Electric Byron F-16 Build
Reply
Old 09-01-2008, 03:18 PM
  #101
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Electric Byron F-16 Build
Thanks, the reason I ask, is that I use those on all my control surfaces but I connect to them with a Sullivan locking clevis so there is no turning force on them. If the nylon piece turns just a tiny bit with the ball link on it will throw off your stab neutral setting. Interesting that it works for you.
8178 is offline
Old 09-03-2008, 06:06 AM
  #102
nevster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Dave,
sent you a pm regarding the tuned pipe
Nev
nevster is offline
Old 09-03-2008, 07:49 AM
  #103
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Nevster,
I'm just about to respond.
I managed to get a little more work done of the last two days but i'm back at work now so i expect to slow up a fair bit[&o] I ave made the replacement former by making a template of the outside of the fuse and them trasfering the shape to lite-ply, i then adjusted the shape to suit and epoxy'd into place. I had to make the former in two sections to be able to get it into the fuse. I just epoxied the lower portion in this afternoon so tomorrow after work i can begin with the servo mount/installation for the rudder.
I might also try and pick up the paint for the aircraft tomorrow as well, and that way i can be ready to paint the fuse this weekend if i get that far.
My standard flow of packages has contiuned with the final items( for now) arriving today. th replacement canopy is in!!!! It's pretty thin on one side, which I'm not all that happy about but we'll see how it goes. the intake ducting that some bloke sold me in form the US doesn't fit![:@][:'(][&:] it's too small for the fan intake area and the intake at the front is a little too large. it can be made to work but not without a fair bit of work. so i'll have to shelf that idea for a while.
thanks
dave
ID:	1025290   Click image for larger version
ID:	1025291   Click image for larger version
ID:	1025292   Click image for larger version
ID:	1025293   Click image for larger version
ticketec is offline
Old 09-03-2008, 01:09 PM
  #104
hattend
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are either of you going to use the lexan thrust tube?
tecketec, where did you get the intake duct?
Don
hattend is offline
Old 09-03-2008, 05:42 PM
  #105
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: hattend
Don
Hey Hattend,
Yes, i will be using one. the original that was installed in the back end is damaged so i am trying to source replacement material to make one up for mine.
The intake duct came from some guy in the US who PM'd me and said he had an intake for a byron F-16 and it would just bolt in!!! it doesn't fit.[:@] i could do some work to it and make it happen, but not for the maiden..
Dave
ticketec is offline
Old 09-03-2008, 05:58 PM
  #106
The Ghost
The Ghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Dave, you did not need to put the lower half in, only the top half, see photo. Looking good, I'm looking at getting the paint to get into undercoat today, but with the wet down here at the moment I don't know when I will be able paint but I will be ready.
Cheers
The Ghost is offline
Old 09-03-2008, 06:47 PM
  #107
Peter_OZ
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave,
sounds like this thing is going to be more expensive then you bargained on! Probably why the old ownder wanted to offload it.
cheers
Peter
Peter_OZ is offline
Old 09-03-2008, 07:08 PM
  #108
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: The Ghost
Cheers
DOH!!!
ticketec is offline
Old 09-03-2008, 07:11 PM
  #109
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Peter_OZ
Dave,
cheers
Peter
Hey Pete,
Yeah i little more but not by much.... I made a good portion of the amount i paid for the model selling the engine, so i'm still pretty much on budget. and i always know you end up spending more that you originally plan anyway.
Speaking of which, i'll need to get some of those you-beaut extensions off you as well as another battery pack for the R/X. can you still get into your store room?
Dave
ticketec is offline
Old 09-03-2008, 08:12 PM
  #110
The Ghost
The Ghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave, it sounds like the orignal builder built it as a hanger queen and only used enough to make it look like it would fly. I would ckeck the balance on the flying stabs and check out how well the vertical fin is glued to the fuse, won't hurt to check now rather than find out later.
Cheers
Old 09-03-2008, 10:01 PM
  #111
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: The Ghost
Cheers
Hey Ghost,
I've given the fin and all the hinged flight controls a good tug to make sure they are correctly attached and they seemed fine. I think the guy who i bought it off didn't put it together but it ended up being a hanger queen for him either way.
