vailly FW-190 flys
TX
190a
Longeze, Please tell me you are gonna bring it to the austin warbird show at the end of april! I would really like to see it.
I plan on bringing the hangar and doin some warbird flying. Hope to see you there.
EvanQ.
EvanQ.
vailly FW-190 flys
Are you using the cooling fan and is the 3 blade prop static?
I have one of these on the back burner in my basement. I have every thing for it. I should get it done now huh?
Can you tell us anything about first flight character performance?
How was the takeoff? Landing? Did you use full flaps? How much does it weigh? If you could do it again, What would you change? Sorry about all the questions...
Kirk out
Kirk out
My Feedback: (9)
TX
vailly FW-190 flys
Yes, am using the cooling fan but the 3-blade is my static prop. The prop im flying with is a mejzlik 22x10. Takeoff was strait down the runway without use of rudder, I set up my alignment to roll slightly right. The planes tail came up and didnt rotate till I gave elevator (very-nice). Stall tests were done imideately at altitude with gear down and full flaps with excellant results, so first landing was set up this way. Landing was very scale like and nice.
Glenn
Glenn
My Feedback: (9)
FL
vailly FW-190 flys
Glenn
Glenn
What does it weigh, and how much nose weight did you need?
IL
vailly FW-190 flys
AWESOME!!! Can't wait to start mine, do you know where i can get the static prop blades? Roy doesn't make them any more..Thanks Vic G. Again totally awesome!!
