If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 4 123 ... LastLast
Results 1 to 25 of 89
  1. #1
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Me109 F/G by Fliteskin
    Some have requested a condensed version of the building thread Im running on RCSB for the new 109 in 1/4.9 scale, so here it is.
    I won't bother with small details like glue rib 1 to stick B, etc. Just the main sequence of events as it unfolds.
    First a word about the design: it comes directly from Willy Messerschmitt. With great 3 views and cross sections, a scale prototype was built. The fuselage is completely molded along with supercharger & wing saddle. Also wing tip and radiators are molded. These are very time consuming items, so molding parts saves the builder a few months time.
    The wing has scale NACA 2R1 14.2 root and 2412 tips with washout for less tip stalls. Along with working slats allows more scale take off and landings. The full size 109 had to land 3 points to avoid ground loops.
    More info on http://fliteskin.com/page7.html
    JG
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Fliteskin is tougher than you think!
  2. #2
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Me109 F/G by Fliteskin
    Wing is built over plan using laser cut balsa and ply.
ID:	990888   Click image for larger version.
ID:	990889   Click image for larger version.
  3. #3
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Before skinning the top, leading ege gets drilled to accept the slats pushrods.
    A sheet of fliteskin is cut to oversize slightly over the plans and then glue to the ribs and spars.
ID:	990900   Click image for larger version.
ID:	990901   Click image for larger version.
ID:	990902   Click image for larger version.
  4. #4
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Top Wing is now getting sheeted, fliteskins are attached with Nano:
ID:	991735   Click image for larger version.
ID:	991736   Click image for larger version.
  5. #5
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    4 hours later wings are ready to be handled. Assembly positioned on the fuse.
    JG
ID:	991738   Click image for larger version.
  6. #6
    Join Date
    Aug 2004
    Medford, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Are the slats spring loaded/automatic, or are they servo controlled? If servo, when would they be used?
  7. #7
    Join Date
    Dec 2001
    West Linn, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tell me more about Elmer's Nano
    Kent
  8. #8
    Join Date
    Aug 2004
    Medford, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Elmer's Nano is simply rebranded Elmer's Ultimate. Its a poly glue. I find it similar to Gorilla Glue except for the time to dry.
  9. #9
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Evil_Merlin
    Merlin you are correct. Also Nano is easier to sand, Gorilla is a bit rubbery to sand.
    Slats move with flaps via torque rod.
    JG
  10. #10
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Time to see how the gear fits in the rails. Slight mod for the Spring Air set, ribs are cut for the Shindin Me109 gear.
    JG
ID:	992526   Click image for larger version.
  11. #11
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is how I built the gear doors using 2 sheets of fliteskin together:
    1. lay an oversized piece over the wheel well and using the template, draw the gear door shape.
    2. Sand 100 grit the area over the gear door.
    3. Apply slow CA over the first sheet and then place the second layer, previously sanded 100 grit.
    4. once dry, cut to to match the door shape with scisors. A third layer can also be applied for more strengh.
ID:	1008865   Click image for larger version.
ID:	1008866   Click image for larger version.
  12. #12
    rrudytoo's Avatar
    Join Date
    Dec 2002
    Simpsonville, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    JGrc,
    Those wheels and tires look great! Who is the supplier?
    Al
    To wives and sweethearts. May they never meet.
  13. #13
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Al
    go to www.fliteskin.com [8D]
  14. #14
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    At last the flaps and slats are working together. Seing the slats moving forward when the flaps deploy is really cool.[8D]
    JG
ID:	1010611   Click image for larger version.
ID:	1010612   Click image for larger version.
  15. #15
    Join Date
    Jul 2007
    San Jose, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How do you attache the Fliteskin? Looks like a great product. I love that 190D too! I wonder how much it sells for? Your 109 is going to be great! I don't know if I like the 109 or 190 better. They are both such nice looking planes.
    Jeff
    Courage is what it takes to stand up and speak; courage is also what it takes to sit down and listen.
    Winston Churchill
  16. #16
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jeff,
    Thanks for your comments, the skins are attched using Elmer's Nano glue. Similar to Gorilla but easier to sand on the spots that overflow a bit. Is a foaming glue so it does not take much. Only apply a bead over the ribs and spars. The key is to sand the skins with 100grit over the areas that will contact with the glue.
    Yes the 190D is a fantastic machine, flyes like a pattern plane too. Due to the Euro/Dollar exchange rate now the kit is probably about 2 grand[] I think the 109 will fly better, less wing loading. I calculate 18lbs weight.
    JG
  17. #17
    Doolittleraider's Avatar
    Join Date
    Nov 2003
    lakemary, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What thickness did you use? I tried to do it on a horizon stab and when it was done to "wavy" when it dried. How did you do yours?
    \"To Gen. Jimmy Doolittle, you would have enjoyed this airplane and it would have enjoyed you -\"
    Chuck Yeager
  18. #18
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Doolittleraider
    Dool
    I use .010" 90% of the time and the results are great.
    This is how I've done the DH Hornt stab which has a 37" span. First I sheeted the top and the added the bottom half.\
    The elevators are skinned with .007"
    JG
ID:	1011346   Click image for larger version.
ID:	1011347   Click image for larger version.
ID:	1011348   Click image for larger version.
  19. #19
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Update,
    received the rest of F/G parts
  20. #20
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Last couple o evenings I built the stab halves and joined:
    JG
ID:	1016401   Click image for larger version.
ID:	1016402   Click image for larger version.
  21. #21
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This morning I spent building elevators and gluing lil' ribs:
ID:	1016415   Click image for larger version.
ID:	1016416   Click image for larger version.
ID:	1016417   Click image for larger version.
ID:	1016418   Click image for larger version.
  22. #22
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finally I tried the rudder to check the looks [8D]
  23. #23
    Join Date
    Mar 2004
    Valentines, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I appreciate the effort but Please don't call this beautiful aifcraft a ME 109. True, it was built by Messerschmitt but the correct designation is BF-109. There has never been an Me 109. It's a common mistake.
    I never met an airplane I couldn't crash.
  24. #24
    JGrc's Avatar
    Join Date
    Feb 2002
    Portland, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You've got a point
    JG
  25. #25
    Join Date
    Aug 2004
    Medford, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Totally and utterly INCORRECT.
    The Bf 109 and the Me 109 are both proper designations for the aircraft and BOTH were used in Germany.
    The Bf 109 name was used by the RLM until July of 1938, from there forward, they had the Me 109 name (while the RLM tried to enforce the rule that any plane that had the Bf designation remained the same, it did happen).
    Documents have been found from the RLM, Messerschmitt AG and others that in some documents used both the Bf 109 and Me 109 designation in the SAME document.
    Heck even the Luftwaffe called the Bf 109 the Me 109, and pronounced it "may hundert-neun". Thats a bit difficult to confuse with Bf 109.
    So, both Bf 109 and Me 109 are proper.
    That being said all dataplates up to and including the K models were listed as Bf 109's.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