It seems like the jury is out was to whether you should balance flying stabs or not. some say yeah do it, but there are also reports that the original instructions told you to balance them but after there were some losses of this model, they removed that instructions from the manual. what the "don't balance" camp suggest is that it's better for there to be a consistent load on the linkages which reduces the likelyhood of flutter being induced...
Dave
ticketec is offline
Old 09-05-2008, 12:43 AM
  #112
The Ghost
The Ghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well parts arrived today (only took two weeks[] Good ol' aussie post) First photo is motor with a new longer shaft fitted, old shaft and spare shaft material in bag. Second photo is the bearings for the front mount in stator unit. Third photo is the front mount with the bearing and motor mounted. Forth photo is unit with the fan fitted. Have tested with 6 cell pack (all I have at the moment) and it works great, not as loud as I thought. Will be deadly on 12 cell, can't wait[>:]. Still no more painting as it is still raining here today, should be clearing over the weekend, may get the painting done then.
Cheers
ID:	1026438   Click image for larger version
ID:	1026439   Click image for larger version
ID:	1026440   Click image for larger version
Old 09-05-2008, 06:10 AM
  #113
Peter_OZ
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah know what you mean. Hey what are you doing Friday 12th? I'm test flying the sea fury with Ron Ca t TMAC strip and need a camera man for the video. You up for it?
Had to move everything out of that storeroom as we turned it into an office.
All the gear is on a bench so can get to all the items no prob.
cheers
Peter
Peter_OZ is offline
Old 09-05-2008, 08:37 AM
  #114
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: The Ghost
That's what i though whem mine was running on 6s too..... i'm wearing ear muffs for any more runs at 11s, so hold onto your socks mate, she's gonna be loud!!!
I have made a little more progress. i have made up the servo tray for the rudder servo and epoxied that into place. i made it bigger so i can attach the retract servo and valves later on down the track. i also checked out to see how she was coming along CoG wise, and she's pretty nose heavy, so i'll be putting the 2 R/X packs in front of the elevator servos so i don't have to add any dead weight.
I know that the byron manual said that the flying weight should be between 10 1/2-12lb's but i was just watching some you tube videos and they were stating closer to 20lb for the ready to fly weight??? I reckon mine will be closer to the 6kg (13lb) mark. the fuse with servos comes in at 2.9kg (6.4lb), add to that about 1.5kg (3.3lb) of batteries, pluss all the other bits and pieces like fan/motor, ESC, etc.. well we'll find out as she get's closer.
Dave
ticketec is offline
Old 09-05-2008, 11:10 PM
  #115
The Ghost
The Ghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Dave, I don't know about it being loud, I have had and flown a kero burner so it should not be that loud. Still very wet[:@] down here today, but I did check the fitment of every thing in the model and wieghed it, came in at 3.3 kg's with every thing except batteries and paint, so I should be able to keep it light.
Cheers
Old 09-06-2008, 07:13 AM
  #116
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: The Ghost
Cheers
I must be getting too old then
3.3kg! thats really good.. i wonder why mine is so heavy then? maybe my scales are not reading right? that's the easy answer anyway Hummm Kero burner. i would love to get one, but they are just too expensive for me at the moment. I've never been able to find any turbines around second hand either? i would think that they would be a little more within reach if there were second hand ones available. where do they all go?
You motor install looks really good. when will you have your packs to run it up to full steam? Are you intending to fly yours before you finish painting it? i have been tossing the idea around. i have just finished the rudder and nose wheel servo hookup, so there are only a few minor jobs that would have to be completed before she could be flown. but it would be a few weeks more if i waited till after painting her to fly it.
