store , the original owners and distributors of CMP . I know that he has very little stock left on CMPs because he does not have exclusive distribution from the factory anymore because he can not make the shipping minimums . As you know he had a very bad rap on over charging on shipping .I can drive there so I was lucky and the store personel and owner were very friendly
He is a very interesting person to talk to and learn about the planes coming from China . He (the owner of US rights to CMP ) will be back in major distribution in the near future of all composite models from China . I will be interested to see what this guys develops , he knows the biz and what RC guys want . The original CMP spitfire is a very beutiful plane for the money , it has some scale flaws but they can be fixed .
The CMP P40 is a real gem !!!
I also would love the Corsair , some of the original problems were stated as follows --
weak landing gear mounts --ok easy to fix -(I always reinforce regardless of what it looks like
Outer wing panels did not match color exactly to inner wing panel -(same problem with Kondor models version of the Corsair)
Cowl was thin -and not exactly scale
That was what I remember , but you can email CMP in China -contact Jackie , she is very responsive and truely cares about the CMP consumer .
I have to tell you , I have over 8 warbirds from either CMP -willshobbies , evergreen ect all China based factory made planes , avg price paid is $93 to $269 , I love all of them , they all have great potential for standoff scale .
Yes they all have there issues but try building one at that price .
Old 12-25-2006, 09:05 AM
dmyers0403
My Feedback: (48)
AKM does not show the Corsair on their wed site - Is the Nitro Planes Corsair the same one?? Where is the best place to buy this kit and get the correct one - Thanks
Old 12-25-2006, 09:13 AM
LDM
My Feedback: (15)
Yes Nitro is the same plane , and based on there sales they should have all new inventory , my problem with them is questionable communication with other RCU members .
Ask them a question in there support section of RCU and see if you get the answer you want before you buy ..
Old 12-25-2006, 09:15 AM
LDM
My Feedback: (15)
Opps also before you are getting a real CMP vs a copy from Nitro , they carry both on many of the CMP planes , but I dont think they offer two versions of the Corsair .
I know they do on the SPIT , Hellcat and P40 & FW 190 (offer copies that is )
