KMP Corsair
Reply
Old 12-03-2010, 06:21 AM
  #1226
smchale
smchale's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: KMP Corsair
Brian, thanks the notes on the CG. Guess the best option is to start with it fwd then move it back.
So, my model just arrived so some of my initial questions (from the last page) have been answered. A couple I'm still curious about if anyone cares to share their thoughts?
What 4" tire options with alum hubs are being used as a good balance between strength and light weight? I'm thinking maybe the sullivan skylite's with alum hubs?
Any other modifications or hardware upgrades folks are recomending in the setup of this model? Also, anyone know that the wing panels are covered with? Looks like some sort of paper? Does it it shrink with heat? low or high?
smchale is offline
Old 12-03-2010, 06:52 AM
  #1227
DOC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sullivan Skylite's are the way to go! Our runway is chip seal and i went thru a set of Dubro wheels in 3months. The sullivans seem to be of harder material and are holding up better.
Good luck on shrinking the fabric covering, I've had no luck there.
Regards, Dennis
DOC is offline
Old 12-07-2010, 11:59 AM
  #1228
smchale
smchale's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dennis, do you have a picture of your skylites on the corsair? I'm curious if the smaller rim makes much difference astetically?
smchale is offline
Old 12-17-2010, 12:03 PM
  #1229
p51tom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just completed my scale Corsair tail wheel and mounted it in my model. I used Robart 4 1/2 inch wheels in my model. They are not heavy in weight only price. They are the proper size and should make flying off grass easier. I had to change the wheel wells to get the proper fit. The real Corsair has rectangular wheel wells. I am posting some photos for you. The last few photos I have added are coming out different sizes. Does anyone know what could be causing this.
P51Tom
p51tom is offline
Old 12-17-2010, 12:07 PM
  #1230
p51tom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The photos did not load. I will try again.
P51Tom
ID:	1535312   Click image for larger version
ID:	1535313   Click image for larger version
ID:	1535314   Click image for larger version
ID:	1535315   Click image for larger version
ID:	1535316   Click image for larger version
p51tom is offline
Old 02-02-2011, 10:37 AM
  #1231
flukester
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
P51tom,
where did you get the drawings for the tail wheel mechanism if you don't mind me asking? I would love to build that baby but I'm not as good a modeler as to build from a picture alone. I noticed that you have the BT plans and what looks like a new set drawn an CAD as well as a sketch. You're posts are great. I need to see pictures and have a description to help me along. Too much arguing over the CG and retracts. I hope that you stay with us. Is there a build thread you could point me to for the plane as well as the tail wheel? Keep up the posts please, but I'm afraid you've already finished.
Thanks ....flukester
flukester is offline
Old 02-11-2011, 03:48 AM
  #1232
smchale
smchale's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: smchale
Congrats Brian. Mine arrives tomorrow and I can't wait to get started. Have most of the items I need so should be able to dig into it shortly. What did your final weight end up at, and where did you settle for a CG?
Well mines all finished now. Here are a few pics. Going to set the CG around 110mm to start, seems the safest move. Here's a summary of some of the details:
ESM 74" span Corsair, Hacker A60-14L motor, CC ESC, 2x 5S 5000mah lipos in series for motor fuel, Williams dummy radial kit, lined cowl with carbon fiber and added two large hatches for battery access, Model Solutions of Canada sound card, 2x 40W speakers in wing, 2x 3S 910mah lipos in series for sound, futaba 2.4 rx, 6.0V nimh rx battery (size tba based on balance), functioning canopy, pappy boyington pilot figure with head linked to ailerons, scale pitot tube, scale antenna, sierra precision main retracts, sullivan skylite wheels, scratchbuilt retracting tailwheel, rib stitching on wings and tail surfaces, painted with testors MM enamels, stencils and transfers by getstencils.com, scale accessories static 3-blade prop, APC 22x12 2-blade flying prop. I'm sure I'm forgetting some things...let me know if you want any additional pics. Weight 22 lbs.
