If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 104 of 119 FirstFirst ... 45494102103104105106114 ... LastLast
Results 2,576 to 2,600 of 2973
  1. #2576
    Join Date
    Oct 2002
    Louisville, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KMP / YT FW-190 Build Thread
    ORIGINAL: Mpizpilot
    Is the g-38 known to be hard to start? I've got one in another ESM plane that I'm getting ready to maiden. I've got no exp. with the zenoahs.
    Once you get the mixture correct ( start with 1 1/2 on each ) and the prop in the correct place, it can be hand started. I have a G-26 that CANNOT !!! All it does is pop but does not catch so I have to use a starter on it.
  2. #2577
    STICK MODE's Avatar
    Join Date
    Dec 2007
    BLENHEIM Malbourough, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: DougB1
    ORIGINAL: STICK MODE
    ORIGINAL: DougB1
    Got to fly my composite ESM FW190 today and it flew GREAT !! I have a G-38 up front and put the battery right behind the fire wall and it balanced right where I wanted it which was at 133cm. Even got the G-38 carb spot on and I can flip start it without an electric starter ( and it's a mag motor ) Have been working on it from last fall to early spring and the work and wait was well worth it.
    DougB1
    Doug im sure you meant 133mm if it was 133cm that would make it>>>>>> 1,330.0 Millimeters which would be about 4 inches past the rudder lol glad she went good for you mate enjoy cheers Frank
    Yes you are correct, it is 133mm I don't use that type of measuring very often and got it mixed up.
    Doug
    Its ok me and inches dont get on how does she fly Doug ive clocked up over 200 fllights on mine that elavator can be powerfull i backed mine of the recomended throws still a lovely plane to fly cheers Frank
    If the world should blow itself up, the last audible voice would be that of an expert saying it can\'\'\'\'\'\'\'\'t be done.\"
  3. #2578
    Join Date
    Oct 2002
    Louisville, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: DougB1
    ORIGINAL: DougB1
    DougB1
    Doug
    It took off straight down the runway, lifted off slowly ( I made sure it had LOTS of speed ) and flew very gracefully. I had to do 8 clicks of down trim and that was it. The first landing was with full flaps and boy does it slow down !! Did 3 flights on it and am looking for many more to come.
    Doug
  4. #2579
    Join Date
    Oct 2005
    Fresno, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I completed my ESM 71" FW-190 today - Hopefully, I will be able to maiden her tomorrow if the wind dies down a bit. Mine is powered by a PTE 36 and the engine sounds great. I'll keep my fingers crossed that things go well with the maiden flight.
    Best wishes and good safe flying - Heli-NuBee (Roger)
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1769597   Click image for larger version.
ID:	1769598   Click image for larger version.
  5. #2580
    Join Date
    Oct 2003
    Eindhoven, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Roger, she looks beautiful, good luck on the maiden!
    Doug, you mention full flaps. What is that, 60 degrees?
    Volkert
    Club Saito member #371
  6. #2581
    Redback's Avatar
    Join Date
    Aug 2004
    GraftonNew South Wales, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Roger,
    Good luck with the maiden, don't forget the report.
    Things to do afterwards:
    Replace tailwheel with Dubro semi-scale
    Replace shiny plastic spinner
    Get some filth and grime on the plane - it's waaaaay too clean
    Terry
  7. #2582
    Join Date
    Jun 2007
    Rio de JaneiroRJ, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guys, my plane is almost ready. But I’ll need to put some weight in front to balance the Center of Gravity.
    I’m using a DLE-30 engine and I was thinking on fixing some lead plates on the mounting bolts that fix the engine to the stands. Something like a half moon of steel and lead.
    Does someone have already tried this arrangement? Is this a crazy idea?
    Waiting to hearing from you,
    Arruda
  8. #2583
    Join Date
    Oct 2005
    Fresno, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    WOW!!! What a hand full! I maidened the plane but it was a bit scary. The elevator had a bit too much up trim on take off and the plane tried to snap roll, I came very close to losing it. Both the elevator and ailerons were to sensitive and that made the plane touchy. Landing was a son of a gun due to the sensitive controls and I came close to losing it again. I slowed down the elevator and ailerons but I also think it may still be a bit on the tail heavy side. I have already put two pounds of lead up front but I believe it still needs a bit more. I only tried the one flight until I add more weight to the nose. (I also needed time to clean my drawers after that flight but at least it is still in one piece.)
    Best wishes and good safe flying.
