P47 pics & 3 views
LA
P47 pics & 3 views
Have an up coming P47 bubble project starting soon and dont have as much info on paint schemes and 3 views as I want. Looking for web info and pic assortment for ideas. Search engines have not helped much.
ON, CANADA
P47 pics & 3 views
No offense but you gotta try a bit harder in your search. There are a ton 'o pics available.
Firstly, go to images.google.com and do a thunderbolt p-47 search
images.google.com/
Then try some of these:
www.wpafb.af.mil/museum/research/p47.htm
scroll to page bottom
www.eaglestrikeproductions.com/cgi-bin/amddecals.pl?scale=48&setid=083&dbs=aeromaster&pgs=2&currpg=1&dclimg=ad48083
www.eaglestrikeproductions.com/cgi-bin/amddecals.pl?scale=48&setid=348&dbs=aeromaster&pgs=2&currpg=1&dclimg=ad48348
www.airbum.com/photos/P-47Thunderbolt3.jpeg
(a nice cockpit pic)
www.avnet.co.uk/tfc/p-47d/img/p-47d_05.jpg
Those oughta get you started (I mostly searched for the razorback pics so my bookmarks mostly reflect those...however, I have a ton of them and the razorback is harder to find!)
Syd
images.google.com/
Syd
My Feedback: (60)
AZ
Jug
Lenny, you might try dropping by www.aeromaster.com and searching for decals for the Jug in the various scales. The web site usually shows several views of each color scheme and if you find something you really like you can always order the decals. I also have the Squadron Signal "Walk Around" book on the P-47 and it is highly recommended. Good luck, Chad.
P-47 info
Scale Aircraft Modelling out uf the UK...November 1999 issue. Volume 21 number 9 is an issue you cant do without. 35 color profiles with info about Allied countries flying big Jugs. Aero Detail 14 P-47 thunderbolt . Squadron/Signal publications has at least 4 that I have: P-47in the pacific,P-47 walk around, p-47 in action, P-47 in Europe, And Detail & Scale has P-47 t-bolt volume 54 d&s that includes all production versions. Also Waine Seiwert at Aerotec models in St. Paul, MN. sells lots of stuff for big Jugs...Is this enough info to keep you busy for awhile?