Also did a run up test in the driveway, here's a video clip: http://www.youtube.com/watch?v=3dwM6D4N4KQ
ID:	1561654   Click image for larger version
ID:	1561655   Click image for larger version
ID:	1561656   Click image for larger version
ID:	1561657   Click image for larger version
smchale is offline
Old 02-11-2011, 05:01 AM
  #1233
irocbsa
irocbsa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could you share your method for making the pilot's head rotate with the ailerons? Did you use a separate servo slaved to the aileron channel or did you rig up some sort of bellcrank and wire assemly?
irocbsa is offline
Old 02-11-2011, 05:33 AM
  #1234
smchale
smchale's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There really wasn't a lot to it. I used a 2-56 thread rod epoxied into his head, then ran that through a carbon tube in his body down through the floor. By the way, the rod was nice to hold while painting the head.
I just ran the carbon tube down below the floor far enough to clear the pull-pull cables. On the thread rod I added a nylon control arm and connected it to a mini servo slaved off the aileron channel.
I did need to sand a little around the base of his neck as well as inside his collar to allow the head to turn. Also the carbon tube extends a fraction above the body so the head pivots on the carbon tube and not on the body.
smchale is offline
Old 02-11-2011, 06:41 AM
  #1235
irocbsa
irocbsa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks! A picture is worth a thousand words.
irocbsa is offline
Old 02-11-2011, 06:58 AM
  #1236
aghost
aghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sean, Very nice!! It will go well with your other planes shown on your website.
Brian
aghost is offline
Old 02-11-2011, 11:20 AM
  #1237
Flight 21
Flight 21's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Smchale that is one sweet bird. VERY nicely done! Let us know how great she flies!
Flight 21 is offline
Old 02-13-2011, 11:16 AM
  #1238
p51tom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flukester
Sorry it took me so long to respond. I was on a 14 day cruise. I have posted information on "Looking for Corsair tail wheel build". Use the search function and you should find it. You will find a great amount of informaion from many builders of this tail wheel. My informaion starts on the last few pages.
Good luck,
P51Tom
p51tom is offline
Old 03-16-2011, 03:51 PM
  #1239
p51tom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Smchale,
I just completed my ESM Corsair and had to add 28 ounces to the nose for the proper CG. Adding so much weight, my plane came in at 20 and 1/2 pounds.
I had a 75" Brian Tayor Corsair that weighed 22 pounds and it was a great flying model. It was powered with a SuperTigre 3ooo with an 18x6 Zinger prop which gave it plenty of power. With the CG at 25% it landed very slow with those large flaps. I sold it to a friend who still has it. I wanted to go with gas engines so I powered my EMS with a RCGF 26 using an 18x8 Zinger.
I saw your completed Corsair and it looks great. Like my Tayor Corsair your model came in at 22 pounds and it should fly as well as mine did. The weather is getting nice so when the time comes, please let us know how your Corsair flys.
ID:	1579763   Click image for larger version
p51tom is offline
Old 06-29-2011, 01:31 PM
  #1240
lynn1130
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone know who is selling the Sierra gear for this plane that VQ used to carry? I know, Sierra LOL and I will call them too but was wondering if there are others. A friend is building his now and would like the retracts like I have but I can no longer find them listed.
lynn1130 is offline
Old 06-29-2011, 02:49 PM
  #1241
skillet92
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I remember correctly serria never had them listed you had to ask for them. But I believe if you go to arfpromodels.com they have the serria gear. Mine are GREAT. The strongest gear that I have. I am getting ready to pull the trigger on the esm 190 and will get the serria gear for it also.
skillet92 is offline
Old 06-29-2011, 03:10 PM
  #1242
lynn1130
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can't find them on ARFPros. They show the ESM gear (which are crap in my estimation) but I could not find the Sierra. I am still looking.
lynn1130 is offline
Old 06-29-2011, 04:05 PM
  #1243
skillet92
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lynn I found this link to VQWarbirds for the sierra retracts on google. Seems to still be good. Let me know! How is your Corsair still flying. I love mine and have really been enjoying it!!!
http://www.vqwarbirds.com/product_in...roducts_id=100
Old 06-29-2011, 04:09 PM
  #1244
DOC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try Sierra direct ! < http://www.sierragiant.com/ >
I have a pair that i have used on my ESM corsair for the last year and a half. I was saving them for an F6F hellcat. they have worked well for over 100 flights, but are sloppy from wear. I just retired the Corsair as War weary. Seems the Aerovate 26 has lost 50% of its power and is simply wore out !
