FlyBoyshobbies Me162 & Blohm & Voss 141
Reply
Old 01-16-2011, 11:27 AM
  #201
tmaucher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FlyBoyshobbies Me162 & Blohm & Voss 141
Just got the me163 Im reading all the stuff and most say to change the cg to 6.25" at the wing fuse meet. is that about right. Im thinking that the os 55ax might have a new home. but I might even go with cheap hobby king electric set up< not sure but should be fun this spring. thanks
tmaucher is offline
Old 01-17-2011, 04:42 AM
  #202
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine is still flying at whatever CoG I had previously posted on this thread
I like mine being electric, and your right about the cheapness of the setup. I had been flying with 5000mah 5 and 6s setups but i recently have aquired 3600mah li-pos that will be heaps better. I don't need 30min flight times and I would like to see how it performs at the lighter weight.
dave
ticketec is offline
Old 03-07-2011, 07:49 AM
  #203
BIKERIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's pic's of mine, hyperion Zs 4020-8 on 4S batt, 71 amps, 950 watts, flyes Great!!
ID:	1574782   Click image for larger version
ID:	1574783   Click image for larger version
ID:	1574784   Click image for larger version
ID:	1574785   Click image for larger version
ID:	1574786   Click image for larger version
ID:	1574787   Click image for larger version
BIKERIDER is offline
Old 03-07-2011, 12:46 PM
  #204
kahloq
kahloq's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Put a little dubro plastic spinner on the front and it'll really clean up the airstream. I did one with german esque black/white half n half.
Here's mine in flight. 5s 5000 on a turnigy 500kv motor with 14x10 apc prop
kahloq is offline
Old 03-07-2011, 02:32 PM
  #205
BIKERIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I left the spinner off because the front cowling is my only cooling inlet at the moment, I also
have 3 add. 3/4 in. holes in firewall to allow air to electronics, works well my batt. was barely
warm after 6 min. flight. I used dubro 4in. light wheels works better on grass, gear drops
nicely, CG at 6.25in and most settings as mentioned in this thread, flyes Great!!.
More details:
RTFW. 7 lbs.
Hyperion ZS4020-8/777kv, apc 13X8 prop(950W@71A)
ESC 80 amp exceed/opto
Batt. 2ea. hyperion in parallel 4S/2500/25C(5K)
2.4 Spektrum, Hitec 605 servos, 2s 800mah receiver batt., castle BEC.
Also incl. pick of my other German plane!!
Later, Allen
ID:	1575000   Click image for larger version
ID:	1575001   Click image for larger version
Old 03-07-2011, 02:38 PM
  #206
kahloq
kahloq's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What I did for cooling air was put 3 small airscoops on the nose bottom section in the silver area and color matched them. I wanted the spinner in place myself, because I could see that in the air whereas the little scoops are invisible.
With the 5s 5000 I get about 12 mins
kahloq is offline
Old 03-07-2011, 02:53 PM
  #207
BIKERIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm looking for a alum. spinner, don't trust plastic as motor rpm's are 10k+, I saw pics of
your scoops on this thread, I might try that.
Thanks, Allen
Old 03-07-2011, 03:32 PM
  #208
kahloq
kahloq's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I havent had any issues with the dubro spinner at all.....but...my power setup isnt any where close to 10k rpm's ...much closer to 7500 loaded with the prop on it.
Your 777kv motor on a 4s battery is turning 12k UNLOADED, but with a prop on it, its considerably lower.....but still probably 9000-9500. I dont fault you for being carefull. You can get an aluminum spinner from dave brown in the size you need. Go to dbproducts.com..much cheaper then truturn and they are just as good.
kahloq is offline
Old 03-13-2011, 02:59 PM
  #209
BIKERIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More pics, flew today at CG setiing of 6.25 in, flew great with 3/16 in reflex on the
elevons, no add trim!!.
