Sig P51B electric + build + maiden
#102
My Feedback: (31)
NJ
RE: Sig P51B electric + build
Is there a way to get 2 blade performance out of a three blade set up? I am willing to adjust motor size. I flew a couple 60 size fighters on a YS-110 and they hauled butt. I know it won't be a scale prop size but i need the speed and the scale appearance. Just me....
#103
CA
dbateman-
I think your up against the laws of physics, so the straight answer is simply no. (A one blade prop would be the most efficient.) That said, you can add more power to a 3 blade prop and get your desired effect of scale look and no loss of performance (thrust). That's tricky, but we've done it on these war-bird models. Jeff and I have used 3 blade props in a 16x10 size/pitch, powered with an Eflite Power60 brush-less motor on a 6-cell, 5000mAh LIPO pack with a Castle 80amp ESC and it hauled a 8-10 pound Hangar9, Top Flight or SIG .60 size warbird around quite nicely. Some of our Scale Master friends have even tried 4-blade props, but many fly two blade 16x12 props and switch to a static prop for display and judging. After that motor has spooled up and the prop is spinning, blade count is harder to tell, but performance sure isn't. With the electric conversion you've outlined, at least you'll be able to swing a larger diameter prop then some of those funny looking glow/gas props.
stalkmoe
stalkmoe
#105
My Feedback: (60)
AZ
The P-51B used a four bladed prop so three blades is still not scale. Better in my opinion to run a larger diameter 2 blader which looks more scale in flight anyway due to the larger prop arc. That's just my .02 cents of course.
#107
My Feedback: (60)
AZ
ORIGINAL: dbateman
Some early models ha d a three blade prop. There is a combo that will fly a 60 size warbird like it had a YS 110 in it. I just have to find it.
Only the Allison powered versions, i.e., the P-51, P-51A, A-36 had the three bladed props. The B/C model Mustangs (such as is the Sig ARF) have the Merlin engine up front and were only operated with a four bladed prop. The noses are substantially different between the two engines. Just FYI of course as none of this prevents you from running a 3-blader on your Mustang if that is what you prefer.
Allison engine P-51A
Merlin engine P-51B/C
#109
CA
You get some much more performance with the two-blade using the Power 60. I wouldn't use the Power 90 as it adds too much weight for this plane's frame. You can get the same performance with the 60 if you use a two blade. If you want scale then just swap the prop when you land for static display.
Jeff
Jeff
#110
CA
Jeff is correct, but I will tell you my experience with a Power90. I read an article sometime ago online from RCGuys... I think. They had "hopped" up the hangar9 .60 size Corsair with the Power90, an 85HV ESC from Castle powered by 8 cells (Two 4cell Thunder power 5000mAh packs wired up in series). You can Google it and still find the article. I built up the same configuration in my Hangar9 Corsair, and in fact Jeff maidened it for me. It does fly faster (it has a 3 bladed prop 16x10), and also weighs more. Of course each flight takes two batteries- not a huge deal really. I still have it, but seem to fly my standard .60 size Hangar9 war-birds more often. It is a viable route to take in your quest for scale prop and more performance. Good luck, let us know how it goes.
#111
CA
Thanks for those great picts Chad- hadn't seen an early A or B model until last years Reno Air races- Polar Bear flew in as a static display- sure enough...3 blade prop, so that was the Allison engine then?
#112
My Feedback: (60)
AZ
ORIGINAL: Stalkmoe
My pleasure Stalkmoe. "Polar Bear" does indeed have an Allison engine up front. That particular P-51A was recovered from a mountain side by "Moon Spillers" and restored way back in the early 80's if I remember correctly. It is something of an oddity among Mustangs in that it contains many P-51D components which are quite different from the original P-51A parts so it does not really accurately represent any Mustang ever built by North American. It is still beautiful to look at and most people don't know, or care, that it is not original.
#115
My Feedback: (31)
NJ
ORIGINAL: 800mZero
could always put a power 110 in it on 8sworks great for me.
Is that what's in the Mustang shown?
Doug
#116
RI
hanger 9 60 sized blue nose
power 110
Ice 100 ESC
2 4s 4000mah lipos flightmax
APC 15.5X12X4 prop
1950 watts WOT
Between 60-70 amps WOT
She ways twelve pounds and hauls booty at half throttle-I use 3/4 for high speed passes.
And yep thats the mustang shown.
power 110
Ice 100 ESC
APC 15.5X12X4 prop
1950 watts WOT
#118
RI
it does well on 4 blades! it has a larger amnmount of p factor obviously so takes offs and landings are fun but she really scoots with the four blade. On the sig where you have the extra wing spani would run 5000 mah batteries-I had to go 4000 to keep the weight down. which in long run gives me about a 6 minute flight.
And thank you on the paint scheme, she is painted as my uncles plane was that he was shot down in 3 days before the ened of the war.
