If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 54 of 133 FirstFirst ... 444525354555664104 ... LastLast
Results 1,326 to 1,350 of 3321
  1. #1326
    fly24-7's Avatar
    Join Date
    Dec 2005
    Shrewsbury, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications
    ORIGINAL: RBean
    Seems the consenses is that the gas engine is out. I've don't know much about the RCV engines except that they are geared. Have not really though about it, but why not. But which one is best. Does it really need the 1.20 or would the .91 be enough. Are they easy starting, dependable etc? I guess I'll have to research and see what I can find out. I've ordered Spring Air retracts and Robart struts. I only have the engine decision left to figure out.
    If you're willing to pony up the bucks, you can always go with the Saito FG-20. Would fit the same as the Saito 125 and you'll get the best of both worlds - little cowl hacking and economy of gas.
    Why yes, I use mixing. Balsa, light ply and on occasion, dirt...
  2. #1327
    Last summer I purchased a TF P-51 and a Sato 115 (glow) which is just a bit smaller than the 125. This engine fits nicely in the cowl and produces plenty of power. Only the very top of the valve covers and the muffler (stock Saito muffler) are visible. You can check the height chart on the horizon hobby website to see how much taller the 125 is. It's late and my motivation has faded but I can take a picture and post it tomarrow if you are interested.
    Ultra Sport Brotherhood #122
    Ryan STA/STM Brotherhood #5
    P-38 Brotherhood #45
    Sig Brotherhood #101
  3. #1328
    mimoore67's Avatar
    Join Date
    Apr 2003
    Brooklyn, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: RBean
    Flight 21,
    and the rest have convinced me I need an RCV SP. Especially if they will turn a four blade prop. Next question is .90 or 1.20. The 1.20 at 34 oz is quite a bit heavier than the .90. I have a Thunder Tiger .91 FS on a VQ Hurricane and it is sufficient power but could be more. Since the Mustang is bigger, I'm not sure if the 90 will be enough. What do you think?
    I would go with the RCV 90SP should be plenty. These engines produce lots of torque and use big props and large pitch!
    It\'\'s gotta be scale!
    Private Pilot - Aircraft Single Engine Land
  4. #1329
    Flight 21's Avatar
    Join Date
    Feb 2005
    Overland Park, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I agree with Rbean - the 90 should be more than enough. It all depends on your flying style, but he is right on about the large amount of torque and bigger props and pitch. If you have at least intermediate flying skills the SP 90 should be great.
    \"Do or do not. There is no try.\" -Yoda
  5. #1330
    Join Date
    Jun 2005
    antwerp, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The reason I will go for the 120 sp is the following:
    The sp engines have a 2:1 gear internally, so they will turn at half the rpm of 'normal' four strokes. Therefore they need the high pitch propellers to be able to pull them through the sky. But at the same time, they are less efficient during slow flight (=take-off and landing)
    Therefore I will use a 3 or 4 blade prop, so the pitch goes down again, so I will have more thrust at the low speeds, needed for those hairy situations...
    (the efficiency of the 4 blade prop at the higher speeds will be less, but the mustang will be fast enough anyway, so it's a trade off between thrust at low speeds, or thrust at high speed)
    My mustang will be quite heavy as well: I have century jet retracts, on board glow, droptanks, 10 HVAR rockets, maybe smoke system,...
    (I think the 90 sp will be enough if you just have the stock set-up, without any mods)
    BUT IMAGINE THE LOOK OF THE BIG 4 BLADED PROP :-) quite scale...
  6. #1331
    CorsairJock's Avatar
    Join Date
    Apr 2002
    Parchment, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The 90SP will swing a 4 blade also.
    And speaking of torque: I have noticed that this plane seems to want to maintain that left turn right after after takeoff more than any other warbird that I have flown. I'm holding right rudder, but it still yaws and rolls left every time it takes off. The condition was worse when I had the 4 blade prop installed (more torque), which is why I went back to the 2 blade props.
    People that are set on over-powering their warbirds will do so regardless of anyone else's opinion, so if your so sure you can handle the extra torque: go for it.
    Avatar: Electric Powered, Highly Modified Hangar 9 Corsair
    Club Saito Member #670
  7. #1332
    Join Date
    Jun 2005
    antwerp, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, I still didn't buy the 120 sp, so I'm still able to switch to the 90 sp or cd...
    CorsairJock, do you think the 1.20 will be overpowering the plane, with all the extra's I will put on the plane? (CJ retracts, on board glow, droptanks, accu monitoring, etc.)
    I just want that extra oompff if I need the power... and thought that the .90 would be only 'just' enough...
    I just want a nice flying bird, not one with bad habits due to the bigger engine...
    any advice? (I now have the rcv 90 CD installed... maybe I don't need to switch to the bigger one? )
  8. #1333
    Join Date
    Apr 2007
    Lady Lake, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm leaning towards the RCV 90SP. The airframe seems pretty light. The Spring Air retracts, Robart struts and wheels are on order and won't be too heavy. I'm concerned about the weight of the 1.20. At 34 oz it is almost as heavy as the gasser (38 oz). Do the RCV SPs need an on board glow driver? That would be more weight with the extra battery.
