CO2 for retracts
CO2 for retracts
Is anyone using CO2 for their pneumatic retracts. When I used to drag race we always used CO2 in our air shifters to eliminate moisture from the compressed air which can lead to corrosion and a possible malfunction.
RE: CO2 for retracts
I have never, ever heard of someone having corrosion problems with their RC plane retracts. Using normal air works, its cheap and there is plenty of it. No need to change IMO.
most moist comes from use of an air compressor. For the air tanks in an RC airplane you use a hand pump or a very small compressor. The content is on moist is not noticeable or visible.
The use of CO2 let you push more volume into a cylinder...
Like the former poster stated, no need for CO2 in RC aircrafts
Happy landing
G-Pete
Happy landing
G-Pete
My Feedback: (90)
I had a complete set of Rhom-Airs a few years ago ( sold 'em ), and the manual that came with them said to use CO2, and nothing else. I'm thinking that there really isn't that much of a corrosion problem with retracts (unless you use them thousands of times ), so like the guy siad: 'air is cheap' and readily available. I suppose if you have a supply of CO2, it wouldn't hurt to use it.
Hi Guys,
Just to let you know, a CO2 system will be available very soon (about 4 weeks time). It uses tiny very high pressure CO2 cylinders which cost less than $1 and can give up to 200 uses per cylinder (depending on retracts). It is also possible to adjust the rate at which the u/c retracts for much greater realism. The system does not require a servo as it includes a valve salenoid that operates directly from the r/c receiver. It also includes a pressure gauge etc and can be retrofitted to almost all existing retract systems. The system is very small and light weight, but I don't have the exact figures for that yet.
If anyone is interested, please let me know and I'll pass on more info when it becomes available!
All the best,
Alex
[email protected]
All the best,
Alex
[email protected]
Don't get too attached to CO2 systems people. It surely won't be long before the carbon police get it banned!
Surprised no one has complained about CO2 in fizzy drinks yet, must only be a matter of time!
Terry
Terry
My Feedback: (18)
ORIGINAL: Xelax
Hi Guys,
All the best,
Alex
[email protected]
Hi Guys,
All the best,
Alex
[email protected]