DOC is offline
Old 06-29-2011, 04:20 PM
  #1245
smchale
smchale's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's the video of the first flightof my ESM Corsair today. Not too exciting, and a bit of a bounce on the landing. The wind was gusting quite a bit as I'm sure you can pick up on the camera...which was stuck on my hat so i apologize for the amateur quality. I'll work on that.
All in all the flight was good. The biggest challenge seemed to get it going straight on the take off roll, it really wants to turn, and sharp! I've never used a gyro before but wonder if it may help in this regard. Any suggestions? I fly Futaba so I'm open to any thoughts on a good one, as well as a suitable rudder servo to match it (again, foreign territory for me).
It also had quite a 'waggle' in the air, which I assume is common for the F4U? Would a gyro clean that up a bit?
You can hear me trimming a bit in the video, which was a lost cause due to the wind...I think I took out most of the trim i put in...haha.
The motor has gobs of power, and 12S made this thing really groove. I bounced the landing as I came in pretty hot, I was nervous about the weight. But the wing seemed to handle it well and I'm sure I could dial in more flap and slow it down in future flights.
I didn't run the sound on the first flight, I also disconnected the canopy valve servo (but did add air to keep in closed) and the pilots head. I'll go back and tweak the 'bling' once I finalize all the rates and settings, etc.
Sean
http://www.youtube.com/watch?v=HZMvLD7S6_E
ID:	1629447   Click image for larger version
ID:	1629448   Click image for larger version
ID:	1629449   Click image for larger version
smchale is offline
Old 06-29-2011, 05:13 PM
  #1246
DOC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sean, The best take off is so easy once you do it. Start out with just enough power to get it rolling slowly down the center line (just a high idle) then inch the power forward just enough to get the tail off tho ground. Now you have good directional control, but not enough power to get airborn(you should be 1/2 way down the runway). now open the throttle smoothly and complete the centerline TO. Try it, it works
DOC is offline
Old 06-29-2011, 05:33 PM
  #1247
skillet92
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sean, I just built my second one and have been flying it for about 3 weeks now! I did alot better job on this one it seems judging from flights that I have got so far. I have managed over a dozen so far and it is a putty cat!! I balanced mine at 4 and a half and I have a G-38 turning a 18x8 APC for power! More than enough!! Mine will just float in and it came in at just over 19 pounds!! As for the take offs just what DOC said I just ease in the power slowly till it gets moving while keeping just a tad of pressure on the elevator. I still have to control the left tendency with the rudder but after the tail comes up it smooths out. By the time I am at 3/4 throttle it lifts off scale like. I don't apply full throttle until she is about 30 to 40 feet because of the torque and roll over effect. Most of the time I fly on 1/2 to 3/4 throttle for a more scale flight.
As for the "waggle" mine has it just like my first and it does not seem to affect the way that it flys. It does it more in high speed passes. Here are some pics of mine!
PS Beautiful weathering job!!!
ID:	1629516   Click image for larger version
ID:	1629517   Click image for larger version
Old 06-29-2011, 07:03 PM
  #1248
DOC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've seen just about every Corsair model and they all HUNT during high speed level flight. The best part of flying this bird is the full flap landings.
Just Sweet !
ID:	1629547   Click image for larger version
DOC is offline
Old 06-30-2011, 03:09 AM
  #1249
smchale
smchale's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the input guys, great pics! Now that it's flown I can focus more on takeoffs (you know how the maiden goes with a million things going through your head at once ) and smooth them out. You are much lighter than I am, but that's my own doing. I'm closer to 24lbs. I refinished the entire model with panel lines, rivets, rib stitching, etc etc. I've also beefed up the front with 2 very large cowl flaps to install the 2x 6S packs, sliding canopy, sierra gear, full depth cockpit with moving pilot head, scale tailwheel assembly, sound system with 2 wing mounted speakers and 6S lipos inside....
Despite all that it didn't feel heavy in the air and the landing did slow it down, a bit more flap will be good too. I think the wing handles the weight well. Thanks again for your input.
smchale is offline
Old 06-30-2011, 04:43 AM
  #1250
Whistling Death
Whistling Death's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: DOC
I bought mine from VQ.
Whistling Death is offline
Reply
Display Modes
