H9 Corsair .60 wing
H9 Corsair .60 wing
I have the hots for another sport - scale Corsair, and I like the looks of the H9 .60 size ARF. I've read the various threads about this ARF, but I don't have a clear sense of whether the wing structure is really weak or not.
For those of you who have this ARF, is the wing a serious problem? My landings are almost always gentle, but I DID say "almost."
Appreciate your opinions.
Mike
Mike
My Feedback: (15)
RE: H9 Corsair .60 wing
I had issues with generation one , but simply glassed the internal area near the reported problems , I have just purchased a new one , and wondering if its needed because the firwall on this one is reinforced so I am figuring that the wing is also reinforced
Mike- Ihave been reading the threads on the H9 Corsair wing. I built this plane last year and I had about 20 flights on mine and I notice that the covering was flexing on one wing just outside the wheel well. I understand that is an area where some wings broke. Well, I recently purchased another wing and glassed as far into the wing as possible. This new wing flys great and I have bounced it hard several times on my CJ retracts with no problems. I even painted the wheel wells green and left off the plastic inserts. Looks more scale. I glassed about 3 ribs on either side of the wheel wells...one nights work. I also noticed that the wing was visibly well glued with hot glue. I also had 3 cracked or broken ribs in the new wing that I was able to glass. I am very confident that this solved my concerns about any wing weakness based on all the information I have read on this subject. It was really an easy fix!
Tim
Tim
Mike-
I did not have to remove any covering. I was able to reach far enough into the wing with the metal disposable epoxy brushes. One I kept straight, one I bent 45 degrees and one I bent about 100 degrees so I could work it behind the ribs down in the wing. I precut patches of fiberglass before I started and then put epoxy in the area I was working. Then I would set a patch on the brush and place it in the wing and brush it lightly into place. I did each wing in 3 sections. The wheel well, left of the wheel well and right of the wheel well.
The markings do peel right off. I have only removed them from my Alpha 60 but it is the same covering. Just use an exacto under an edge and it will peel right off. Good Luck!
Tim
Tim
