KMP F8-F Bearcat
Old 08-19-2013, 12:30 AM
  #601
juweeltje
juweeltje's Avatar
thanks rcguy59 for your replay.
will try a menz 18/10 first and see if it fly's better than a 19/8…..and than a 18/12….
cu
Old 09-19-2013, 12:19 AM
  #602
juweeltje
juweeltje's Avatar
does anyone have a retractable tail wheel? if so witch one do you use?
@rcguy59,
I have tried a 19/8, 18/8, 18/10 on the ground.
conclusions : I have the most torch with the 19/8
18/8 , 7500rpm , 5.5 kg.
18/10 6900rpm 4.5 kg.
19/8 6810rpm , 6.0 kg.
as I need much torch (because of our short runway) I use a 19/8.
But still is think I also will try a 3 blade 18/10.....
Old 09-19-2013, 05:56 PM
  #603
rcguy59
My Feedback: (8)
rcguy59's Avatar
I'm using a Robart retractable tailwheel in mine.
Old 09-19-2013, 09:55 PM
  #604
juweeltje
juweeltje's Avatar
rob160 or rob120?
Old 10-07-2013, 10:23 PM
  #605
juweeltje
juweeltje's Avatar
bonjour Pasc,
yesterday, i had also a hard landing.
because of the hard landing, the part that wass glued in het middel of the wing ( fusalage part) came off.parently it wasent glued verry well....
so it came of en get stuck at the tailwheel, the plane tiled over on the left side, so the left wing had get the full weight of the plane....and it broke in the middle of the left wing (left top is o.k.).
Seems that some wingparts are not made from plywood but made from balsa(7), so those broke....
now im repair them.
i have seen that you have repainted your wing as well. .... can you tell me if the paint you have used is the exact collor that i need?
also i wonder what type of wood they used for the broken (how do I call that...?)wingskeleton...?? I have copied wing skeleton (photo 7 ) in balsa , but the balsa piece weights only 1 gram..;the original piece weighs 2 grams....so I wonder what wood is it...? it "looks" and feels a bit like balsa but it's darker and a little bit stiffer.... Its certainly no hardwood triplex....
thanks juweeltje
Old 10-08-2013, 02:54 AM
  #606
flyingchef
My Feedback: (93)
flyingchef's Avatar
For the tail wheel retractable gear I originally used the 60 size Robart, it came out to be to weak for the weight and after replacing it twice I made my own.
Old 10-08-2013, 09:02 AM
  #607
pasc
Originally Posted by juweeltje
bonjour Pasc,
now im repair them.
thanks juweeltje
Hello juweeltje !!
The paint I have used is : http://www.klasskote.com/product/KKAMCGS15042 it's the same color of the kit.
Here a picture of my F8F after repair:
On my repair, I removed all the coffering and reconstructed new ribs in balsa or ply wood.
I also strengthened the main "longeron".
Then I confined completely the wing, and cover this with lite fiberglass 25gr and epoxy resin.
Have a good luck for the repair
Pasc
Old 10-08-2013, 10:10 AM
  #608
juweeltje
juweeltje's Avatar
pascal, did you buy the paint directly or did you order the paint in your hobbyshop?
and she looks great again. did you apply the paint with a brush or by a airpistol?
Old 10-08-2013, 12:02 PM
  #609
pasc
I buy the paint directly at klasskote.co.uk but this site is currently inactive.
I apply the paint with a airpistol.
Here a picture of my last construction: (P51D TopFlite Gigant)
Old 10-08-2013, 12:34 PM
  #610
juweeltje
juweeltje's Avatar
pasc, looks realy nice !
i have never painted with a airpistol , so i have googeld a bit.
looks like i need a mini hvpl pistol with a 1.0mm noisle, is tis correct, ore witch basic inexpensive pistol is just fine for this paint job?
juweeltje
Old 10-09-2013, 10:51 AM
  #611
pasc
juweeltje
I use a standart airbrush for retouch of car carrosier like this : http://www.raccordsprevost.fr/PISTOL...pc1000003.html
Pascal
Old 10-09-2013, 11:48 AM
  #612
juweeltje
juweeltje's Avatar
thanks….will look in to it...
i have already looked for the ral replacement color of the fs 15042, and that should be the ral 5011 .But is't not quit the same collor , it's lighter blue….
