Byron P51 One piece wing version
My Feedback: (20)
I picked up a partial built Byron P51 early version with the one piece wing. Most of the parts are there, except the material that is used to cover the metal gear doors. I have a Byron P51 plug-in wing version, and that used abs plastic to cover the metal gear doors. Can any one tell me what the earlier version used for the gear door covering, was it the same as the later model plug-in version? Was their an instruction manual for the kit? Would anyone have the manual I could get copies of?
RE: Byron P51 One piece wing version
I belive the early one pice wing kits used very thin plywood, maybe 1/16 thick or veneer,
the abs molded covers are way better, they fit the contour of the bottom of the wing, & are also a lot easier to install,
51-D GUY.
My Feedback: (20)
Thanks P51 guy. Looks like the plywood might be a better fix, not a lot of room for thickness on the wing, even though the abs would probably would last longer and be easier to install. Got plywood, lol, have to come up with the abs! Again thanks.
