CMP BF109F BUILDING THREAD
Reply
Old 12-04-2009, 10:42 PM
  #1426
kahloq
kahloq's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: CMP BF109F BUILDING THREAD
Rhom air?.
kahloq is offline
Old 12-05-2009, 12:29 AM
  #1427
SCALECRAFT
SCALECRAFT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thought I had seen the link on the struts in the winter season when the wheel pants were removed.
I'll check the 109lair.
Steve
SCALECRAFT is offline
Old 12-05-2009, 12:36 AM
  #1428
paladin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the sissors are hidden by th wheel. this is for the g but out of time. total doc size is 22meg so i can't post it for the enjoyment of all.
Joe
File Type: pdf
paladin is offline
Old 12-05-2009, 12:43 AM
  #1429
SCALECRAFT
SCALECRAFT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
According to the book " Messerschmitt BF 109 F,G,& K Series: An Illustrated Study by Jochen Prien and Peter Rodeike",a winter pic without the pants shows the links are there, small but there.
The links are hidden by the tire and wheel pants.
Steve
Old 12-05-2009, 12:45 AM
  #1430
SCALECRAFT
SCALECRAFT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
paladin, I think you win that one with that diagram.
Steve
Old 12-05-2009, 08:44 AM
  #1431
LDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wow great info Joe, had me fooled , never viewed links on all the models I searched on google
LDM is offline
Old 12-12-2009, 04:47 PM
  #1432
paladin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking for the angle of the struts and the best I’ve been able to get is this far is the attachment below. It tells me that a scale wheel base will be 15inches. I need to see how this looks on the model next. i have the 109F doc but it is to large for here so i attached the g.
Joe
File Type: pdf
File Type: pdf
paladin is offline
Old 12-12-2009, 05:01 PM
  #1433
LDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Joe correct me if I am wrong , with forward strake , that would mean the landing gear mounting rails would need to be on an angle so the gear would lean forward when extended and turn slightly aft when retracted to stay flat once in the wing ?
I had the same set up with my seafury , but not as much of a forward angle
LDM is offline
Old 12-12-2009, 08:00 PM
  #1434
paladin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yup, right now my forward rail is .200in below the aft rail. it does the same thing as adding the .250 spacer between the rail and Aft LG ear. if I wanted to move the strut further into the wing i move both rails into the wing =ly. this being an ARF I don’t have plans so I can’t be exact so I’ll live with what I get cause it won’t be perfect.
Joe
paladin is offline
Old 12-16-2009, 11:05 PM
  #1435
paladin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Robart 660DB Gear Door Mounting Bracket 7/16" Strut (GDMB) tapped a second hole for mounting the Landing Gear Fairings. Cut the OLEO to length, slip the GDMB on the strut, press the bushing into place and taping them.
I’m not sure the Rhom Airs will hold up under the wt. of this plane but I seam to have them all over the work shop, so I’ll give it a try. I’ve used these with OLEO’s on planes up to 15#. But they make the setup of the angle of the strut pretty easy.
Joe
ID:	1336005   Click image for larger version
ID:	1336006   Click image for larger version
ID:	1336007   Click image for larger version
paladin is offline
Old 12-17-2009, 10:10 AM
  #1436
SCALECRAFT
SCALECRAFT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
paladin
I have spring airs in mine. They work. My model is at 12lbs. It has a 108 in it.
My next one is getting a major bash, it will have CJet retracts once I finish the home expansion. 99% done though.
Steve
Old 12-17-2009, 07:37 PM
  #1437
paladin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks Steve,
I weighed all the parts months ago, and estimate those parts I did not weight, and came up with 17#. I know it will come down as the real parts are added. I have not balanced it yet which may go against me but right now I’m hoping for 16#. That should be ok with rhom’s.
The rhom’s will make getting the angle right easy. Just bend the 3/16 joiner between the retract unit and OLEO’s. it looks like 1.25in over the length of the strut.
Joe
ID:	1336623   Click image for larger version
ID:	1336624   Click image for larger version
ID:	1336625   Click image for larger version
ID:	1336626   Click image for larger version
ID:	1336627   Click image for larger version
paladin is offline
Old 12-19-2009, 02:47 PM
  #1438
dornhoffer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Paladin,
Your mods looks good and I think the Rhom Airs are strong enough. The only thing you might watch for is that they don't have a positive lock up like some of the newer gear. I have some on my Platt FW190 that comes in at around 12lbs. I have robart struts as you have done. They work great but if the gear doors don't fit snuggly against the leading edge, they tend to pull down in the slip stream and create drag as the gear are pulled down at high speed. I ended up flying without the gear doors because of this. Let us know how they work out.
