Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications
#301
My Feedback: (90)
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications
ORIGINAL: Jonathan2121
I saw the pics of the finished product. But you did not post where you ground down the strut to fit the wheel. Can I just go with a smaller wheel or would you recommend sticking to the 3 1/2".
does it matter if i use 609HD 85 degrees or the 608HD 90 dsegrees?
85 or 90: that is the question. The stock retracts seem to be slightly less than 90, but I don't think they are 85 either. I'm thinking the 90 will be a little more forgiving, in that it will have a slightly outward canted stance. It's really a question of how much dihedral is in the wings, and I don't have the answer to that either. There appears to be less than 5 deg (each wing), which means that using 85 degree retracts will have the strut canted INWARD slightly. It's a tough call, you really couldn't go wrong either way. Anybody else have an opion on that?
BTW: only had time for 1 flight tonite, but it was beautiful.
#302
UT
Kempdawg, You are absolutely correct, yours is the first post to propose the reinforcing of the retract bay in a correct manor. I am going to incorporate your idea as well as tossing the stock retracts and replacing with Robart 608 HDs. I just traded for a slightly used TF P-51 ARF. It had one flight on it, on the second take-off the engine did not spool up so the pilot aborted the take-off. The plane ran off the runway onto fairly smooth sand and dirt and stopped. That was enough to break the right retract and split the mounting rails. The owner was not happy when the damage was inspected, and traded the plane to me. The whole idea of retract mounting is to spread the load over as much of the structure as possible, which is what your idea does. When are the manufacturers going to realize this.
Thanks for the idea and best regards from Old Bird.
Thanks Kempdawg89.
I understand what youare saying. When I was looking at the model last night and trying to figure out how to beef it up. I noticed all the empty space between the retract the lead edge and toward the tail. In my mind I came up with the same solution to just add wood until the retract fits nice and snug.
I am going to make those modification this weekend. I was thinking about adding some fiberglass cloth over the all the wood in the retract bay. What you think about that?
Are you using the stock plastic retracts or did you switch over to another?
Thanks again
Thanks again
Keep me posted on how your mods turn out - as for me I am going down to the shop to glue the wings together. I am not looking forward to this, one of my most hated ARF construction tasks, because it is so stressfull! The tape method just seems like the wrong way to do this, its not very strong, allows for sideways movement and pulls the darn covering up ARGHHH. I think I am going to try using rubber bands around those plastic pins and a clamp in the retract servo area as well as puting the wing bolts in halfway and rubber banding them from both sides as well. Does this make sense to anyone? Anyone have any tips on this process?
#303
NV
kempdawg, Here is my method for gluing wing halves together. Get two short pieces of dowel, 3' or 4" and stick these through the holes for the wing bolts. No dowels? use wooden pencils. Hold the trailing edge together with rubber bands over the pencils, top and bottom. Hold the leading edge together with rubber bands over the locating dowels. When you have this clamping sequence figured out, take it apart and mix and apply your epoxy, then clamp the wing again with the rubber bands. Be ready with some alcohol and paper towels to clean up the oozing epoxy, it will keep coming out for several minutes. If you think that you are going to have troubles with the wing halves slipping on the slippery epoxy, sprinkle a few grains of fine sand on one of the wing root ribs after you apply the epoxy. This will key the two halves together until the epoxy sets.
I just finished adding some birch plywood reinforcing under the gear mounting rails in the Mustang. I'll be using longer screw that reach into the new wood for some real grip. The new wood also fills the gap between the rails front and rear and the body of the Robart retract.
The stock retracts appear to be a cheap copy of the Robart 608 design. Leave it to the ARF makers to copy a good product with crappy, cheaper material.
Hope this reaches you in time for the wing joining.
Best regards from old bird.
#304
WI
ORIGINAL: cruzomatic
Michael,
What size prop are you spinning with that Saito 125?
Michael,
This bird sits nice and high, so 16" doesn't even come close to being an issue.
#305
WI
#306
WI
ORIGINAL: Kempdawg89
It would be nice if one of the 'gurus' on this thread could respond here.
My suggestion (and I certainly don't have the experience to back it up) is that the stock retract mounting rails do not extend deep enough into the wing on the leading edge side - allowing the retract housing to flex forward when the gear flexes backward during landing. Again the pivot point or stress point is the flange which caused the type of damage pictured elsewhere in this thread.
My solution is to add wood to the inside brace until it is flush with the mounting rail and supports the entire front side of the retract housing. Does this make sense to anyone besides me?
I am in agreement with you and Old Bird on the retract bay needing to be beefed up even more. I fit birchwood pieces under both the front and back of the retract bay and epoxied them in place. This allowed me to use longer screws to attach the robart mechanicals (608hd) that I'm using. I have had no problems with retracts so far, and everything seems very solid.
#307
Thanks michaelbbbb and corsairjock,
I ordered everything I needed today. I will be sticking with the 3 1/4" wheels to make my life easier.
Before I mount the retracts I will be beefing up the mounting bays with extra wood, lots of epoxy and fiberglass.
I am going away on vacation for 2 weeks so I won't be able to start the surgery. But I will keep you guys updated with some pics when I start.
