If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 8 of 11 FirstFirst ... 678910 ... LastLast
Results 176 to 200 of 251
  1. #176
    Join Date
    Jul 2002
    Barstow, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: *World Models 70
    Waiting on the pictures and debaiting the conversion issue.
  2. #177
    Join Date
    Jul 2002
    Barstow, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm going to maiden the machine today. We have clear skies and the temperature should be in the low fifthtees. I choose to power this kite with an OS 1.08 glow engine using a VESS 15x8 propellor. Switching topics I want to ask why everyone is switching to gas engines? Is it due to cost of glow fuel or more I think follow the leader. The average modeler flys once or twice a week and during these outings may become airborne no more than six flights. These flights last no longer than 6-10 minutes. I'm one of these individuals and honestly can't figure out why most modelers are caught up in this change. I did stop flying my 90 size nitro helicopter because of the cost of 30% nitro fuel but this is the only machine that has suffered from the cost of glow fuel. I do still fly helicopters but they are in the 50 size range and use 20% nitro which is still affordable. Two stroke engines are still affordable and not obsolete. They are easy to maintain and set-up.
  3. #178
    Join Date
    Jul 2002
    Barstow, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Plane flew great. It took minor airleron and elevator trim adjustments. The OS 1.08 proved to be the right choice of power plant. Experienced in an flight emergrncy, lost throttle five minutes into flight. Flew the tank dry at 3/4 throttle setting. Landed plane dead stick without incident. Upon isnspection found out that my throttle set up had failed. Don't use nyrod in proximity of exhaust header, it will melt. Switched throttle set up to piano wire running inside sleeve. The spring air retracts fitted with robostructs worked fantanstic. They look real and are functional. Using a Vess prop increased my RPM by 250. I'll be back flying this plane tomorrow and experiment with the split flaps. A word of precaution, use blue locktite on all machine screws that hold the servo horns in place.
  4. #179
    Join Date
    Sep 2010
    KuantanPahang, MALAYSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys, I also have this beautiful bird powered with Saito 182T on it. I also have Mc Daniel Onboard Glow and using air retract. I used 17X8 APC Prop and believe me there is plenty power to climb it. For the CG, I have to add 120 grams at the fire walls and make the plane a bit of nose heavy. For the trim,I just have to adjust 3 clicks for elevator .So far after 6 flight with it, I'm so happy with the set up.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1545246   Click image for larger version.
ID:	1545247   Click image for larger version.
ID:	1545248   Click image for larger version.
ID:	1545249   Click image for larger version.
ID:	1545251   Click image for larger version.
ID:	1545252   Click image for larger version.
ID:	1545253   Click image for larger version.
ID:	1545254   Click image for larger version.
    Train hard to became a better pilot
  5. #180
    Join Date
    Jul 2002
    Barstow, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice plane. I'm new to split flaps and there operation. I set them up with 15 and 30 degress on a three toggle switch. I'm using a JR 10X transmitter which is programmed using its flap function. The servos are slowed down and I have dialed in elevator mix. The plane pitches up during flap extension and I end up manually holding down elevator in both settings. What must I do to eliminate this problem? My other planes use trailing edge flaps and they do not exhibit this problem.
  6. #181
    Join Date
    Sep 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: flycatch
    I had the same problem when the maiden flight aspecially during strong wind. I see there is two option for your problem.
    1) Mix the flap with the elevator but make sure you mix it with 30 deg switch position and not the 15 deg switch position or :
    2) Add some weight at the firewall like I did to my p-47
    Good luck
  7. #182
    Join Date
    Jul 2002
    Barstow, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    When I balanced the plane it required 1.5 oz to bring it to a level state. When I flew the plane it took down trim to maintain level flight at 3/4 throttle. Are you saying I should add additional weight to make it nose heavy? What is the reasoning behind only adding elevator mix at the full flap osition?
