RT Aerospace 1/5th T-34C Build
Reply
Old 12-09-2007, 10:02 PM
  #51
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RT Aerospace 1/5th T-34C Build
Just a quick update. I did'nt get too much work done this week. Just closed up the flaps and made the gap fillers. be starting work on the retracts this week. Need to decide if I am going put in nav lites too.
ID:	822502   Click image for larger version
ID:	822503   Click image for larger version
ID:	822504   Click image for larger version
TLH101 is offline
Old 12-10-2007, 07:35 AM
  #52
mimoore67
My Feedback: (51)
mimoore67's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My vote is for the Nav lights! You've gone to all this work so far, why not a little more!
mimoore67 is offline
Old 12-16-2007, 07:37 PM
  #53
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have not had as much time to work on the T-34 lately, but I am still plodding along.
Decided to change the flap control system. I just did not really like the "Y" thingy. Looked cheesy. I built a bellcrank style, control that is quite a bit more positive.
ID:	827305   Click image for larger version
ID:	827306   Click image for larger version
ID:	827307   Click image for larger version
TLH101 is offline
Old 12-17-2007, 06:43 AM
  #54
fliir
fliir's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Terry
The word that comes to mind is "robust". I like it!
vis-a-vis lighting - nav lights are not normally run in the daytime - when you will be doing scale flight. I will be painting in unlighted colored wingtip nav lights, but I am going with all (3) strobes, which ARE often run in the daytime for collision avoidance.
fliir is offline
Old 12-18-2007, 10:01 AM
  #55
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, went outside and watched them for a while yesterday. Most, but not all had 3 white strobes going. Did not see any with nav lites. When they were close to the field, the landing lites were on, on some birds. I think I will just use s set of strobes, that are on all the time. Found a guy who can do a set of three random flashing white LEDs, that plug into the receiver, and come when the model is turned on. Draw almost no power, and only $15 a set.
Just had to see what it would look like this morning. Nice sized model, not small, but not too big. Sure is a lot of cockpit room to fill.
ID:	828538   Click image for larger version
ID:	828539   Click image for larger version
ID:	828540   Click image for larger version
ID:	828541   Click image for larger version
ID:	828542   Click image for larger version
TLH101 is offline
Old 12-21-2007, 10:17 AM
  #56
GEARED
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Terry,
I found a good source for T34-C cockpit details: http://www.airnorthwest.net/specops/t34c/P-307.pdf.
You can download the illustrations you get interested on.
Enjoy!
Geared
GEARED is offline
Old 12-21-2007, 10:42 AM
  #57
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good info!
TLH101 is offline
Old 12-29-2007, 05:09 PM
  #58
fliir
fliir's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Terry:
Back about post 21 or so, I see that you have the wingtips on your wings. I haven't worked much with vacuum formed plastic. Can you give me some hints as follows:
1. What do you do to prep the plastic? Do you roughen the surface where it attached to the rib?
2. What do you like for adhesive? Do you epoxy them on or use something else?
3. What is your preferred primer for the V.F. material?
Thanks!
fliir is offline
Old 12-30-2007, 02:01 AM
  #59
dtw757
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Terry,
If you want a good illustration of the layout of both cockpits including the instrument panels, I still have my old NATOPS manual. I could
scan the pages and send it by e-mail.
dtw757 is offline
Old 12-30-2007, 09:23 PM
  #60
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
fliir,
I just use some 60 grit paper to roughen the glue surface.
I have used epoxy, Goop, RC 56 canopy glue, and thick C/A in the past.
I just use whatever I am priming the model with.
TLH101 is offline
Old 12-30-2007, 09:26 PM
  #61
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
dtw757,
Sent you a PM.
TLH101 is offline
Old 12-30-2007, 09:30 PM
  #62
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Installed the retract rails and started sheeting the bottoms of the wings. Slow but sure.
ID:	837882   Click image for larger version
ID:	837883   Click image for larger version
ID:	837884   Click image for larger version
ID:	837885   Click image for larger version
TLH101 is offline
Old 01-01-2008, 09:43 AM
  #63
fliir
fliir's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Terry:
Did I offer you the photos I have collected/taken? I have (3) exterior shoots and one interior shoot. Let me know if you want them, I can burn a CD for you...
