3W F8F Bearcat Need Help...
#51
RE: 3W F8F Bearcat Need Help...
Hii propwashed,
ah now I got it. You mean the former for tank, smoke and pneumatic. Of course you can have it, but do you have the right dimension of those bottles, you need?
Cu,
Eric
Cu,
Eric
#55
My Feedback: (10)
TX
I just tried to put a DA 150 in the nose and the plug caps rub badly.
The 3w 150 plugs do not rub.
Go figure?
This is a heavy plane so I have an RCS (Moki) 250 on order to put in it.
Banker
Go figure?
Banker
#60
Hello John , Erich, Banker, Brink, propwashed and all of you Bearcat afficianados. Thanks for the advice re: radial vs opposed twins etc. I agree . Just need to know the max width I have to work with. Can I get 12 3/4 inches? Being an old Navy jock I have some recip time to go along with the turbine time. Nothing sounds like a big radial. I was treated to an air show by Bill Fornoff with his Bearcat back in the sixties. First maneuver was an immelman (sp) on tkof. WOW.
I sure like the way all of you are sharing info and helping each other with your projects. Hope some one will slap a ruler on that baby for me. Thanks guys --Ad Clark
I really need 12 3/4 inches!!!
#61
My Feedback: (10)
TX
My firewall is exactly 13" wide (looks like Tobbe's on the first page of this thread).
Just for the sake of clarity, the caps on the DA 150 fit but they rub and would eventually rub through.
Go with the radial.
Erich: How much does yours weigh? I can get hold of a used 215 reasonably cheap. Was wondring if it would be enough versus the 250.
Mine weighs right at 50lbs.
Go with the radial.
#62
Banker-- Thanks for the info. I will have to build one of these and wil be watching this thread. Any one having cooling problems, are they opening up the cowl flaps per scale? Any beefing up reinforcing the glass etc? Are you folks using Seirra retracts? What engine were you using to get a weight of 50 lbs and is that wet or dry? Thanks, Ad
#64
My Feedback: (10)
TX
Ad:
Check out this thread: http://www.rcuniverse.com/forum/m_58...tm.htm#5853947
Read the post by ww2birds. He has helped me.
My weight is dry.
RC Showcase recommends baffling the radial engine for cooling.
Prop:
I was wondering whether a 215 would pull the 50lbs.
My weight is dry.
Prop:
#66
My Feedback: (14)
I see that my Bearcat was featured in the article on Warbird Flying in the most recent Model Airplane News! Too bad Rich did not have info on the owner, it mentions my engine (incorrectly) as an RCS 215 .. it's really a 250, and does not have my name on it .. sigh.
But .. really .. how cool is that!
Really really nice picture of the B'Cat on final though :-)
Dave McQ
Dave McQ
#67
Hi banker,
the exact weight of my bearcat is about 19,6 kg---> 43,2 lb, dry. The power with the 215 is really enough. I have also a Solo Prop 28x20 on it.
Eric
Eric
#68
My Feedback: (10)
Eric, do you know anything about the Bearcat shown inthis video: http://www.myvideo.de/watch/1207519
Owners name is Thomas PfĆ¼ller. I am interested in what size Moki he is using and the size of the prop.
Thanks.
Jeff
Thanks.
Jeff
#69
Hi Jeff,
I know him very good. He is a friend of mine. He uses the same parts like me. A 215 radial and a Prop from SEP (germany). The size I donĀ“t know. I have to ask.
Eric
Eric
#70
Hi Erich-What is your firewall made of & what is the distance it comes out for the prop to clear? Do you sell firewalls or could I get demesions on it from you ? Thanks "Brink"
#71
Dave -Saw your plane in RC Report w/your picture. Were you able to shoot some interior pictures
of your bearcat. Iam still waiting on mine from cactus aviation!!! "Brink"
#73
Hi Brink,
IĀ“m sorry, I donĀ“t sell firewalls. Mine is the original from the Fw190 from Airworld. It is made of fibreglass. But I have to say that this not my 100" recommendation. The firmness is not really good.
There is a second photo (friend of mine). That is a better version. Just have a look. It is made of plywood (4mm) and covered inside and outside with fibreglass. That works reliably.
Cu,
Erich
Cu,
Erich
#74
My Feedback: (14)
Hi Guys,
Here are the pics of the interior setup on my 3W Bearcat. Not the most "sanitary" install you'll see, but fuctional.
Using separate servos for tailwheel steering and rudder (so that I can mix a lot of tailwheel steering at low throttle, minimal above 1/4 throttle).
Futaba MSA-10 (like a Matchbox) for the two elevator halves mounted on the rear "shelf" in foam (was set up before I had the 14MZ in the plane .. would not need it now!)
Front two servos with CF pushrods are throttle (on top of picture) and choke.
Rx antenna runs in an outer nyrod back toward the stab inside the fuse.
50 oz fuel tank and 24 oz smoke tank with Don Harris pump.
Dave
Dave
#75
Hi Guys,
here I have a little video from my Bearcat in action. The quality is not really good, what shells...
[link=http://www.youtube.com/watch?v=UozgxzW1-ik]Bearcat in action[/link]
cu, Erich
cu, Erich
