Flying Styro Kit FW 190
NY
Hi,
I got a Flying Styro Kit FW190 for christmas. The plans call for a speed 300 motor and a 7.7:1 gearbox. Is this a good set up? Or what else has been used? Thanks.
Steve
Steve
RE: Flying Styro Kit FW 190
Steve, use the setup with the axi and lipo from hobby-lobby. It performs much much better.
Be sure to get the angle of the prop right and it will fly very very well
I miss that model [&o]
Stian
Stian
ORIGINAL: SteveKremer
Which AXI motor do you propose? Do I need a gearbox?
Steve
Steve
I had the 2212/34 but when I saw how much higher speed and unlimited vertical an Alfa or FSK can fly with a 2212/26 I sold it. The 34 was very good when there were 6-8C Lipo and the 3 blades FSK prop.
The prop is to be mounted pointing 1-2 degrees to the left and 1-2 degrees downwards. When I built it I glued in the firewall correctly, I thought.. But i turned out the cutout at the nose was cut angled and so the firewall ended up pretty straight. This gave me a yaw to the left and up when accelerating and I could never trim it correctly to have it fly straight.
You need to glue in the firewall ( with a small plywoodplate to cover the cutout for the 300 motor) angled left and down and you need to assure youre measuring from the right place.. one of the panellines in the nose instead of the nose itself. Be very careful at this and double check as it will be glued permanently and flight behaviour will depend on it Don`t use 5min epoxy as it will cure to quickly for you to position correctly in time.
Stian
Stian
