T-28 Trojan from Iron Bay Model
QC, CANADA
Hi everyone! I am writing here to get your opinions on a big project I am planning . I want to build a kit. The T-28 from Iron Bay Model. See the link below
http://www.ironbaymodelcompany.com/i...s/Warbirds.htm
http://www.rcuniverse.com/forum/m_31...tm.htm#3126553
I am in rc airplanes since 4 years. I have owned 3 planes, all where arf. For the last year i was searching for the perfect model. This plane is what I am looking for. The thing is that this model is not available as an arf.
I have never built a kit and this one require knowledge in balsa, fiberglass and painting. I am thinking to go all the way on kit building. I am ready to invest the time it need to be complete. I want to educate myself on thoses building technique.
So, the question, for all the experienced builder out there, is it too big (hard) of a project for a first timer?
By the way I am a mechanical designer and also have kind of good hand skills.
Thanks a lot, and I wish me and the rcuniverse community will go far along my future project.
Daniel
Daniel
Banned
RE: T-28 Trojan from Iron Bay Model
By all means grab the kit and do think about how to build it but start getting into some of the less demanding kits to build up your knowldge of building and flying.
I would suggest you do a couple of top flite kits, they will teach you good skills and allow you also to get used to flying a warbird before trying to fly the big T-28.
While you are building your TF kits get a low wing tail dragger type of plane so you can get some expereince of the style of model you will be transitioning to. Something like a big dragon lady would be perfect or even a H-9 PT-19 if you can get one, they come as an ARF and can be powered by a 120 FS engine. I would highly recommend the Pt-19 before trying the T-28.
cheers
Peter
cheers
Peter
QC, CANADA
Thanks Peter for your input, I will consider what you are suggesting me.
I would like to simply clarify a point. My concern is more about building the plane than flying it.
Is there some lesser expensive kit than the T-28 that i could build in a similar way (balsa, foam wing, fiberglass) prior to building my dream Trojan ?
Dan
Dan
My Feedback: (10)
NE
the byron/iron bay t-28 is huge!! i would not suggest this bird as your first kit project. i agree with peter oz as to get the kit if you can when it is available. start out with a top flite corsair or p-40 as a first build. as for learning to glass, if you have flyin buddys that have glassed before, convince them that you need some pointers. the t-28 is not a hard build cause its 70% built cause of the glass fuse and foam flying surfaces. its the finishing that will get ya. a cheap start would be pick a foamie. learn to glass a foamie anything and still be able to fly it, then you have learned how to keep it light and still very strong... good luck....
My Feedback: (34)
Daniel,
Don't go for the Byron T-28 right off. That is one of the more complicated Byron/Iron Bay Warbirds to build. I would be afraid that you will get discouraged part way through. They never intended it to be that way, but with the plug in wings, tricycle gear the speed brake on the belly, all the air line routing... everything gets technically complex. I would strongly recommend something simpler to get your feet wet. The Yellow Aircraft Spitfire and/or Yellow Aircraft T-6 are about 50% of the work of that T-28. The Topflite Corsair and/or Mustang are great choices as recommended, yet you wouldn't get the experience with the glass fuses on those. You should check the Marketplace for that Byron Corsair that is selling right now. It would get you some experience first before you tackle that T-28. Leo
Banned
if you have the cash buy the kit and all the bits for it because you never know how long these things will be available for then once you are competent make a start, not before. Put it on the shelf and drool over it for a couple of years till your skills are up to it.
cheers
cheers
My Feedback: (9)
You prolly could fly it, but building it night prove to be a night mare! Build a couple of kits first. Than move on.
I couldn't get them to answer the phone.
