spring air nose gear problem ?
My Feedback: (15)
Cant seem to keep my connection on my nose gear from binding when retracted . First I used a simple clevis , then I used an "L" bend with wheel collars , any suggestions , its wants to turn when retracted and tend to bind up as opposed to simple moveing smoothly up and down
My Feedback: (15)
RE: spring air nose gear problem ?
I actually fixed mine in a differant manner . I simply use a L-bend , with two wheel collars on each side .Then I realized that the pushrod guide needed to be glued in a secure manner near the turning mechanisum , once I did this , no problem at all 100% retraction with zero binding
