Reload this Page >
CMP giant scale Zero build
Old 03-12-2010, 07:17 AM
  #326
flyer35
My Feedback: (33)
Default RE: CMP giant scale Zero build
Thanks Jim I bolted the weight behind the firewall. Since it's still winter here I will have time to rework it. I did fly this plane as is last fall and it flew well but less weigh is always good. Again good luck it does fly very well, Bill
Old 03-12-2010, 09:15 AM
  #327
cswann821
With the DLE 55 having a rear mounted carborator...won't this make tuneing a big hassle/pain, haveing to take off the Cowl to access it when ever adjustments need to be made? I'll compare to the cowls measurements tonight.. Thanks for the DLE specs. just haven't seen anyone run a rear mounted on this bird yet in this thread. I guess onces the engine's tuned though... I'd only acces it onces in a while pre-flight.
Any other engine suggestions?
Old 03-12-2010, 01:40 PM
  #328
jstanton
My Feedback: (14)
jstanton's Avatar
If you are looking for a power house of an engine and want a side mounted carb like must of us are using Brillelli is still making a few engines for those that want something American. Take a look at Brillelli customs and talk to Mark. He still has a new Brillelli 60 and I know it is a very strong engine. He specializes is custom engines and he might be able to put together a Brillelli 46GT. Here is his web site.
http://brillellicustoms.com/index.html
Old 03-14-2010, 09:43 PM
  #329
jstanton
My Feedback: (14)
jstanton's Avatar
Here is a small video of the Brillelli 46GT being test run after 2 years sitting on a shelf. Now I am waiting for some good weather and than I'll do the maiden.
http://www.youtube.com/watch?v=_jrMf2T4nOw
Old 03-23-2010, 03:50 PM
  #330
cswann821
Does anyone have some pics of a rear mounted Carb engine in their Zero?
Thanks!
Old 03-24-2010, 11:33 PM
  #331
cswann821
Hey guys, can anyone recommend a place to get stand offs. If I'm doing the math right, with the DLE55's 170mm length (this is the end of the stock standoff to the spiners backplate)... added onto the ~73mm deep motor box, and accounting for cowl depth, and the 5-7mm prop to cowl space. I am going to need stand offs of about 33-35mm.
170mm (engine with installed stock standoffs length)
+ 73mm (engine box)
= 243mm vs the cowls 203mm length. (DLE is to long with it's stock standoffs)
so 243-203= 40mm ... so the engine/standoff lengthneeds to be shortened 40mm for the spinners back plate to be flush with the cowl length.
Stock DLE 55 Standoffs= 68mm - 40mm + (5 to 7mmto account for neededspinner cowl space) = 33 to 35mm standoffs will be needed
Is my thinking correct here?
Old 03-25-2010, 02:04 AM
  #332
flyer35
My Feedback: (33)
At the hrdware store in with the nut and bolt section you can find spacers of various sizes. They work well. I had the same problem with a Fuji engine I had to take the engine box off and use homemade standoffs.
Old 03-25-2010, 04:36 AM
  #333
jstanton
My Feedback: (14)
jstanton's Avatar
I had the same problem with my Brillelli 46GT. I did not use the engine box and I made a mounting block out of two 3/4" plywood pieces I had on hand. Here are a couple of pic's of the install. It just my help you with another option for mounting your DLE 55.
ID:	1404429   Click image for larger version
ID:	1404430   Click image for larger version
ID:	1404431   Click image for larger version
Old 03-25-2010, 04:43 AM
  #334
jstanton
My Feedback: (14)
jstanton's Avatar
Bill,
Have you moved your weight to the forward side if the firewall yet? I was wondering how much weight you have been able to save since you have already moved all your servo's into the fuselage
Old 03-25-2010, 07:56 AM
  #335
flyer35
My Feedback: (33)
Jim, I haven't yet been busy building a 1/4 scale Sopwith. I did however move the servos from the tail to the CG area and that save 1/2# I will move the weight from behind the firewall to a platform over the engine I think this will save a full LB. Keep you posted, Bill
Old 03-25-2010, 10:12 AM
  #336
cswann821
Thanks for the pics Jstanton, so I don't have to use the engine box that comes with the kit. I wonder if I could just use the single square ply piece that also comes in the kit instead. Heres a pic of the piece i'm talking about posted in flying giants.