Old 12-28-2013, 09:47 PM
  #613
w1nd6urfa
w1nd6urfa's Avatar
Hi all,
I was given a ESM Bearcat with a broken wing from a bad landing, the damage is quite extensive as the top main spar broke and most of the ribs in the retract bay area split.
This model is very nice on the outside, but after a close inspection at the wing internals it is made very lightly for its size/weight and - at least mine - used the worst quality wood one could possibly find! The ribs are made of 1.5mm dry balsa that breaks if you touch it, the main spar has vertical grains (that's where it broke ofcourse)
So it looks like a major rebuild to reinforce all these weak areas.
http://flickr.com/gp/109944463@N07/07Y4s1
Old 12-28-2013, 09:51 PM
  #614
w1nd6urfa
w1nd6urfa's Avatar
http://flickr.com/gp/109944463@N07/r4L416
Old 12-28-2013, 10:01 PM
  #615
w1nd6urfa
w1nd6urfa's Avatar
http://flickr.com/gp/109944463@N07/5Hxi6V
Old 12-28-2013, 10:09 PM
  #616
w1nd6urfa
w1nd6urfa's Avatar
I'm contemplating the forces acting on the wing from the landing gear, and it looks that the long struts combined with the gear mount position (near the middle of wing) and the "compressed paper" plywood used by ESM for the retract mounts is a recipe for disaster, it all has to change.
After studying a few Bearcat plan kits (Top Flite, Ziroli) I decided to install hardwood beams for the retract mounts, and spread the loads on 5 ribs rather than 2:
Of the 5 the 3 ribs are pre-existing and 2 will be half-ribs I will add myself.
http://flickr.com/gp/109944463@N07/5503s2
Old 12-28-2013, 10:11 PM
  #617
w1nd6urfa
w1nd6urfa's Avatar
http://flickr.com/gp/109944463@N07/Fhbs99
Old 12-28-2013, 10:15 PM
  #618
w1nd6urfa
w1nd6urfa's Avatar
Dry fitting with the retract-strut-wheel to align everything:
http://flickr.com/gp/109944463@N07/4AdB99
Old 12-28-2013, 10:19 PM
  #619
w1nd6urfa
w1nd6urfa's Avatar
For strengthening the main spar and leading edge I will add carbon fibre strips and rods
http://flickr.com/gp/109944463@N07/ZA3s49
  #620
w1nd6urfa
w1nd6urfa's Avatar
http://flickr.com/gp/109944463@N07/155776
Old 12-28-2013, 10:21 PM
  #621
w1nd6urfa
w1nd6urfa's Avatar
And along the spar:
http://flickr.com/gp/109944463@N07/7NBtwF
Old 12-29-2013, 12:15 AM
  #622
juweeltje
juweeltje's Avatar
hi there,
a few months ago i had a bad landing myself,
the left wing was half destroid,the top off the wing was undamaged.
and yes, i found that the wing ribs are made from very light balsa. i replaced the broken ones with 2mm light triplex.
now everything is repared and ready to get painted...
good luck with the rebuild.....
ID:	1952180   Click image for larger version
Old 12-29-2013, 10:15 AM
  #623
w1nd6urfa
w1nd6urfa's Avatar
Good job!
Finished the starboard side, result is solid
http://flickr.com/gp/109944463@N07/8s1048
Old 12-29-2013, 10:20 AM
  #624
w1nd6urfa
w1nd6urfa's Avatar
My plan is to cover the wings with Fliteskin for extra durability and scale appearance, what do you think?
I built a Spit this way and I'm sold on it: http://www.rcuniverse.com/forum/rc-w...fliteskin.html
Old 12-30-2013, 12:41 AM
  #625
juweeltje
juweeltje's Avatar
i have used normal white covering foil from hk.
I when't to a car shop, and they made me the same color in a spray paint.