ID:	1578248   Click image for larger version
ID:	1578249   Click image for larger version
ID:	1578250   Click image for larger version
Old 11-03-2011, 03:14 PM
  #210
BIKERIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well it's been a great summer, well over 50 flts on the komet, no damage, a few broken props!!, installed gyro on rudder, use gain mode for takeoff only,
off in flight, set at 80% gain takeoff a lot easier, also installed a dubro servo saver(springs) on rudder pushrod at servo arm, saves the servo gears on
rough landings, flew it 5 times at EWEEK(Triple Tree Aerodrome/ AKA Joe Nall field), was able to make long aproach and tailwheel 1st landings, that field
is so smooth, the plane slid another 30-50 feet after landing, I also installed heavy duty urethane tape along skid to protect paint and large dubro wing
skids, no damage on landings, even at rough fields!!, I'm attaching video of one of this summers E-fly-ings, this field was rough tail bounced a lot, but had
a great time!!, timeline 7:50 takeoff, 8:35-9:00 some passes and landing.
I like this plane so much, I have a second one sitting in shop!!, it will be recovered/painted in the RED version with more power!!, BTW the 1st one was
speed gun tested at 80mph on level pass with 8 mph crosswind.
Keep them flying, Allen BTW Texas RC dorpped the price on these
Video http://www.youtube.com/watch?v=M52f9mcxiTA
Old 11-22-2011, 02:01 PM
  #211
mogge
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got mine today, good shape, from Texas RC Planes. Lots of good advice in this tread, let see how I do. ;-) Start sourcing parts tonight.
mogge is offline
Old 01-10-2012, 01:55 PM
  #212
BIKERIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This thread kind of died, I'm still quite excited with this plane, I started the build of the red version(paint fuselage, recover wings),
got the wings done, still sanding on fuselage, it has a very hard clearcoat.
Going with the new E-flite Power .52/590KV, max amps 65, max watts 1650, tested with APC 12X6 on 6S/40C ,1375WP, 61.17AP,
I think it will have plenty of power!!.
Allen
ID:	1712482   Click image for larger version
ID:	1712483   Click image for larger version
Old 01-10-2012, 02:34 PM
  #213
mogge
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey all,
Thread's not dead. I have completed mine thanks to all the build tips and will balance it tonight. I will post pics as well. I am excited, this should be a fun plane.
Mark
mogge is offline
Old 01-10-2012, 04:49 PM
  #214
kahloq
kahloq's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: BIKERIDER
Allen
Mines running a 500kv motor on 5s with a 14x10 apc. Your may find it hard to break ground using a lower pitch prop such as a 6 and the thrust generated by a 12 diameter may not help matters either. This plane requires a snot load of thrust PLUS reflex on the elevons to get it to leave the ground along with usually holding full up elevator. Once in the air though, it'll fly fine, even at half throttle.
kahloq is offline
Old 01-11-2012, 04:25 PM
  #215
BIKERIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: kahloq
Quote:
ORIGINAL: BIKERIDER
Allen
That prop/battery combo was only a "test", all I had on hand was 4S+6S batt's, it felt a lot more powerfull than my other Komet setup, wich is aprox 1000WP on new 4S/30C/5000 batt.,
I usually ease the power in while holding full ellevator and come of the ground at 3/4 throttle with no issues, I found that full power takeoff induces quite a bit of torque roll, plane would
roll almost 90 deg.!!, I also use high rates for takeoff/landing, the controls get weak if you don't, it takes longer to get airborne than my other planes, but i have aprox. 800ft, another thing
I noticed is that the gear falls off immediately with this technique, I had the gear hang up several times on full power takeoffs, required reducing speed and pushing nose down to drop.
I'm going to try a 12X8 and if it stays around 70 amps(75 burst) static, I'll use it. The 12X6 will have more static thrust, 12X8 more airspeed.
WKYP, Allen
Old 01-13-2012, 04:11 PM
  #216
BIKERIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the video link on post #210 around 7:50 time, you can see that the field was a little rough/bumpy, making it hard to keep tailwheel down as there is
no way of holding the tail down, because you need some speed for the elevons to start working!!, I was going to turn around for a second try, but when
they called "landing", I decided to get in the air fast, full up and full power, you can see the resulting torque roll in a split second, fortunately this had
happened before so I was ready, at my regular flying field is non issue, is very smooth and 800ft, so I can make a longer takeoff and apply power
slowly, with better results. My rudder gyro set on gain holds plane fairly straight, I turn off IMD after takeoff.
