TF Corsair "sub ribs" for wing sheeting.
ON, CANADA
At step 28 of the wing covering build, it says to use R-5C sub ribs (just prior to covering with sheeting). Can anyone tell where I might find these sub ribs? I've checked the "parts list" where it shows the pictures of the die cut parts and can find nothing named R-5C, either in balsa or ply. Nor any named parts called sub ribs.
http://manuals.hobbico.com/top/topa0101-manual-v3_0.pdf (p12 of 44 in the pdf file link).
Thank you.
Thank you.
My Feedback: (85)
RE: TF Corsair "sub ribs" for wing sheeting.
Len,
Found them !!!!
Go to pg 4 in the book. Look at "Die Cut Parts" # CRS6W08 you see sub rib 5 that little triangle piece on top is Sub rib C. If you tossed it you can make another out of scrap. It's not a major structural part it only helps you form the oil cooler profile.
Pete
ON, CANADA
WOW! Totally unmarked piece. I found it sitting in my scrap box. How in the world did you know that was the item when you first did the build?
Thanks Pete. [sm=thumbup.gif]