http://www.flyinggiants.com/forums/s...t=28437&page=7
Old 03-28-2010, 04:35 PM
  #337
jstanton
My Feedback: (14)
jstanton's Avatar
I used that piece and had to use another 3/4" piece of plywood to get the distance I needed for the prop hub. It will workout just fine. Just remember if you use a DL-55 you will also need about 2 lbs of lead in the nose so make sure you leave room to add it. Good Luck. I hope to maiden my Zero this coing Sunday if the weather holds
Old 04-12-2010, 04:57 AM
  #338
jstanton
My Feedback: (14)
jstanton's Avatar
I did the maiden flight on Sinday afternoon. All I can say is this is one very nice flying War Bird. The take off was buestiful and the plane is very stable. The ESM retracts worked great and I am very glad I went with them I had a couple of issue in the flight. All of my batteries where mounted in the cowl and the reciever batteries came loss. I had them shrink wrap so they did not fall out they just hung under the cowl in flight, I also had the throllle arm come off of the carb. i guess I forgot to lock it down. I used the remount kill swict I had install and killed the engine and gilued down and landed in some tall grass at the end of our runway. One landing gear mount broke loss and that was all the damage. I have already repaired the mount and attached the batteries to the cowl again. This time they will not come loss. I plan the fly the Zero again this Tuesday. I got some video taken and I'll post it ASAP.
Old 04-12-2010, 06:55 PM
  #339
paladin
My Feedback: (9)
Congrats Jim!
you'll have here dialed in soon.
Joe
Old 04-20-2016, 04:45 PM
  #340
cswann821
Hi everyone! After having this bird in a box for YEARS now I am FINALLY building her. I got my Retracts installed , went with Century Jet, and I have a DLE55 rear exhaust.
So I ended up cutting down my Motor box so I could keep my engine carb fully exposed and not have to deal with cutting standoffs. Now I am trying to line up my motor box onto the front of the zero's fuse BUT the fuse has no hash marks like I've seen in other build pics and I believe the build diagram says that there should be. !!! I do have hash marks on my motor box..just not the fuse? the box hash marks do not center around the small circle in the fuse correct?? or do they?
Can anyone perhaps send me measurements in reference to the small fuse hole center to create my own hash marks?? WHAT TO DO?
Old 04-21-2016, 09:40 PM
  #341
Prekin
My Feedback: (19)
Prekin's Avatar
I´m not sure if I understand you what you want. Could you post some shots, what you need? Maybe I could find my my Zero pictures.
Old 04-22-2019, 04:45 PM
  #342
steph280
Sorry to revive this old thread. But finally got around to building mine. Just wondering if anybody have retracts for this bird not being used anymore?
Old 11-01-2020, 06:13 AM
  #343
Trommeldave
Hey Steph,
i do not have any retracts i can give to you, but i'm almost starting to build mine. I use these retracts you see in the link.
Motor would be a Saito fg60-r3.
Please tell me/us bout your built!!
https://www.zyhobby.com/3pc-set-cys-...ane-p0196.html
Best regards from Germany,
Dave
Old 11-01-2020, 07:50 AM
  #344
jstanton
My Feedback: (14)
jstanton's Avatar
Glad to see this tread once again active. I am recovering my CMP Zero you the earlier 1941 model. I have the covering removed and recover with Sig Koverall. Just have to paint it now. As for the retracts here is what I have used.
https://hobbyking.com/en_us/all-meta...en_us_products.
These are very robust and work really well. I will take a pic once I get back out working on it again and post it here.
Old 11-01-2020, 08:31 AM
  #345
Trommeldave
Hey there,
nice. Looking forward to your paint job!
those hk retracts must be great. I know lots of pilots using them and they all say the same...
never got them by myself.
the ones i use are surely a lot more stable and strong but also more expensive...
rg, Dave
Old 11-01-2020, 12:19 PM
  #346
jstanton
My Feedback: (14)
jstanton's Avatar
Dave,
Here is a short video of the Hobby King retracts in the wing of the CMP Zero.
https://www.youtube.com/watch?v=U4pj...ature=youtu.be
Old 11-01-2020, 11:38 PM
  #347
Trommeldave
Yeah, nice vid.
Are you going to enlarge the wheel well area?
I think the wheels that come with the kit are way to small for this big airplane?
i would do this on mine and also mold the wheel houses like i did on my Spitfire. Looks much better, less dirt comes into the wing inside while start and landing and less turbulences while the gear is down...
jstanton (11-02-2020)
Old 11-02-2020, 12:09 AM
  #348
Trommeldave
Old 11-02-2020, 04:42 AM
  #349
jstanton
My Feedback: (14)
jstanton's Avatar
Originally Posted by Trommeldave
Yeah, nice vid.
I did enlarge the wheel area. Those wheels on the gear are 4.5" wheels. The ones that come it the kit are maybe 3" wheel if they are that big. I am also going to do what you did on your Spitfire. You did a very good job. The weather has turn cold here now so the building will continue but it may be a while before I can paint it.
Old 11-02-2020, 05:18 AM
  #350
Trommeldave
Oh ok, thats good! 👌
thanks, was even not easy to bend the 1mm balsa in there, but i‘m happy with the result!
sure, the weather here in Germany is also not right to fly or do anything outside. Also all the model airfields are closed now because of corona 😐
so, back into the basement!