Allen
Old 02-14-2012, 10:28 AM
  #217
Herb H
Herb H's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wanted to thank all that provided very useful info here on the FB / BH / TX / CY Me-163 Komet arf !
It flies very well, quite docile, almost like a nice glider
Here's a video of mine (second flight, after maiden earlier in the day), more details & pictures under my blog ("Herb") on RC Groups . Thanks again!
http://www.youtube.com/watch?v=p15-OaaBLUE
ID:	1726990   Click image for larger version
ID:	1726991   Click image for larger version
ID:	1726992   Click image for larger version
ID:	1726993   Click image for larger version
ID:	1726994   Click image for larger version
ID:	1726995   Click image for larger version
ID:	1726996   Click image for larger version
Herb H is offline
Old 04-15-2012, 01:40 PM
  #218
tmaucher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Herb H
Here's a video of mine (second flight, after maiden earlier in the day), more details & pictures under my blog (''Herb'') on RC Groups . Thanks again!
Whats the deal with the real small tires on the carriage?
tmaucher is offline
Old 04-15-2012, 01:56 PM
  #219
tmaucher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have began to trick the cockpit out a little, nothing to fancy just a pilot and a picture of the original cockpit , like was done before. I need to figure out the cover over the bullet proof glass? It really seems to be a major characteristic of the original and will help appearance from a short distance. Thanks to all for the help . I might just try the rocket motor, but at the same time I am thinking about just using some kind of smoke bomb. This is because Kahlog said the rocket motor doesnt really increase the thrust at all so save some money and maybe the smoke will last for most of the flight. I have a turnegy 42-40 750kv and two nanotech 4s 2200 mah batts to make a 8s monster? I know that the motor is on the small side of the size range, but the less weight might just counter balance it. I really want the plane to rock. This could all be changed after the maiden . PS Im not looking for long flight times maybe five good minutes or so. thanks
tmaucher is offline
Old 04-20-2012, 03:43 PM
  #220
tmaucher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ordered the graphics from Callie graphics .com. They respond very fast and they where here in I think in three days. Very reasonable price all so. Hey they have a new customer
tmaucher is offline
Old 05-29-2012, 03:25 PM
  #221
BIKERIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally got the Red airframe ready for final gear inst., decals, etc. Will
post final details later, Allen
Old 05-29-2012, 03:39 PM
  #222
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I picked up one of these at a swap meet a couple weeks ago. Converted it to electric with a 400Kv motor on 5s. Got a short flight yesterday and it looks like all the CG, and throw info, listed on this thread is pretty darn close. Canopy came of so I cut the flight short. I need to work on the the latch system a bit. BTW, Texas R/C Planes has got some red 163s coming in a few days, and they also have parts for them. The one I got was glow powered, so I ordered a new cowl from them.
TLH101 is offline
Old 06-09-2012, 02:35 AM
  #223
BIKERIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got decasl from Callie, great quality and fast shipping!, just $18
shipped, got all gear installed today, balanced at 6 3/8 in from L/E,
my other komet is balanced at 6.5 , but I think this is good for 1st
flight, final weight exactly 8 lbs.
Power System:
E-flite Power 52(590kv)
ESC Hobby Wing F/F HV 80 amp
Batt. Sky Lipo 6s/40c/4400
Prop, APC 12X8
My Power reading, Battery 15 min. off the charger, 65A/1650W.
good for 200W/lbs.
Love how It came out, test flight sunday, WKYP, Allen
ID:	1770440   Click image for larger version
ID:	1770441   Click image for larger version
Old 06-09-2012, 05:54 AM
  #224
tmaucher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On these new ones I have a question. Is the canopy tented? In your pictures it sure looks like it.
tmaucher is offline
Old 06-09-2012, 11:26 AM
  #225
BIKERIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: tmaucher
No is clear, the black cockpit frame may make it look tinted, this is custom repaint of original kit.
Allen
Reply
Display Modes
