nitromodels p-38 with 55.1 in wingspan
i would like to know i got a nitromodels p-38 lighting arf airplane with the 51.5 in wingspan i did not get the instruction manual and would like to know if anyone knows the center of gravity of the plane is and the throw on the ailerons and elivator low and high rates
thanks
thanks
FL
RE: nitromodels p-38 with 55.1 in wingspan
eadao, CG is 76 mm from LE up next to the center gondola.
Throws are as follows, NONE LISTED IN THE MANUAL.[:@] If memory serves me I had ailerons set at 3/8" and rudder and elevator at 1/2", on mine. Mine was equipt with retracts, which cleaned it up in flight, you may need to adjust for the gear drag if you used the stock landing gear. Very nice flyer.
Brad
Brad