Best, John
dornhoffer is offline
Old 12-20-2009, 06:17 PM
  #1439
paladin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John, because they don’t lock in the retracted position they are much easier to set up. Because I don’t have to reach the up lock, it stops where ever it hits a solid stop. While rhoms not locking up causes them to sag (allow the wheels to partially deploy) under high G’s if over loaded. Like at the bottom of a loop. I have 5 other planes with rhoms the worst of which is my Platt Focke Wulf 190 D-9 with a 9in strut weighting 1oz, a wheel weighting 4.5oz, and a strut cover that weights .75ox for a total moment of 48.4oz-in. with a starting tank pressure of 80 psi I can get two retractions before the third one exhibits the problem you are talking about. So the me109 has an almost 7 in strut weighting 1.5oz, wheel weighting 4oz, and a cover weighting .75oz for a moment of 36 oz-in. so I think I’m ok with 80 psi on the tank
Joe
paladin is offline
Old 01-01-2010, 03:45 PM
  #1440
paladin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
guy's i finally joined the wings and even with the lowering of the front LG mount the landing gear axile is nowhere close to the LE. have any of you flown off grass? and how mutch of a shim did you use?
Joe
paladin is offline
Old 01-14-2010, 12:33 AM
  #1441
paladin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I plugged the oversized dowel holes, figuring that the plastic ones would not hold up. Then used ¼ in dowels also can see that I glassed the center section. I did not take pic’s of the belly pan but it hid it all. the CG cam out at the aft recommended point, do you guys thing that is to far aft? should i move it forward for the first flights?
Joe
ID:	1355772   Click image for larger version
ID:	1355773   Click image for larger version
ID:	1355774   Click image for larger version
ID:	1355775   Click image for larger version
paladin is offline
Old 01-14-2010, 08:27 AM
  #1442
Hot Rod Todd
Hot Rod Todd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is your fuel tank mounted behind the stock position? The CG for most planes is based on some fuel in the tank, if you mount the tank on or near the CG you often have to move the CG forward to get the same effective balance point. In any case, add lead as needed to get the CG up to the recommended position. With an OS 1.60 on the front of mine I had to add tail weight. You must have a light engine. I used the stock plastic inserts for the wing dowels, they worked fine and seem to be holding up well.
Hot Rod Todd is offline
Old 01-14-2010, 03:11 PM
  #1443
paladin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks tod!
I'm thinking of moving it forward about 1/4 in
where is your CG?
Joe
paladin is offline
Old 01-14-2010, 03:35 PM
  #1444
Hot Rod Todd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't remember. I'm sure you could search back about 50 pages or so on this forum and find it. I believe it's right on the recommendation, rare for a CmP aircraft. In most cases they provide a CG that is way too far back.
Old 01-14-2010, 06:06 PM
  #1445
paladin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup, before i fly i will look back to see what you guys that flew already got, but that wont be for a few months here in ny.
you can see the cg i marked in the picture with the fuel tank. i move the fuel tank back because it helps with the ground handling not having all that fuel forward of the wheels
Joe
paladin is offline
Old 01-15-2010, 08:03 PM
  #1446
kahloq
kahloq's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
CG = 112mm for good stable flying.
BTW, the plastic dowl ring things hold up fine as long as you use CA glue on the 3 little screws.
kahloq is offline
Old 01-15-2010, 09:03 PM
  #1447
paladin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Kahlog
Joe
paladin is offline
Old 02-14-2010, 11:16 AM
  #1448
vmibert
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ty Brown has created a wonderful product (his spinner for the Nitro Planes Bf-109) and he put together some great tutorial videos that really helped!
Below are two photos of my Nitro Planes Bf-109 with Ty's spinner on it. The only issue I had with his spinner was that his backplate doesn't mount flush with my motor's hub, I'm having a friend make me a small, round plate to serve as a "washer" between the hub and the spinner plate. Other than that, and it looks perfect! After I painted my spinner, I poured on a coating of EnviroTex Lite Pour-On High Gloss Finish and after it cured, I got rid of the gloss by spraying it with a couple of coats of clear Dull Coat spray paint.
I'm still trying to tune my OS Surpass 200 2 cubic inch four-stroke engine. I can't wait to fly this!
Thanks again for your help!
Sincerely,
Bert
ID:	1378610   Click image for larger version
vmibert is offline
Old 02-14-2010, 12:44 PM
  #1449
21onen
21onen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I received my spinners last week. Very impressed. My plans are to use an E-flight 160 motor with the mounting bracket on the front . As a result the undercut in the spinner helps hide this bracket. Going through a drilling tapping process and using bevelled aircraft screws to mount the spinner to the base plate. Very nicely made spinners. Thanks Ty
Tero T in Toronto
21onen is offline
Old 02-14-2010, 02:12 PM
  #1450
Bill Jennings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
G'Day
Got my spinner from Ty a couple of days ago also very imptessed. Thanks Ty.
Regards.
Bill
Bill Jennings is offline
Reply
Display Modes
