If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 108 of 119 FirstFirst ... 85898106107108109110118 ... LastLast
Results 2,676 to 2,700 of 2973
  1. #2676
    STICK MODE's Avatar
    Join Date
    Dec 2007
    BLENHEIM Malbourough, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: KMP / YT FW-190 Build Thread
    Mine with a Saito 170r 2 half pounds +2 batterys both 4 cell hydra max 4200 mah weighing a pound between them placed hard against the inside fire wall on board glow driver placed hard against fire wall all up front weight over 4 pounds RESULTS = to date 176 flights no prangs clean undies and heaps of fun
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    If the world should blow itself up, the last audible voice would be that of an expert saying it can\'\'\'\'\'\'\'\'t be done.\"
  2. #2677
    j301's Avatar
    Join Date
    Feb 2008
    Mesa, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: STICK MODE
    ... no prangs clean undies and heaps of fun
    I can't think of a more poignant endorsement than that! Think I will have to start planning a build, always liked the 190, was one of the first air frames that came to mind way back when I got interested in the hobby, guess its finally time.
    ARF\'\'s; because it\'\'s less depressing to take out a box of plane and bring back a box of sticks.
  3. #2678
    Join Date
    Oct 2003
    Eindhoven, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Build up wing for me. The Laser fits perfectly in the cowl.
    Volkert
    Club Saito member #371
  4. #2679
    Join Date
    Feb 2006
    camden, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bump
    Michael.M Waco brother #187
    P-47 Brotherhood #22
    And Certified Warbird Nut
  5. #2680
    Join Date
    Oct 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bump is good. I have got this plane ready to go but the weather is COLD! No flying for now until March!
    Volkert
  6. #2681
    Join Date
    Feb 2006
    camden, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mine is almost ready. I have a dle30 in mine and am just setting the cg. I am going to set it at 130 for the first flight. 2 questions, first what did yoursnd come in at weight wise. Mine looks to be in the 16.5 pound range. And where are you measuring the cg from. The flat part that meets the fuse or from the wing somewhere. I have mine set from the fuse i just want to be sure
  7. #2682
    Redback's Avatar
    Join Date
    Aug 2004
    GraftonNew South Wales, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    See page 13 of this thread for a picture of how I measured the CG on my first (all composite) one. This one weighed in at about 17.5 lbs (built up wings are lighter), I was a tad nervous on the first flight but it flew OK.
    This one had a 120AX in it, enough power but took a truckload of weight to balance.
    Terry
  8. #2683
    F82FAN's Avatar
    Join Date
    Jul 2002
    Conroe, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, after several YEARS of fiddling around my composite version is about ready for its maiden...
    Its got Sierra Gear, an Evolution 35cc motor and a bit of a different paint scheme that I will post before first flight.
    Hope all of those birds are still crankin well!
    HANGAR.... YOU KEEP PLANES IN THE HANGAR!!!!
  9. #2684
    Join Date
    Oct 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Today I maidened my Rote-13 FW-190! I changed the yellow-11 to a red-13. It flew great I must say. Being somebody used to lightweight pattern planes I wondered how it would go but the plane gives good indications when airspeed stars to get too low.
    Mine flies with a Laser 200v twin which runs a 18x8 APC. I balanced it at 130mm and total weight is 7.3 kg. For retracts I use v2 ESM retracts with a Lado RS666 actuator.
    For landings I use 60 degrees flap and it really slows down well. I need to fly her in with power.
    Volkert
  10. #2685
    kahloq's Avatar
    Join Date
    Jan 2006
    Fort Collins, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice
  11. #2686
    Join Date
    Oct 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    let's see I get some pictures uploaded; I haven't used my computer for a while!! iPad everytime nowadays...
    So next time I will have the motorhood on as well. It was now suggested by Laser to leave it off for those first flights.
    As you can see I changed the look a bit, it is from the famous ace Heinrich Bar. Interesting guy, not only a top ace (also on the western front!!) but he was actually degraded from major to soldier in 1944. Later re-instated and became a Me262 ace as well.
    http://en.wikipedia.org/wiki/Heinrich_B%C3%A4r
    Volkert
ID:	1858854   Click image for larger version.
ID:	1858855   Click image for larger version.
  12. #2687
    Redback's Avatar
    Join Date
    Aug 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Has the classic ESM FW190 signature, a ton of lead in the nose!!!