    Roger
  9. #2584
    Join Date
    Oct 2005
    Fresno, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK Guys, About the shiny black spinner, it is just temporary. I have had a black and white swirl spinner backordered at Troy Built Models for some time. When and if I receive the correct spinner, I will get rid of the shiny black spinner.
    Roger
  10. #2585
    Join Date
    Mar 2010
    Wading River, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I used the same idea, except did not mount the half circle shaped lead to the engine mountain bolts. Just mounted to the firewall.
  11. #2586
    Join Date
    Mar 2010
    Wading River, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Heli-NuBee
    Roger
    Scan back a bit in this thread and you'll see my maiden was exactly the same, very lucky to get it back in one piece. The cg and throws listed in the manual are waaayyy wrong. Once you get it where it should be,it's a great flying, solid feeling airplane.
  12. #2587
    Join Date
    Mar 2010
    Wading River, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My maiden flight sounds just like yours.
    ORIGINAL: Mpizpilot
    Successful maiden today! (Well sort of). Finally got around to putting the first flight on this bird and it was a complete handful. I've got to dial down my rates even farther and recheck my cg and it was waay tail heavy. Amost lost it on take off as it went almost vertical,then combined with the incredibly powerful ailerons and elevators it was the most stressful 9 minutes of flying I've ever done. It also didnt help that above the tree line the wind was so turbulent it would put the airplane on it side every time. I had actually consigned myself to the fact that the airplane was in the least going to be damaged,at worst destroyed, but somehow I was able to get it on the ground without a scratch.
    Can I ask what most of you guys are using for CG and throws again? I know its buried in this thread somewhere, but I'm just too burned out to scan through all this.
    There were a couple of positives though for sure, the DLE 30 does great in the plane and runs just fantastic. The ESM gear performed flawlessly and even absorbed my not so pretty arrival. I'm extremely glad I repainted the bottom of the plane as it really presented well in the air and made it very easy to see. I'm sure once I get it dialed in I'll be happy with it.
  13. #2588
    Join Date
    Oct 2002
    Louisville, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: wagen017
    Volkert
    I have about 45 degrees which slowed it down a lot. My balance point is at 133mm and was perfect ( this is the composite model )
    Doug
  14. #2589
    Join Date
    Oct 2005
    Fresno, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey mpizpilot
    As you can tell, my flight was also quite stressful. Take off and landing were unreal and just flying it was a real challenge. I was also fortunate not to lose the airplane on the first flight. Now that I reduced the control throws and will add some more nose weight, my next flight should be much easier.
    Roger
  15. #2590
    Join Date
    Mar 2010
    Wading River, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    130mm seemed to be the magic number for me concerning the cg. I was so scared to fly it again after the first flight, I wasn't sure I was up to it. The second flight was completely different.
  16. #2591
    Dowmer's Avatar
    Join Date
    Oct 2008
    Herndon VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I finally managed to maiden mine last week....well, sort of. It didn't end well due to my own stupidity and fat fingers.
    After all the normal checks etc I rolled down the runway. It started to pull to the left like I figured so I fed in some right rudder. Of course I fed in too much andover corrected to the right just as the plane was getting lift. I panicked, because it was heading for a marsh at the side of the runway and pulled backon theelevator. With the touchy elevator, of course if jumped off the ground before it was ready ( duhhh, heavy planes need speed) and wing tip stalled to the left and went down like a sack of bricks, breaking off the gear and a few scrapes. Definitely fixable but a bruised ego nonetheless.
    Lesson learned, Dont over correct (I know It won't be the last) and more importantly, keep the darn plane on the ground to build up speed!!
    Here's a couple pics before the mishap.
ID:	1769922   Click image for larger version.
ID:	1769923   Click image for larger version.
    Flying:
    ESM FW-190 D9 Bash
    Bendix Special
    MilPoke - Self designed Frankenplane
    Building - Scratch 1/4 Scale Travel Air Mystery Ship
    Golden Era Aircraft Brotherhood #23
  17. #2592
    Join Date
    Oct 2002
    Louisville, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What other sizes does the FW190 come in ( any mfg ) I have the ESM and would like to go bigger.
    Doug
  18. #2593
    kahloq's Avatar
    Join Date
    Jan 2006
    Fort Collins, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: DougB1
    Doug
    ESM also has a 50cc size 82.5" wingspan fw-190 d9
    If your looking for an Anton, well for arf's....there really arent any until you go really big....BUT....