David
fliir is offline
Old 01-01-2008, 04:10 PM
  #64
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
fliir
Thanks for the offer. I'll see what I can do with what I have. If do end up needing more, I'll certianly let you know.[sm=thumbs_up.gif]
TLH101 is offline
Old 01-01-2008, 04:19 PM
  #65
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Been working on the retract doors today. The gear doors that come with kit a very nice heavy plastic parts that look nice. And they have the correct contours molded in them.
I cut out the doors and cleaned up all the edges. I located the exact locations before sheeting to be sure I would not screw anything up. So now it was just a matter of laying the doors down and tracing around them, then cutting the sheeting.
ID:	839503   Click image for larger version
ID:	839504   Click image for larger version
ID:	839505   Click image for larger version
ID:	839506   Click image for larger version
TLH101 is offline
Old 01-01-2008, 04:45 PM
  #66
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Next, I installed all the hinges on the doors, as set out in the manual. They are just tacked with C/A and some screws for now, so I can disassemble them later. I had to change the way the inner doors were actuated, as they were designed to work off the mechanical retract servo. I have just added a control horn and a 1" travel air cylinder. I will use a UP-2 control valve from Ultra Precision, or a pair control valves, with a door controller, to actuate the gear and doors. the inner doors work like a Mustang, with doors being closed when gear are down. The outer doors are actuated by a piece of tubing that slides on the wire attached to the strut. Right now, I have clamped it on with a hose clamp, but will make a brass strap to hold it later.
ID:	839553   Click image for larger version
ID:	839554   Click image for larger version
ID:	839555   Click image for larger version
ID:	839556   Click image for larger version
TLH101 is offline
Old 01-01-2008, 05:39 PM
  #67
YAT-28E
YAT-28E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TLH ,
Keep the thread going!!!
I just started to follow and have seen some great ideas to be used on my T-28 build for linkages!!
Great info!!
YAT-28E is offline
Old 01-06-2008, 11:26 AM
  #68
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finished the gear doors on the opposite wing this week and started on some of the finish work.
I shaped the leading edge and added the L/E cuffs the blend to the fuse.
ID:	843717   Click image for larger version
ID:	843718   Click image for larger version
ID:	843719   Click image for larger version
ID:	843720   Click image for larger version
TLH101 is offline
Old 01-06-2008, 11:30 AM
  #69
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also worked on the gap fillers for the ailerons. This was done by sanding a groove in the T/E with a special tool I built, then laying a piece of 1/32 ply in the groove. Really simple setup that is very strong.
ID:	843722   Click image for larger version
ID:	843723   Click image for larger version
ID:	843724   Click image for larger version
ID:	843725   Click image for larger version
TLH101 is offline
Old 01-06-2008, 01:55 PM
  #70
mimoore67
My Feedback: (51)
mimoore67's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW, I really appreciate your work, keep it up! I'm learning a lot just from the pictures!
Old 01-09-2008, 12:29 PM
  #71
fliir
fliir's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Terry:
Did you consider any other hinge and actuator system for the ailerons?
I would prefer one aileron per servo, but I want to retain scale hinge lines and concealed linkages...
fliir is offline
Old 01-14-2008, 08:55 PM
  #72
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: fliir
Terry:
I thought about using seperate servos on each aileron, but I really wanted to try the scale system. Every other model I have built in the last 10 years, or so, uses 2 servos in the wings.
TLH101 is offline
Old 01-14-2008, 09:10 PM
  #73
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A few pics of the stab. The elevators will be hinged same as the ailerons,
ID:	851384   Click image for larger version
ID:	851385   Click image for larger version
ID:	851386   Click image for larger version
ID:	851387   Click image for larger version
ID:	851388   Click image for larger version
ID:	851389   Click image for larger version
ID:	851390   Click image for larger version
TLH101 is offline
Old 01-15-2008, 08:09 AM
  #74
GEARED
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all,
I am attaching some pics of the stab/rudder of T34C I am kit-batching from a TF t34B kit . Lots of work and fun!
Geared
ID:	851806   Click image for larger version
ID:	851807   Click image for larger version
GEARED is offline
Old 01-15-2008, 10:02 AM
  #75
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking pretty good.
The model I am replicating, does not have the corregations on the stab. I have seen a lot of "C"s that do, but all the planes I have seen, at the nearby base do not. However, they do have the corregations on the rudder & fin. Not sure what the deal is.[&:]
ID:	851881   Click image for larger version
ID:	851882   Click image for larger version
TLH101 is offline