  8. #183
    Join Date
    Sep 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: flycatch
    Yes,you should add an extra weight on the firewall. I've add 4.5oz(125grams) on my firewall and yes I mix my flaps with the elevater to make the plane dive. For got to tell you about the mixing,I mix my elevator just only 12deg with the flaps. Hope you clear on that
  9. #184
    Join Date
    Sep 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is my P-47 landing video using 4.5oz on the firewall and 12deg elevator mixing with flaps at my place and see how it dive when I switch on the flaps
    http://www.youtube.com/watch?v=CzrH-zFnSGo
  10. #185
    Join Date
    Jul 2002
    Barstow, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The flaps are dialed in. No noticeable pitch change at half flaps however with full flaps deployed I mixed in 3 degrees of down elevator mix. With flaps deployed at full setting it lands at a fast walking pace. You can almost make a three point landing and the roll out is less than fifty feet on our packed clay landing strip. This plane is a delight to fly and displays no vices on different throttle settings. After resolving the gear geometry it tracks straight down the runway holding a sight amount of right rudder. Using flaps and side slipping to align with the center line proved to be pleasant. This is my forth warbird and I would rate it a ten.
  11. #186
    Join Date
    Sep 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You also mix with the elevator huh, good and nice job ... Any photo of your plane ?
    ORIGINAL: flycatch
  12. #187
    Join Date
    Jul 2002
    Barstow, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Took the machine out again and flew it in windspeeds ranging from twelve to fiftheen mph. This plane tracked perfectly. I did all the scale manuvers and the wind, which was blowing from the southwest appeared to have no effect on the flight path. Landing presented no problems other than the effect of weathervaning. Takeoff required rudder use upon rollout. I had another inflight emergency, involving throttle and I ran the bird out of fuel and landed dead stick. I penetrated the wind adding a little down elevator and the rollout was less that ten feet. Don't be fooled when you are told you need a heavy warbird to fly in windy conditions. This plane weights about 13lbs and took on the environment today.
  13. #188
    Join Date
    Jul 2002
    Barstow, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Spent the afternoon teaching myself throttle management and flap deployment. Has anyone noticed how the real plane lands with full flaps. It will touch down on the mains with a slight positive attitude and the tail drops almost immediatly. I practised this same manuver and the plane duplicates its big brother. Your landing roll is less than twenty feet. If you land on the mains tail high your roll out will be three times this distance. Something to think about. Our landing strip. packed clay, is twohundred feet in length and about thirtyfeet in width. It seems like it is plenty long but coming over the threshold you eat up a third of its length. I use about onehundred feet for takeoff for scale appearence. This plane is fantastic and a great introduction to the scale RC arena.
  14. #189
    Join Date
    Jul 2010
    Campinas, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is my Jug before decals and WWII Xoar prop.
    Setup:
    DLE 30cc;
    (7) S3305 Servos;
    (2) S136G Servos for retracts;
    T10CAG FASST TX;
    GWS Micro servo for landing light;
    R617FS RX;
    LiFe pack 1800mAh by Hobbico;
    Hydramax pack NiMh 1450mAh for ignition;
    Robostruts and wheels by Robart;
    Prop Nut by Truturn;
    Top Flite dummy engine;
    Xoar Prop;
    Aces of Iron pilot;
    Firepower RC drop tanks, pylons and machine guns;
    Navigation Lights by Marco;
    Thanks for all help on the posts, guys.
  15. #190
    Kostas1's Avatar
    Join Date
    Dec 2005
    AthensAthens, GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That's really nice,but do you have any other shots from above to see the airframe ?
    **Check my gallery for more pictures**
    http://www.rcuniverse.com/community/...y&memid=222042
    Club Saito member #706
  16. #191
    Join Date
    Nov 2003
    Reno, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RaiBalboa, very nice job of detailing and wiring on your P-47. Have you weighed your plane yet? I built mine completely stock except for the Ziroli canopy. With the Magnum 120 4-stroke she weighs just under 12 lbs. I want to put some detailing on mine but I am concerned about adding weight. How does yours fly? Mine flies great and the ground handling is the best yet of my warbirds.
    Best regards from old bird.