  9. #1334
    Join Date
    Apr 2002
    Parchment, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I hate to make judgements concerning engines that I have no practical experience with. Altho I own an RCV 90SP (as well as a 60SP), I have never even 'fired it up' My intentions are to install it on a Thunder Tiger F8F Bearcat, but it is another one of my projects that has been put on the back burner. That Bearcat should weigh a little over 10 when completed (with 3 gear retracts, functional flaps), and I have every reason to believe that it will be a good engine for it (especially with a 4 blade prop).
    I'm thinking you Mustang will end up in the 11 lb range with the 90SP, and again: I'm thinking it should be enough to fly it comfortably and scale. It won't be a skyrocket/ able to leap off the ground and go straight up vertical, but you should get a reasonable climb without too much torque issues. Just my opinion. And despite what some people say: warbirds DO fly better/ easier when they are lighter. Not only do they fly better, they impose less stress on the landing gear, and I have witnessed that even CenturyJets are not indestructable.
  10. #1335
    sandseeker's Avatar
    Join Date
    Oct 2004
    Derby, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My TF P51, YS 91 Slimline pitts and Century retracts. Flew today nose heavy despite lead in the tail...great flying plane!
    Anyone fitted gear doors to CJ retracts?
    Chris
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1353327   Click image for larger version.
  11. #1336
    Join Date
    Apr 2007
    Lady Lake, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've decided to go with a .91 FS to keep this thing light. I'm using 700 series Spring Air retracts. I have Spring Airs in a VQ Hurricane with Robo struts and 3.5" wheels. They work great. However, with the Mustang I want to use the off set struts, but the Spring
    airs take 3/8" robo struts and the largest wheels these size robo struts take is 3.25 ". The 7/16 Robo Struts take 3.5" wheels, but won't fit the retracts. I'll be flying off a grass runway so the larger the wheels the better. Any one flow this plane off grass with 3.25" inch wheels or smaller? How does it do?
  12. #1337
    Join Date
    Mar 2005
    monterrey nuevo leon, MEXICO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    110 OS, 125 SAITO OR 91 ONLY IF IS YS...
    MY TWO CENTS.
  13. #1338
    Join Date
    Apr 2002
    Parchment, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: RBean
    I've decided to go with a .91 FS to keep this thing light. ............
    Sounds like a wise choice.
    ORIGINAL: RBean
    ................... I want to use the off set struts, but the Spring airs take 3/8'' robo struts and the largest wheels these size robo struts take is 3.25 ''. The 7/16 Robo Struts take 3.5'' wheels, but won't fit the retracts. I'll be flying off a grass runway so the larger the wheels the better. Any one flow this plane off grass with 3.25'' inch wheels or smaller? How does it do?
    If you would take the time to read some of the early posts, you will find that I am using 3 1/2" Dave Brown wheels on 3/8" dia. offset RoboStruts. It took a slight modification to the struts, but I pulled it off. Otherwise, I;m sure that there are plenty who are using the stock (3/14" wheels) and having good success on grass runways.
  14. #1339
    Join Date
    Apr 2007
    Lady Lake, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    CoursairJock,
    Thanks for the the info. I have read the entire thread but its been some time ago. I've ordered the 3/8" Robart Struts. I have 3.5" Robart tires so I'll find your prior post re the strut modification. I have a OS .91 Surpas II so I hope it will be enough power for at least scale like flying. I thought about the RCV .91 SP but I think I'll just go with the engine I have.
  15. #1340
    Join Date
    Mar 2002
    Little Elm, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: RBean
    I've decided to go with a .91 FS to keep this thing light. I'm using 700 series Spring Air retracts. I have Spring Airs in a VQ Hurricane with Robo struts and 3.5'' wheels. They work great. However, with the Mustang I want to use the off set struts, but the Spring
    RBean - if you call Spring Air they will make you adaptors so you can mount 7/16 oleos to their 700 series retracts. Hope this helps.
    Ed
    \"there are fighters and there are targets\"
  16. #1341
    Join Date
    Apr 2007
    Lady Lake, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I called. Their adapters as I understand it use a wire between the retract and strut. So then, why use Robo strut ready retracts. I'll go with the 3/8" struts. As I have already found with my Hurricane, the robo strut ready retracts and robo struts solve a lot of problems. Also the 3/8" struts weight slightly less than the 7/16" ones. I like the spring airs because you don't have to worry about having enough air pressure to get the gear down, wether from a leak or multiple operation of the gear in one flight.
  17. #1342
    Join Date
    Mar 2002
    Little Elm, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Who did you talk with there? When I called I asked the lady who answered that I wanted to talk to the guy who makes the retracts (I think its her husband). I told him I didn't want the adaptor you are describing and he said they would make one from aluminum rod with one end sized to insert into the hole in the 700 retract and the other end of the same piece of aluminum would be sized to fit into the hole in the 7/16 oleo strut. He said to use adhesive (super glue) to keep the adaptor in place in the oleo (I figured I woul use something a little more positive than the super glue).
