Fleet Air Arm Corsairs
I am getting close to completing a 1/8 TF Corsair and, as an expat Pom in the land of Oz, would like to paint it in British colours.
Can anyone aim me at some info on colour schemes that I can work from. I have a couple of pictures but nothing good enough to base a paint job on. It's not going to be a super scale effort, but would like to do as good a job on the paintwork as I can.
This is my second Corsair, first was done as an NZ one in honour of our colleages in the Eastern Territory!
Terry
Terry
My Feedback: (27)
SC
RE: Fleet Air Arm Corsairs
Redback,
There are several sources out there but this one you can hit right away for some instant, though limited, information.
http://wp.scn.ru/en/ww2/f/571/9
On the right side of the page you'll see "Page 1" and "Page 2". Click on these and you'll get some profile views that may be useful. This is a Russian site and it is chock full of information on markings and such. Explore the site and I'll bet you'll save it in Favorites like I did. Enjoy!
Al
Al
My Feedback: (90)
Did a search for "Tamiya British Corsair" and came up with this:
http://www.internetmodeler.com/1999/...av_corsair.htm
BTW: Tamiya makes probably THE BEST/ MOST ACCURATE scale model kits. The kits come with decals for several different schemes (I am thinking that at least ONE of their many Corsair kits will have British decals and instructions), and they provide very accurate 3 view drawings showing where to apply the specific colors for a given paint scheme. Even if you don't build the model, the instructions and decals will be worth the money.
My Feedback: (7)
FL
This is mine. I am an ex-pat in Florida. I have a bunch of info and pics of Brit corsairs and I will get them together and scan a few pics.
Model Aircraft magazine had a few good issues of the British pacific fleet planes and one on corsairs. A french magazine that I found had the best selection, it is called aero journal and was issue no 23 and had about five pages of colour side views and two thee views plus lots of photos.
This is mine, I originally got this from the aero-journal magazine. It was the only British Corsair that I ever saw with artwork on it.
good luck
Paul
good luck
Paul
I came upon the information on the shorter wing when I was well into the build. EVen if I had known I am not sure that I would have changed the span on the model. Just have to make sure there's no-one around with a tape measure!
Dragoon, your's looks great, did you the plastic oil coolers or fabricate them? I don't plan to use the plastic as I found with the last one it was easier to make them from balsa.
Terry
Terry
My Feedback: (90)
The wings were shorter at the tips: they had squared tips, rather than the conventional rounded tips. The remainder of the the wings were the same as U.S. Navy/ Marines Corsairs. If your's is not painted yet, it's not too late to square them off.
"Corsair Aces of World War 2" ("OSPREY AIRCRAFT OF THE ACES") has an illustration (top view drawing) of the Corsair II wing tip. According to this booklet, the span was shorter by 8", or 4" each wing. That amounts to 1/2" per wing, on a 1/8 scale Corsair. Really not all that much, but it IS noticable.
You might also find more details and illustrations in the Squadron/ Signal Publication: Corsair in Scale and Detail.
Thanks CJ, I'll take a look. I am just in the process of finishing the wingtips/ailerons/flaps so it would be possible to do some mods. Only minor problem would be exposing the holes I drilled in the tip blocks to lose some weight!
BTW, just found a reference (http://www.fleetairarmarchive.net/Aircraft/Corsair.htm) that suggests that FAA Corsairs had "41cm clipped from their wingtips...." Assuming, as it seems, that this means each tip it would equate to about 5cm or 2 inches per wing.
Terry
Terry
My Feedback: (90)
Here is a link to a YouTube video; It is perhaps the best show that I have seen of a Corsair. I veiwed it many times before I realized that: altho it is painted as a U.S. Navy 'Jolly Rogers' F4U-1A, it is in fact a 'clipped wing' British (or New Zealand?) Corsair.
http://www.youtube.com/watch?v=DjRDZPS1X6I
My Feedback: (9)
WA
ORIGINAL: CorsairJock
Sam
More on the clipped wings. A book I have called "Fighting Aircraft of WW2" (an excellent book) suggests that the span of the British Corsairs was about 16 inches less that the US version.
At 1/8 scale this is about an inch of each wingtip. As the tip blocks are 2 inches at their widest this will work out OK and is what I will go with. It looks like if I cut this off the outline will be pretty close to the pictures I have seen.
Terry
Terry
The Corsair is getting close to completion. Pic below is the first time assembled after painting, main intent being to find out where the CG has ended up. I have a fairly substantial Nicad which, if mounted in the cowl should balance it about right. Expect the final weight to be around 10 3/4 pounds, after flying a 17 1/2 pound KMP FW190 I am not too concerned.
Build is mostly standard apart from the paint job (also I clipped the wings as per the early British versions), though I did fit Sierra retracts in the hope of regular, trouble free flying. Couple of weeks fiddling around to finalise the radio install and it should be ready for a 1st flight.
Maybe not a scale masterpiece, but at least it's not insignia blue!
Terry
Terry
Got an OS91FX in it which used to live in my previous TF Corsair, sadly no longer with us. Used to haul the old one OK so should be fine for this one.
Terry
Terry
1 Post
ORIGINAL: dragoonpvw
good luck
Paul
good luck
Paul
just been looking at this thread, your corsair looks super really good to see one that's not navy blue makes a refreshing change
keep up the good work
andy
p.s visited mount Dora on vacation last year lovely looking place ( he say,s green with envy )
