Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications
Reply
Old 10-02-2011, 02:22 PM
  #1851
MANFRED
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications
Mpiz, I used panel fine line pen, then airbrushed lightly along most of the lines, then went back and added exhaust. Paint chips were done with aluminum color paint, Then dullcoated her. Got to maiden today and she is way overpowered with the ys110. Looked incredible on flybys. Had some elevator trim issues, landed good though without flaps.
MANFRED is offline
Old 10-02-2011, 05:12 PM
  #1852
Mpizpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: MANFRED
Planning on using a ys 1.10 myself now instead of the dle 20. Excellent job once again. Really got me motivated to work on mine again. What did you use to dull coat, did you scuff the monokote? Never tried this with film covering before.
Mpizpilot is offline
Old 10-02-2011, 06:05 PM
  #1853
JR16
JR16's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I went with the 85's but now you got me wondering if i should have gone 90 cause i went with the 653 robostruts and i had plans of installing the offset correctly, oh well not much i can do about it now the retracts are ordered LOL.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNCY1
JR16 is offline
Old 10-02-2011, 06:40 PM
  #1854
AirWizard
AirWizard's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Manfred,
Did you add weight, how much?
AirWizard is offline
Old 10-14-2011, 07:39 AM
  #1855
Mpizpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone have a quick and easy diagram of the panel line layout?
Old 10-14-2011, 11:03 AM
  #1856
emyscu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have something that can help you out...hopefully.
Ciao from Emidio
ID:	1674213   Click image for larger version
ID:	1674214   Click image for larger version
ID:	1674215   Click image for larger version
ID:	1674216   Click image for larger version
ID:	1674217   Click image for larger version
emyscu is offline
Old 10-14-2011, 04:36 PM
  #1857
Mpizpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Beautiful, thanks
Old 10-14-2011, 09:23 PM
  #1858
Mpizpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And for those using YS engines, did you guys use the stock tank? Will it hold up to the pressurized fuel system? Mines getting real close to being finished, I may have gone a bit overboard with the weathering though, lol.
Old 10-18-2011, 02:13 PM
  #1859
Mpizpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think I went a bit far with the airbrush, but it was my first attempt and I figured this is the one to practice on. I can always wipe it down before I clear it.
Old 10-18-2011, 02:15 PM
  #1860
Mpizpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Couple more, I know the lines are no where near scale but I was just trying to dress it up and try my hand at weathering..
ID:	1676198   Click image for larger version
Old 10-18-2011, 03:42 PM
  #1861
frets24
frets24's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You never know until you try and practice, trial and error lead to tried and true personal techniques and experience. Wipe it down in the direction of airflow to soften up the lines a bit but don't erase them...just drag the color across the surface and see how that looks. If you still don't like it wipe it all off and do it over. I clearcoat all of my planes with a rattlecan once finished with the paint, decals and abrasion/scratches weathering then do my washes and or airbrush weathering with acrylics. if I don't like it, an alchhol dampened rag takes it all away back to the clearcoat. Once finished and satisfied I do my clear fuelproofing to lock it all in.
Good start there anyway
frets24 is offline
Old 10-24-2011, 07:07 PM
  #1862
Mpizpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: frets24
Thanks, it'll get there eventually.
Old 10-25-2011, 06:00 AM
  #1863
JeffH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The biggest thing with weathering is color. Panel lines and rivets appear to be a darker shade of whatever color is on the plane. If you think about it, the plane is assembled, then painted. Any crud will collect in the joints and rivets, but it really just appears darken the joint, and maybe oil stain it. Wipe an oily finger across a flat paint, makes it look wet or darker.
A mustang wing has almost no panel lines or rivets showing since they are filled and sanded before paint.
Weathering is something that I know what should be done, but truly suck at actually doing. My planes always retain the factory fresh look
JeffH is online now
Old 10-25-2011, 05:35 PM
  #1864
RBean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've ordered paint from Warbird Paints to refinish my Mustang in British Camo colors, mainly its so beat up from my many off field, gear up dead sticks from engine problems. All now finally resolved. With the DLE 20 it has way more power than needed. I need to do a bunch of patchings, filling etc the refinish. The flat will help hide the many imperfections of my many repairs. Here is the chosen paint scheme. At least it will be different.
