Roundels
Roundels
Here’s a question for all those historians out there.
As I look at a photo of a WW2 Spitfire I can see the Wing Roundel with a Red Centre and the Outer Ring is Blue.
But on the Fuselage the Roundel is Red Centre, White Ring, Blue Ring and then a YELLOW ring.
Why is there a high visibility Roundel on the Fuse and a Low Visibility on the Wing?
For that matter why are there Two types of Roundels?
RE: Roundels
My guess is there was a war going on and the enlisted man assigned to paint the roundels wasn't a historian. But then, I am sure someone like FT can come up with a very technical reason as to why with documentation and letters from the war department to support the hypothesis.
I still have a gallon of "PRU Blue" that was custom blended for a Spitfire if anyone is interested.
By the way, were all Spits painted that way?
RE: Roundels
It simply became a matter of recognition. One issue of the Spit was that it resembled the 109 from a distance. The leading edges of the Spit wings were painted Yellow for the head on view and the Fuse sides have the Yellow surround on the Roundel.
The Spit is not the only aircraft to carry these markings. Most of the RAF aircraft carried similar markings.
These markings evolved as the war progressed to help better distinguish the RAF A/C from the Axis planes. There are other markings that were also changed after the invasion of Normandy because the aircraft were now stationed in the Continent and as such were volunerable to attack from the air by the Axis planes.
My Feedback: (7)
FL
RE: Roundels
The markings changed often from 1936 to 1945. It had little to do with just the Spitfire. The Markings were made for general use with sizes and placement designated by the authorities.
Here is a page of raf roundels and placement from 1939 to 1945 plus a few later ones.
http://www.homepages.mcb.net/bones/0...F_ROUNDELS.htm
Good Luck
Paul
Good Luck
Paul
RE: Roundels
ORIGINAL: dragoonpvw
So what you are saying is they changed the style of Roundel as they saw fit for virtually every aircraft.
Scary... Thanks for the link it was great - the mind set of the Brits is another matter...
My Feedback: (60)
AZ
RE: Roundels
ORIGINAL: bbbair
Wow!
Wow!
My Feedback: (7)
FL
RE: Roundels
ORIGINAL: bbbair
Wow!
good luck
Paul
RE: Roundels
Paul;
Sorry about the Flippant remarks – bad habit.
Yes; we do tend to forget just how ‘Young’ the Air Plane was in WW2 and that both the planes and their strategy were still evolving.
As we look at AC today we tend to think of mass production and uniformity, so when I look at the many variants of a very simple design – it just makes you wonder “Just WHAT IS GOING ON??”
Your documentation and explanation of the subject has answered many questions for me. Thank You!