  17. #192
    Join Date
    Jul 2010
    Campinas, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thank's a lot old bird. I appreciate a lot your works.
    I dont know for sure how much it weights, but the Jug is flying great! The drop tanks and dummy engine are lighter..the engine is lighter than Zenoah 26, my past option.
    I didn`t have any trouble till now. I always flies with all accessories, including drop tanks.
    I'll weight it these days...hold on.
    I will post more pics of the airframe, Kostas, Stay tuned!
  18. #193
    Join Date
    Jul 2010
    Campinas, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Kostas, here is more pics from above.
    Hope you like it!
    See ya!
  19. #194
    Join Date
    Nov 2003
    Reno, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RaiBalboa, very nice p-47 and a beautiful airfield also. I hope you have many successful flights with your warbird. Now I have to go to work on some detailing of mine. I have the Ziroli dummy radial engine in the shop, and aluminum tubing for the guns. I really like those drop tanks and lights on your plane.
    All the best from old bird.
  20. #195
    Join Date
    Jul 2010
    Campinas, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks a lot, Old.
    Post a pick of your canopy.
    Blue skies!
  21. #196
    Join Date
    Jan 2010
    NelsonSouth Island, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
     Hi RaiBalboa,
    Nice job .Is that a side carb  DLE 30 or rear .I have acquired another W M P47   and fitting my trusty Zenoah 26 in now.
    Loved the way my first one flew hopefully this will be the same.Will be running a dual RX batt set up this time.
    Duncan
  22. #197
    Join Date
    Nov 2004
    Bloomington, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Raibalboa, you did an outstanding job on your airplane! Tell me, did you have to do anything special to fit the pylons onto the wings, like trim the pylons differently? Is there anything I can change to make the pylons fit better on this bird?
    Once again, great job. Your new stuff is on the way to you, by the way.
    Firepower R/C
    Saving un-loved R/C airplanes around the world
  23. #198
    Kostas1's Avatar
    Join Date
    Dec 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OOOOOoooo that is so nice...
    Have you maiden it ?
  24. #199
    Join Date
    Jul 2010
    Campinas, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi RaiBalboa,
    Nice job .Is that a side carb DLE 30 or rear .I have acquired another W MP47 and fitting my trusty Zenoah 26 in now.
    Duncan
    Duncan
    It's the rear carb version. I bought the G26i too, but it's side carb and heavier than DLE. I'm a Zenoah fan...love their engines.
    Post pics of your second Jug.
    Thank's a lot, Rich.
    The pylons fitted perfectly. You do a great job on your itens...congratulations.
    My Drop tanks are not dropable, but removable. The belly tank I didn't use yet, I'm waiting the one you are sending me. I will post pics here.
    Easy assembly also. Really nice.
    I got losted 1 Drop Tank on air, but I think it was my fault. No problems with the pylons.
    I asked you for one more pylon because I had a problem on my FASST RX. I losted Ch1 in air so I had to make a landind only with the rudder.
    I sent my RX to Brazilian Futaba Distributor, they sent me another one and apollogize for the fail.
    On the landing, I broke 1 pylon and the retracts. Only that.
    The Jug is flying perfectly today, fixed and still great. I'm just waiting your new itens to arrive.
    Your machine guns are great! Fitted perfectly.
    So Kostas, I did the maiden flight. This Jug flies great....really beautiful flying.
    I'm still flying with Futaba haha lol.
    See you, guys! Hope you like the model.
  25. #200
    Join Date
    Mar 2002
    Little Elm, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: bluebird26
    Β*Hi RaiBalboa,
    Nice job .Is that a side carbΒ* DLE 30 or rear .I have acquired another W MΒ*P47Β*Β* and fitting my trusty Zenoah 26 in now.
    Duncan
    Bluebird26 - could you please take some pics of the G26 installation? I have a G26 magneto and would like to see how it fits in this plane. Thanks for anything you could provide? Also - how does it balance withe the G26? Does it need weight anywhere?
    Ed
    \"there are fighters and there are targets\"
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