Cox has a T-28 Trojan arf and so does Hobby people. Might look into that. http://www.hobbypeople.net/gallery/159545.asp
My Feedback: (52)
Peter Oz is right on. In fact, Byron has discontinued making the landing gear for this aircraft. I finished mine last year and I love her. In my opinion, it is the best engineered of all of Byron's warbirds, However, this is a VERY advanced build. If you like, do a search on this forum for my build thread on the Byron T-28 Trojan. Lots of pics and gives some insight into what goes into building it. Here are a couple of shots of my finished Trojan:
Banned
mmm that is a lovely bird, well done mate. Wish to hell I had secured that one off Dino last year [:@]
Think Sierra would be able to whip up a set of gear for it no trouble.
My Feedback: (9)
Robart also has the Gear. It is 644.80. http://www.robart.com/retracts/Custom.aspx , scroll down youll find it.
Can you still get this from Iron Bay. I have a Corsair New in Box that I got from Iron bay years ago.
My Feedback: (156)
Looks like Robart has discontinued manufacturing the gear for the Byron/Iron Bay T-28 and several other kits. http://www.robart.com/discontinued.html
My Feedback: (164)
CA
Awesome Mark,,,,,,,,,,,,,,,, one day that puppy will be in my garage
Dave
Dave
ORIGINAL: MarkShapiro
QC, CANADA
ORIGINAL: Spychalla Aircraft
Daniel,
Daniel,
Do you have experience with them, how is their customer service, etc... ?
I think this is a great alternative to the Iron Bay model.
Damn, Iron Bay are hard to get in contact with... two e-mails unansewred and one phone call with no response.
CA
Yeah, that and a totally useless website!
DANIBOY,
Don't give up on Iron Bay. I too have had reasonable luck with them. Just send a detailed e-mail and usually they will answer you within a week or so.......sometimes in a day or two. I've always gotten to them sooner or later. Then they usually help me pretty well and ship what I need pretty quick, if they have it of course.
Good luck to you with your choice. These guys are giving you excellent advice and you're so smart to get it from them.
Best wishes,
Scott
Best wishes,
Scott
I also have the Iron-bay T-28. First, the fuse is in glass but is only about 50% done, the wings are foam core and require much work before finished. Expect about 200-500 hours to complete depending on how much detail you will put into it. There is plenty of help here on the forum. This bird is no where nere 70% done for you. I have around 600 hours in mine due to the detail and brakes etc. I could spend another 40 or so hours tricking out the cockpit if I so desire later on. It is a very forgiving war bird to fly and with the tri-cycle gear very easy to get on and off the ground. I recomend the T-28 for many guys looking for a first war bird. Cox brought back the Pica T-28 which is an 78" version in an ARF. Try and find one of these and fly it first. They fly great also. I have had personal experience with them both in Pica kit form and the new ARF. Both are excellent fliers.
Good Day,
Gary Webb
Good Day,
Gary Webb
QC, CANADA
Wow Gary, beautifull Trojan you've built.
I have always liked more tri-cycle airplane over taildragers.
Now, for me things are getting straigh, I think im gonna start soon building a TopFlite giant P47D for building experience purpose. During that time ill try getting in contact with Iron Bay to get a T-28 kit and look with them if they have a source to purchase retracts since Robarts as discontinued them (my plan was to order from Robart).
If it is too fastidious to obtain a T-28 kit ill go to Yellow Aircraft and buy a AT-6 kit to perfect my building skills.
Dan
Dan
Daniboy,
I sent an e-mail to Iron Bay two days ago and got a response today. They had what I needed and are sending it out now. That's pretty good and they have always responded to me sooner or later.
I know of a complete Iron Bay T-28 kit w/retracts if you strike out with them. Send me a PM with your contact number and i'll call you if you want to speak about it. I also have a completed one if you want to talk about that??? Prices are pretty high so make sure you're sitting down if we speak.
Scott
Scott
Banned
curious, I nearly bought Dino's T28 kitlast last year but while I was trying to get shipping sorted it was sold to some guy in California, not Dinos fault as I told him to sell if a local buyer came along.
Would not mind getting a 2nd crack at it.
