Sea Fury 3 views
Banned
Sea Fury 3 views
G'day guys,
I need to locate a suitable access hatch location on the Sea fury that I putt switches etc behind.
was wondering if anyone has a suitable 3 view that shows these?
thanks in advance
cheers
PEter
thanks in advance
cheers
PEter
GA
RE: Sea Fury 3 views
These might help dont know if they are detailed enough though http://www.the-blueprints.com/index....-h/18331/view/
http://www.the-blueprints.com/index....-h/18330/view/ http://www.the-blueprints.com/index....sa/22722/view/
Banned
thanks for that, there looks to be a panel either side just up from TE of the fillet, that should do nicely to hide a couple of switches
cheers
Peter
cheers
Peter
This site has several very good drawings of the Tempest and other warbirds. There are profile and cut aways. The only problem is that they are in zip files. I have not had any problems with viruses from the site.
http://www.airwar.ru/other/draw_fw.html#4
CA
Hello Peter OZ,
I was wondering if you have the Top Flight Sea Fury? My wife bought me one for Christmas. I am going to get started on it as soon as I finish my son's Tiger 60. From what I have read on here, the kit needs alot of nose weight to get the correct CG. I was planning on glassing mine (first attempt at glassing) but thought that might add more weight to the tail. It will be several months before I have to make the decision. If you don't mind, any thoughts/suggestions would be great.
Pete
Pete
Banned
mate sorry no mine is the Vailly 90" version.
Glassing if done correctly add about a poothteenth of a bee's dick in weight.
Have you built the tail feathers yet? If not suggest you lighten them by drilling holes through ribs etc to reduce excess weight.
Have a look in the Corsair threads as several of the guys there used that technique.
Good luck
cheers
Peter
Good luck
cheers
Peter
CA
"poothteenth of a bee's dick"
A WHAT!
Thanks for the advise. Haven't started anything. Just opened the box at Christmas to look at the directions and ALL THOSE PIECES! I am in for some fun. rally want to try glassing, panel lines and maybe even rivets,...........maybe. I will check out those Corsair builds. And I am sure I will have a lot of questions to post when I get started.
Thanks again,
Pete
A WHAT!
Thanks again,
Pete
