Don Lien 80" Hellcat Build
Reply
Old 09-24-2008, 09:18 PM
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Don Lien 80" Hellcat Build
I think this will work out much better. 2 layers of heavy cloth and 1 layer of 3/4 oz put down with uncut finishing resin.
FLYPUCK is offline
Old 09-25-2008, 10:02 PM
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pulled the tail wheel door and layed up the access hatch.
ID:	1040999   Click image for larger version
FLYPUCK is offline
Old 09-27-2008, 08:10 AM
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tail wheel door trimmed
FLYPUCK is offline
Old 09-27-2008, 08:59 AM
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
access hatch
FLYPUCK is offline
Old 09-28-2008, 05:55 PM
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got the tail wheel assembly mounted up to the bulkhead. Held in place with some toothpicks (the poor mans Cleco). I'll be using Hysol to install the bulkheads.
ID:	1042653   Click image for larger version
ID:	1042654   Click image for larger version
FLYPUCK is offline
Old 09-29-2008, 04:58 AM
  #31
LDM
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nice work , dont know if you cut your seam in the doors yets , just want to share my experience , it seems like no matter how thin a wheel I use from my dremil I get a larger seem then needed (gap) , so now I usually use a very fine saw blade when cutting seams in doors . Turn over the curve so you can cut from the inside out and cut slowly so that you get the smallest , straightest cut possible
LDM is offline
Old 09-29-2008, 04:26 PM
  #32
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: LDM
Thanks for the tip LDM. I'm not quite sure what to do with the TW door. It appears that on the full scale the front of the door goes up into the fuse and it has a smaller one behind the wheel. I'm not sure how that works. I may end up just leaving a hole where the wheel is or hinging some split doors. Take a look at the pic. Also, the outboard flap. What's up with that??
FLYPUCK is offline
Old 09-29-2008, 05:57 PM
  #33
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone have the numbers on the controls surface throws? There is no mention of how much deflection to use on the plans.
FLYPUCK is offline
Old 09-29-2008, 06:47 PM
  #34
US185Damiani
US185Damiani's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FlyPuck,
Indeed you are half correct, A Hellcat has a Triangular shaped door attached to the Gear leg, but no door over the tire itself.
US185Damiani is offline
Old 09-29-2008, 07:18 PM
  #35
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: US185Damiani
FlyPuck,
Then I guess the most scale thing to do is cut the door short of the wheel and leave it open under the wheel.
Thanks for the input.
FLYPUCK is offline
Old 10-01-2008, 10:59 PM
  #36
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got most of the bulkheads glued in.
FLYPUCK is offline
Old 10-01-2008, 11:40 PM
  #37
LDM
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will look it up for yuo , looks like that flap is a flowler (spell check ) but its moved out as well as down , it can and has been successfuly imitated in models
LDM is offline
Old 10-02-2008, 12:01 AM
  #38
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: LDM
Right you are LDM. Single slot Fowler. I've just never seen one go so far out without moving down.
They can be replicated pretty easily with the proper hinging. Although not a true Fowler, they look pretty convincing.
FLYPUCK is offline
Old 10-04-2008, 09:46 AM
  #39
aquaskiman
My Feedback: (46)
aquaskiman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flypuck I have the same kit and started it last year, then got side tracked on another kit. Thanks for the build pic's George
aquaskiman is offline
Old 10-04-2008, 08:16 PM
  #40
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ran into my first major problem with the firewall today. This kit was designed to use a ST-2500 for power. Hence the funky firewall set-up.
I tryed mounting the engine to it and the prop was sticking out Waaaaay past the end of the cowl. Also, the magnito on the engine would be so far foward that I would basicly have to destroy the divider between the upper and lower openings of the cowl. I figure I have to drop the firewall 1-1/2" from it's present location to get the engine to fit correctly. I took a straight edge across the exsisting firewall and marked a line 1-1/2" down all the way around. This is where I figure the firewall needs to be.
I invite any and all opinions on if this is the correct way to fix the problem and any suggestions anyone might have before I start cutting.
PLEASE HELP!!!
FLYPUCK is offline
Old 10-04-2008, 09:14 PM
  #41
Chad Veich
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Hellcat actually uses a slotted flap and I have an old RCSM article on how to accomplish this on the Lien Hellcat. Lots of fiddling to get it right but it looks fantastic. I can send you a scan of the article if you're interested. The posted pic looks odd as I have never noticed the difference in deflection between the inboard and outboard flaps before. Wonder if that is just a byproduct of the operating linkage or if it was purposely designed to work that way?
Chad Veich is offline
Old 10-04-2008, 10:21 PM
  #42
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Chad Veich
I'm not sure what the deal is with that flap. Just looks really odd to me.
If you wouldn't mind scanning the article, that would be great.
Thanks for the help Chad!
=Doug=
FLYPUCK is offline
Old 10-04-2008, 11:36 PM
  #43
Chad Veich
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Doug, I'm pretty sure I have the article scanned on my computer at work. I will forward it on Monday when I'm back in the office. Please send me a private email to the addy below as a reminder if you don't mind. I searched airliners.net for more pics of the Hellcat in the landing configuration and 99% of them are of the TFC airplane (the same one as in your pic) and they all show the same flap configuration that your pic shows. However, I found one of the Planes of Fame Hellcat landing (see link below) and the flaps on it are all deployed equally! I wonder if the configuration shown in your picture is a partial flap setting or something.
http://www.airliners.net/photo/Grumm...cat/0482096/L/
Chad Veich
cvnkv@aol.com
Old 10-04-2008, 11:43 PM
  #44
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chad Veich
cvnkv@aol.com
That would tend to make sense of it. Good observation.
FLYPUCK is offline
Old 10-05-2008, 11:08 AM
  #45
Baldeagle
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chad Ken Perkins build a Fairyfire fly with simmilar flaps. The flaps were extended in flight to increase fuel milage and range. Then extended down for landing. It might be the same.
Baldeagle is offline
Old 10-05-2008, 06:59 PM
  #46
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: FLYPUCK
Chad Veich
cvnkv@aol.com
I happened upon a F6F training video from the 40's I'm guessing. It stated that there were only 2 positions for the flaps, full up or full down with no intermediate position. More head scratching.
FLYPUCK is offline
Old 10-05-2008, 10:34 PM
  #47
Chad Veich
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mystery solved Flypuck! I took the question to the guys at the Warbird Information Exchange board and it didn't take long to find the answer. Apparently, much like the Wildcat before it, the Hellcat has flaps which can be forced closed by air pressure. I've read this was to lighten the pilot's work load in the event of a go around during carrier operations. There was no worry of over speeding and damaging the flaps so the pilot could just leave them extended and air pressure would close them up. So, apparently, the pilot in the TFC Hellcat in your pic is running around a bit fast with the flaps down.
Old 10-06-2008, 04:33 PM
  #48
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And the winner is Chad. Not sure what you've won but at least your keeping me from beating my head against the wall thinking about it.
Nice work getting the answer. Interesting concept too.
FLYPUCK is offline
Old 10-07-2008, 06:39 PM
  #49
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chad Veich
cvnkv@aol.com
Thanks for the article Chad. A great display of craftsmanship.
FLYPUCK is offline
Old 10-08-2008, 08:46 PM
  #50
FLYPUCK
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rudder servo mount and pushrod installed. I will glass around it later (ran out of epoxy brushes).
FLYPUCK is offline