Does anyone have any photos of the landing gear doors attached to the robart struts and how did you attach them?
My Feedback: (90)
OH
If tower is out of stock then I bet your dealer can't get them either as one of his main sources for robart parts is Great Planes distributors and Great Planes and Tower a one in the same.
I would recommend going online and find a dealer that just may have them is stock.
#311
WI
OH
Well I made the first flights of my P-51 today and I am pretty pleased.
The only real problem I have had is one of the plastic retract housings cracked and broke.
All my landings where greased two wheel landings on a fairly smooth grass field.
The same field I made over 300 landings with my WM P-51 and I didn't have one not one gear problem.
Also I had an interesting thing happening today.
My TF P-51 doesn't seem to hold trim on the roll axis.
On my first flight I thought I needed to give her a click or two of left aileron trim. but then she started to roll slightly left without giving any trim changes.
What I am trying to say is that this bird doesn't hold a neutral aileron setting, it is constantly drifting both right and left slightly on the roll axis.
Any ideas ?
I am using Hitech Digital programable servos for the ailerons.
Any ideas ?
#313
Should I go with the offset robart struts 653L and 653R
Robart 650 Straight RoboStrut 3/8"
is there a difference in performance. will either of them fit ok, without making modificatons?
#314
WI
#317
Does anyone have pictures of the Robart mechanical install? I just purchased the 608HD's and 653 L&R struts and have no idea how to set them up. This will be my first retract install to date so any help, pics, or tips are appreciated.
#319
OH
Has anyone tried to put a Zenoah G20ei (gasser) in one of these? Do you think it would fit?
#320
WI
ORIGINAL: harfordr
Plus you would be adding over 12 oz of extra weight to the nose. Mine is 10.5 AUW with the Saito, a slimline pitts and a smoke pump...so you
would go well over 11 lbs and still have to maybe counter weight to the rear of plane to get CG close to where it needs to be.
I don't see this airplane working out with the G20 too well.
#321
My Feedback: (90)
ORIGINAL: michaelbbbb
I am using a Saito 125, and I wouldn't want to try and stuff a larger engine in this plane. The Zenoah looks nice for a large cowl plane like a P-47, but if you put it in this P-51, you might as well give up on having any cowl left to mount.
ORIGINAL: harfordr
Some have pointed out that the landing gear/ retracts are suspect. Why add 2 more pounds to the weight, and in doing so: add even MORE stress to the retracts?
To each his own, but I just don't get it.
#322
KS
LoL!!!!!!!!!!
Some people might think the same thing about flying a P-51 that sounds like a mosquito
#323
My Feedback: (90)
ORIGINAL: AirWizard
LoL!!!!!!!!!!
LoL!!!!!!!!!!
I'll be flying mine at the Warbirds Over Gilmore (classic car museum) near Hickory Corners, Michigan this afternoon:
http://www.kazoothunderbirds.com/events.htm
MAYBE I can get another video made, and MAYBE someone elsl will show up with another Top Flite Mustang
#324
Hi,
Can anyone tell me which is the better retract?
Robart 550RS with 653 Robostruts. (air up/ air down)
Robart 700RS with 653 Robostruts. (air up/ spring down)
Lado 60-5 with 653 Robostruts. (electric)
Century Jet P51 with robostruts. (air up/ air down)
I am seriously unsure where to invest all that cash...
#325
My Feedback: (90)
ORIGINAL: plopes
Hi,
Can anyone tell me which is the better retract?........................I am seriously unsure where to invest all that cash...
Hi,
4 Blade Prop: Here are long awaited pics of my 4 blade prop (APC 14.4 x 11) installation. I think it is drawing about 35 amps with this prop, compared to 28 with the 2 blade (APC) 15 x 12. Despite the increased power, it seemed to fly better (had more pull during loops) with the 2 blade. I may end up using the 2 blade most of the time, and install the 4 blade for special occasions (like: warbird events)
Getting back to RoboStruts and retracts: the remaining 5 pics are of my LEFT SIDE retract. Some of you have been asking for details and/ or pics, so here they are. There are the stock retract units with RoboStruts installed, and 3 1/2" Dave Brown wheels. The 5 mm strut wires have been cut as short as possible, but note that I left the loop in and note it's orientation (inward). I like the added shock absobrtion that comes with leaving the wire loops in. By mounting the loops inward, the wheels are COMPLETELY retracted into the well, leaving plenty of room to mount those gear doors (IF you can locate the appropriate Robart gear door brackets).
Like I said earlier: I do not recommend using RoboStruts with the stock retracts because to modify the RoboStrut inserts is too complicated for most of you. They must be bored to 5mm.
If you want to install RoboStruts, regardless of whether you use the stock, Robart, or other: IF you want to retain the loops as I did, you will need to make the strut wire as SHORT AS POSSIBLE where it inserts into the retract trunion. This is because the offset RoboStruts can only be shortened so much, and you will also have to make them as short as possible.
I'm gonna guess that most of you however, will choose to remove the wire loops. This will not only simplify the installation, it will make it better looking also.