    Looks like your local church might be short of some roofing!
    Terry
  13. #2688
    kahloq's Avatar
    Join Date
    Jan 2006
    Fort Collins, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Redback
    Terry
    Has nothing to do with being an ESM plane. Any model of a fw-190 A will require a snit load ofweight up front. The giant size topflite is no different and they even include weights in the box.
  14. #2689
    STICK MODE's Avatar
    Join Date
    Dec 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Terry That might have been some of the lot i sold of the Sydney opera house[:-]
  15. #2690
    Join Date
    Oct 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Redback
    Terry
    Yep, the church is complaining but hey, it is for a good cause! :-)
    There is 1200 grams there, will loose 300 gr when I mount the motor hood. I took my CG quite conservative at 130mm, so probably could loose more, however I prefer good flying.
    I will do the gram-saving excersizes on my pattern planes!
    Btw, in a sense it is completely logical, if ESM tries to build planes scale-like, you must have weight in the nose. In real life, these planes weren't much more then some wings strapped to an enormous engine and a couple of guns.
    Volkert
  16. #2691
    Join Date
    Dec 2001
    Yuma, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My ESM 72" FW will be here in a couple of days. I have a couple of questions for you.
    The ESM electric retracts are out of stock and I'm looking at alternatives. Would be interested in what any of you have used besides ESM?
    Second question - are the main gear 80, 90 or 100 degree actions. thanks.
  17. #2692
    kahloq's Avatar
    Join Date
    Jan 2006
    Fort Collins, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have the esm 72"...it has the esm gear installed...however...its the pneumatic versions. The angle is certianly NOT 100 or even 90. Its a decent inward cant as it should be, just no down locks...probably around 80 degrees. The real plane would have 74 degree gear. Sierra giant makes gear for this size esm plane as well as the larger 82.5" 190 d9. For scale...get the sierra giant and the angle will be a bit better(more inward cant. Note the 2nd pic...its the larger d9 with the sierra gear.
    These are the sierra gear you would want:
    http://www.vqwarbirds.com/product_in...f0efc87c61367d
ID:	1859386   Click image for larger version.
  18. #2693
    Redback's Avatar
    Join Date
    Aug 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Splais
    I'm between ESM 190s at the moment[:@] I have a broken one and a new one wating to be assembled!
    I have Sierra pneumatic retracts in both the 190 (happily they survived the crash that followed an engine problem) and in my Bf109. Like most users I have found these to be very reliable.
    Stick mode,
    Sure it wasn't off Chch cathedral[]????????
    Terry
    Terry
  19. #2694
    Join Date
    Dec 2001
    Yuma, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've had Sierra's before and like them. I've been thinking about Sierra's and getting them converted by Down & Locked, to electric. I've also talked to Robart and they have electrics that will work also. Decisions, decisions.
  20. #2695
    Join Date
    Oct 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    74 degrees Lado retracts
    http://www.lado-tech.net/en/rs333/2-rs333-74.html
    You need to check if the suplied legs are correct for a 71" plane though. I am only using the actuators of Lado in a ESM set.
    Volkert
  21. #2696
    Join Date
    Dec 2001
    Yuma, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Still have to order standoffs for my engine. If you have a DLE30 on your FW, could you tell me how long your standoffs are? Thanks.
  22. #2697
    Join Date
    May 2004
    san francisco, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: splais
    I got mine from these guys http://pspmfg.com they work well do you have the side mounted carb or the rear mount I did the conversion on my engine when the new manifold came out
  23. #2698
    Join Date
    Dec 2001
    Yuma, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have the same engine you do and both the side and pitts mufflers. Haven't decided which to use yet. it looks from the picture you have doubled up the standoffs. what is their total length to get the cowl-prop spacing to come out correct? Also, how much, if any weight did you have to add for the cg. thanks, Steve
  24. #2699
    Join Date
    Jan 2012
    Roumieh, LEBANON
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a DLE 30 on my ESM. I used a 7cm standoff to give some space to the carburator. You have to use a pitts muffler as the standard DLE muffler will restrict the installation of the cowling due to the engine width with muffler installed. I used a lot of weight to balance but I tried to place them as far forward as possible.
  25. #2700
    Join Date
    Dec 2001
    Yuma, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    mcn, what prop to cowl spacing did that 7cm standoff give you, maybe even got a pic.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