Dave
ticketec is offline
Old 09-06-2008, 05:30 PM
  #117
The Ghost
The Ghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave, before you get a turbine check the regs that are in this country, and at your club and field, that is why I got rid of mine, to much crap to take with me to the field just for a quick flight. I have a couple of house hold bills to get rid of at the moment, but should have them within the next month or so, I could borrow a 6 cell pack from a mate of mine to see but the wait will be worth it. Never flown a model not finished, so I wont start now, as to the noise I am allmost deaf now so that may be the difference. The sun is trying to look through the clouds today so maybe the weather is going to brake and I may be able to get some painting done. Anyway I'm of to the field for a few flights.
Cheers
Old 09-06-2008, 07:13 PM
  #118
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah i've seen the cases of stuff some of the guys bring out to have a flight with a turbine, but that still doesn't outweight the cool factor for me... and also i't getting to beone of the final frontier for me having flown a fair few different types of models over my modelling time.
As for the quick and easy aspect, that's why i have a good cache of park fliers. don't even have to bother going down to the field to get a fix. the local schools oval is walking distance and is great fun for an after work weekday flight. Nothing is easier than a park flier.
I was just on rcgroups checking out an EDF conversion of the Yellow A/C F-16 done by a guy in Western Australia. he's flying around at 6.2kg with 11+lb thrust and the yellow is about the same size as the byron, so i'll be aiming to keep under that figure. his flies really nicely, and like he has done, i have a lighting kit coming in for mine! it just looks so good!!
I'll post pic's when it comes in.
Dave
ticketec is offline
Old 09-07-2008, 02:39 AM
  #119
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just re-weight her, and she is about 3.8kg with everything but the batteries onboard and paint as well... that's 600gms heavier than yours. i going hunting for the extra weight now
that should put me at around the 12lb ready to fly...
I just replaced the R/H wings locating dowl from the kit included one to the carbon tube i used on the L/h side because it's far more secure. I've also decided to hold my canopy down with magnets instead of the screw the manual talks about. Just have to work uot how many i will want to use. i'm thinking about 4 of them, but might more.
I also oped up the gun port and i will use this incoming air to cool the ESC.
Hey ghost are you gonig to use 2 r/x packs or just one?
dave
ticketec is offline
Old 09-07-2008, 02:53 AM
  #120
The Ghost
The Ghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave, remember that these were hand layed up fuses so the weight could be there. I will only be using one RX pack (2 cell 2500mah with voltage reg) it is all that I have used even in the kero burner, only have 3 servos in this model and only 2 (flying stabs) will be used 80% of the time so with a volt spy for the 2 cell pack it will not be a problem. No use adding more weight.
Cheers
Old 09-07-2008, 03:01 AM
  #121
Peter_OZ
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i can just see Dave with dremel in hand here weight , weight , weight come to daddy!!!
Peter_OZ is offline
Old 09-07-2008, 03:36 AM
  #122
The Ghost
The Ghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well the weather cleared enough this arvo that I got a layer of primer/surfacer on the wings. will wait untill tommorow arvo before I start the sanding, if the weather is OK in the morning I will start on the fuse, then will fill all the panel lines as I have an idea now about the final paint, (but don't ask as it is a secret[>:]).
Cheers
Old 09-07-2008, 06:29 AM
  #123
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Peter_OZ
Dremel??? that's for the little kids, grinder to get this porker to shed a few
Humm, been thinking this over, i might even use a BEC and save the weight of an R/X pack altogther. That way i have the redundancy of dual battery packs but no extra weight. the only other drama was that i was inteding to use the R/x pack to balance the model because she's pretty nose heavy, going to have to find something else to throw back out there for balance instead....
thanks
dave
ticketec is offline
Old 09-08-2008, 12:17 AM
  #124
The Ghost
The Ghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all, rubbed out the wings applied the spot putty where needed and then got the second coat of primer/surfacer on. Not raining and the sun is even out, but it is blowing a gale here and as I don't have the room to paint out of the weahter, the fuse will just have to wait for another day.
Cheers
Old 09-09-2008, 12:11 AM
  #125
The Ghost
The Ghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rubbed out both wings again and then applied last coat of primer/surfacer, will leave now untill I get the fuse to the same point and then will rub out and apply the white under coat.
Cheers
Reply
Display Modes