    Sorry I didn't explain this in my first message.
    Ed
  18. #1343
    Join Date
    Jun 2005
    antwerp, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Man man man... quite a bit of work when you want more 'scale' retracts and covers...
    Here is what I have so far.... now just a bit more tweeking, paint and filler...
    Oh yes, you guys all convinced me that I would keep the .90 engine in it... the more scale flying, the better!
    A question: does anyone has a good solution for mounting the droptanks? the system with the screws is bound to fail on the first flights, I do not intend to make them functional, only detachable on the ground...
    And what about weathering ? is it possible on this type of covering? or will it just drip off?
    Happy flying!
    Jens
ID:	1355572   Click image for larger version.
ID:	1355573   Click image for larger version.
ID:	1355574   Click image for larger version.
ID:	1355575   Click image for larger version.
ID:	1355577   Click image for larger version.
  19. #1344
    RC-CAKES's Avatar
    Join Date
    Dec 2008
    Centennial, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    great job on the custom full length doors. I was thinking about doing the same thing as I never liked how the original was so tough to properly fit to robart struts.
    The attachment to look scale. As a friendly suggestion, don't forget to add some flat blk paint to the airscoop for authentic looks.
    :0
    Enjoy!
    -J
    Club Saito member #721
  20. #1345
    Join Date
    Jul 2005
    Victorville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok,, Flight Report... My -51 was one of the first batch with great covering and the mod. needed on the retract bays. I just got her in flying condition in Dec. and maidened it on the 31st of Dec.
    What can I say, the bird is perfect, better than I could have imagened when I started. The take-off roll was managable with input of rt. rudder ,it started to nose over but was more a function of it being out of trim. The climb out was positive if not spirited. Tucked up the gear and after a few clicks of trim the game was on.
    With the Saito 1.00 it is no racer but the performance is better than scale. With the stock set up on the controls the loops can be nice and big and the rolls nice and crisp. Knife edges well ( pulls to the belly somewhat) I have not seen that annoying tail wiggle that some warbirds have.
    Deploying the flaps does not require any trim change and slows the plane down very nicely. The landings were almost non events (except for the knee nocking) the Mustang setteled down at a nice speed and I was not uncomfortable with it at all.
    After 6 flights on this plane I can say I like it alot! I met all of my goals on the build and it turned out well. I know it's just an ARF but I still like it .
    Eng... Saito 1.00 , APC 14X8 prop ,Mc Daniel on board glow , Keleo inverted pitts muffler
    Raido..JR 9303 2.4 , Hitec servos
    Retracts... Lado 90*, Robart Robostruts/ 3 1/4" wheels
    C.G. 5 1/4" from wing /fuse join
    Weight... 10.8 lbs.
    Mods ... Scratch cockpit sunshield ,instrument pnl. , gunsight , airbrushed pnl lines/ weathering, Slimline pilot
ID:	1356280   Click image for larger version.
ID:	1356281   Click image for larger version.
ID:	1356282   Click image for larger version.
    Gravity is just a state of mind
    Ultimate 10-300 Brotherhood #151
    P-51 Mustang Brotherhood #151
    "Airman, go over to Supply and get me five gallons of jetwash."
  21. #1346
    Join Date
    Jul 2005
    Victorville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A couple of in progress shots. I desided to do the curent warbird and make the mods on the scheme rather than take off the fin fillit to make it the WWII bird. The stars& bars and the tail nos. are Major Decals, the invasion stripes are Monokote. The guns are alum tubing.
ID:	1356297   Click image for larger version.
ID:	1356298   Click image for larger version.
ID:	1356299   Click image for larger version.
  22. #1347
    Join Date
    Jul 2005
    Victorville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Couple more
ID:	1356301   Click image for larger version.
ID:	1356302   Click image for larger version.
ID:	1356303   Click image for larger version.
  23. #1348
    Join Date
    Jul 2005
    Victorville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Last
ID:	1356306   Click image for larger version.
ID:	1356307   Click image for larger version.
  24. #1349
    RC-CAKES's Avatar
    Join Date
    Dec 2008
    Centennial, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lemme be the first to say.......... AWESOME!! Love the airbrushing and the cockpit details! Glad your flights were heartpounding.
    I see a hint of gapseals in the control surfaces.. a great added touch to detail and aerodynamics. I did the same and it covers up the robart hinges nicely.
    I can't wait to get mine back in the air as soon as it warms up. A -51 on skis doesnt cut it! LOL I need to learn how to airbrush and I will do the same to mine one day. How did you do the panel lines- taped off or pen?
    Congrats!
    -J
  25. #1350
    Flight 21's Avatar
    Join Date
    Feb 2005
    Overland Park, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Most excellent! Bravo! I like your choice to do the current bird - looks just like it. So did you clearcoat the plane after the weathering, panel lines and paint? Or did you use fuel proof paint on the details?
    Very nice additional details. Very impressive...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