ID:	1678759   Click image for larger version
RBean is offline
Old 10-31-2011, 04:02 PM
  #1865
RBean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I started on refinishing the Mustang this weekend. Patched, filled sanded etc. Had to use bondo on the cowling, then covered with glass cloth. I got the plane masted off and primed. Expect Warbird Colors paint to show up this week, so will start painting this coming weekend. Ordered markings from Callie Graphics. Should be here before I finish the painting.
RBean is offline
Old 10-31-2011, 07:35 PM
  #1866
thebluemax
thebluemax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you must be one of the lucky ones with power up there......
Quote:
ORIGINAL: RBean
thebluemax is offline
Old 11-01-2011, 06:43 AM
  #1867
RBean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No power problems here. We used to live up near Saratoga Springs, NY. We would loose power if it got windy, or if there was an ice storm, or just because.
RBean is offline
Old 11-01-2011, 07:31 AM
  #1868
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I lost power 8 times this year. Finally got a generator so that should be the end of outages......
Hope that you guys get your electricity back real soon.
Lifer is offline
Old 11-19-2011, 03:50 PM
  #1869
RBean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I finally gave up on Warbird Colors. Since then Ive learned he had supplier and website problems. I ended up going to Sherwin-Williams and getting out door latex paint. Found out the have a cross reference for FS color codes. Only problem was I had to buy it by the quart. Then had to mix 2 parts water to 3 parts paint. Very then coats. Checked cg and wgt and couldn't tell any change of note .
RBean is offline
Old 11-19-2011, 03:53 PM
  #1870
RBean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here, I'll try the pictures again. RAAF Colors in Italy, 1945.
ID:	1688732   Click image for larger version
ID:	1688733   Click image for larger version
ID:	1688734   Click image for larger version
ID:	1688735   Click image for larger version
ID:	1688736   Click image for larger version
RBean is offline
Old 11-19-2011, 08:18 PM
  #1871
thebluemax
thebluemax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks good. nice job.I believe you are using a gas engine so you are all set....
Quote:
ORIGINAL: RBean
Old 11-20-2011, 07:48 AM
  #1872
Flight 21
Flight 21's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very Nice! A for effort on that scheme!
Flight 21 is offline
Old 11-20-2011, 10:21 AM
  #1873
maddog 71
maddog 71's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thinking of changing my YS-91 AC out for a DLE 20 The old YS is getting tired and also a fuel hog Im converting all my planes over to gassers this winter Any concerns with a 20 on this bird?
maddog 71 is offline
Old 11-21-2011, 05:19 PM
  #1874
RBean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
maddog71
I'm using a DLE 20 in my Mustang. Just repainted. Pictures above. The reason I repainted was because it was so beat up from multiple engine outs, sagging etc. Engine is equipped with pitts muffler. The engine would run ok on the ground, at first ok and then during flight start sagging, would not idle down the quit with power up. Took 4 months for me to figure out. Turned out it was vapor lock because muffler canister is under the rear mounted carb and not enough airflow in upper rear of cowling. Once I figured out problem fix didn't take much time. Installed air ducts from scoop under the spinner to upper rear cowl area and flang in front of air exit in lower rear cowl. This created high pressure area above carb and low pressure at exit drawing cool air over carb past the hot muffler and out. Since then no problems. Runs great, plenty of power. Here some pictures of the installation.
ID:	1689622   Click image for larger version
ID:	1689623   Click image for larger version
ID:	1689624   Click image for larger version
RBean is offline
Old 11-26-2011, 12:38 PM
  #1875
JoeMamma
JoeMamma's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: RBean
Just repainted. The reason I repainted was because it was so beat up from multiple engine outs, sagging etc.
Yeah.......repairs.......always a lot of fun.[:'(] The flying season is just about over here, so it's building and repair[:'(] time.
A few months back, I got mine a little slow during a landing. She then dropped a wing and stalled resulting in a cartwheel. Damage to front and rear wingsaddles and a big punture on the top of the wing. Not a terrible lot of damage, but it will be a sustantial amount of work.
I sure wish you could get plans for ARF's.[:'(] I need to fab up at least three wing ribs and having a set of plans would sure make my repair easier.
Joe M.
JoeMamma is offline
Reply
Display Modes