    Airworld has an A version
    102.5" kit price for the arf $2200
    http://vogelsang-aeroscale.com/airworldfw190.html
    Petrausch 92.5"
    kit price 1995
    http://vogelsang-aeroscale.com/petrauschfw190.html
    Sist 82.7
    Kit price 1750(last I knew...these werent being made anymore..no idea if there are any in stock)
    http://vogelsang-aeroscale.com/sistfw190A1-5.html
    And the real low end non scale looking easytigermodels fw-190 ish something or other:
    95"
    price $995
    http://easytigermodels.com/index.php...products_id=91
    There are of course many kits(not arfs or even composite fuselage kits)
    Meister scale
    Platt etc
  19. #2594
    SimonV6's Avatar
    Join Date
    Apr 2009
    UK, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Starmer
    I finally managed to maiden mine last week....well, sort of. It didn't end well due to my own stupidity and fat fingers. After all the normal checks etc I rolled down the runway. It started to pull to the left like I figured so I fed in some right rudder. Of course I fed in too much and over corrected to the right just as the plane was getting lift. I panicked, because it was heading for a marsh at the side of the runway and pulled back on the elevator. With the touchy elevator, of course if jumped off the ground before it was ready ( duhhh, heavy planes need speed and wing tip stalled to the left and went down like a sack of bricks, breaking off the gear and a few scrapes. Definitely fixable but a bruised ego nonetheless.
    Sorry to Hear of your little mishap Jason, after all your great work on it
    I almost had the same mishap yesterday after taking off on a damp and mossy field, hit a bad patch near end of take off run that really held her back but had just enough speed to get it up before the hedge, but it was slow and all over the place, but got the gear up real quick and it stablised after that and she climbed away...but had my heart going lol...........landing was easier, as that side of the field was a bit drier, was thinking "nose over" here we come
    I actually ran the engine afterward thinking i had a low rpm or something, but no she was pulling like a freight train, so all down to bad grass field
    I wish the UK would start basking in some summer for a change lol
  20. #2595
    Ramstein44's Avatar
    Join Date
    Nov 2007
    Aurora, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: kahloq
    ORIGINAL: DougB1
    Doug
    ESM also has a 50cc size 82.5'' wingspan fw-190 d9
    102.5'' kit price for the arf $2200
    Petrausch 92.5''
    kit price 1995
    Sist 82.7
    95''
    price $995
    Meister scale
    Platt etc
    Dont forget,
    Bob Holman, Vailly Aviation, David Anderson, Don Smith designs and IMP. The most sale FW190 Anton is the Don Smith which were designed from Bently drawings.
    "IF" I'd stop staring at them, I'd get more done to them.
    Platt FW190, Holman FW190, Meister FW190, SIST FW190, TF FW190.
  21. #2596
    kahloq's Avatar
    Join Date
    Jan 2006
    Fort Collins, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Those are great of course, but are kits....not arfs. I do not presume to know what DougB1 was wanting...arf or kits.....I listed the arf's and composite versions I knew of bigger then this esm 71" version.......
    Thank you for expanding the list of those that are kit/plans.
  22. #2597
    Ramstein44's Avatar
    Join Date
    Nov 2007
    Aurora, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oh.. I didnt see from the way it was written that he was specific to ARF only and was like you, just adding to the kits per your last paragraph. Maybe it was the "any MFG" that threw me.
    The Holman kit comes with foam cored wings and glass fuse.. Considering all the efforts some place into the ESM FW190's, they could build the Holman better.
    Just an idea.
    I've noticed that Germany has all the best ARF's of the 190. I'm curently attempting to gain information on a very scale FW190 apparently only sold there and the UK[:@][:@]. Hopefully I succeed in obtaining one.
  23. #2598
    Join Date
    Oct 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How much expo are you guys running? I am now flying pattern and 60% or even more is not uncommon. This normally fixes problems with excessive throws.
    Volkert
  24. #2599
    kahloq's Avatar
    Join Date
    Jan 2006
    Fort Collins, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Ramstein44
    Yup, there are several over in Germany that arent available here. I forgot the company selling them, but could find ut if needed.
  25. #2600
    Join Date
    Oct 2002
    Louisville, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: wagen017
    Volkert
    I do not use expo in anything, UNLESS it is something REALLY fast ( 100mph plus ) then it is about 25-35 percent. I myself like to feel what the plane is doing when I move the stick the slightest. I have flown this way for years but not to say it is the correct way but the way I have learned. I think it is how a person can put the inputs in and feel comfortable with their model.
    DougB1
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
