G-Pete's Ziroli P-38J Lightning build
#1002
RE: G-Pete's Ziroli P-38J Lightning build
Gary, same here! Thanks for the kind words, sure we will see each other next season. I really don't like grass runways - but Paradise field was even and had no surprises. Say hi to your brother. About the MG-1 read below...
JSZ, yeah that was a bunch of fun Well, Sunday I was early on the road and the traffic was light. By the time I passed the New Orleans exit I felt very good and kept on going. By midnight I pulled in the driveway of my house. 1200 miles in 17hrs...eat, fuel and stretching legs took one hour. Maybe on the next trip[8D] Saved me a day vacation...
Ty, this a 21th century 1/6 scale Stuart M5 reconnaissance. I have that tank for a long time. Anyway, I cut the inner fenders already and modified the rear drive axle and wheels. This weekend the tank has his last showing with the M5 skin, also this is a test with more weight. After that the chassis will be cut down and the work starts on the Cletrac.
I don't know yet how much I change the drive and road wheels of the M5 here are one of my drawings of the Cletrac drive...
#1003
Thanks for posting this thread G-Pete still using it for a reference for my P-38M build and thought people might
like to see it!
Bruce
like to see it!
Bruce
#1004
Over time guys PM me to see how and what Betty Page is doing. Well, I sold the P-38M and the last what I know she is just flying fine.
There where also questions what I'm doing - as usual I have a project, now this time it is not an RC Airplane. It is a replica of a 1963 FIA AC Cobra originaly introduced by Carrol Shelby - god bless his soul.
I don't think I have to mention the car is scratch build.
Anyhow, now you guys know.
[youtube]http://www.youtube.com/watch?v=oMYLvIlFVT4&feature=plcp[/youtube]
#1009
#1014
CT
Pete welcome to the AC Shelby Cobra Club!!! I have enjoyed mine for over 26 years now and to this day I have never driven anything that accelerates like a true FE 427...
You doing a great job.... look forward to seeing your maiden drive..
The attached photo is of my old girl and the video is for inspiration
http://www.youtube.com/watch?v=__jKGX6rYSo&t=31s
#1015
ORIGINAL: Ram-bro
beautiful work on the cobra, my favorite car.....to be a kit car you are doing a lot of fabrication. So whatwas the donor mustang used for?
BTW, it is not a kit car - it is fully scratch build.
ORIGINAL: Metalmorphous
Thanks, keep the rubber down!
#1017
Hi Pete,
I'm have juist finishend building my ziloli p38 and was wondering did you also turned THE cylinderhead and piston on THE reversed engine? I have found that if you do not, you Will have a compression difference beween both engines. Normally you can also check this difference when rotating THE prop by hand. You feel a difference when turning it to THE left and comparing with THE compression when turning it to THE right and vice versa.
Ronald.
Ronald.
#1018
ORIGINAL: G-Pete
The donor was just to have some initial measurements, motor dimensions, mount locations, weight - 50/50 weight distribution and the electrical harness. On a junker part you can grind, weld and cut around - no worries about damage. After that you replace the part with a new one .
The CSX 3134 was always one of my favorites - but your car looks very nice too. I hope to attend this year London OH.
Now all you need is an aluminum body, my panel beater at the shop worked building the original bodies in the UK, we can build one for you if you like.
Peter Howe
Howe Motor Works
ORIGINAL: Ram-bro
Peter Howe
Howe Motor Works
#1019
Hi Pete. Great build and rebuild. I am going through the same process now and I was wondering how on earth you fit those DA-85's into the cowl. I know your model is a P-38 "M" and the plans are for a "J" but I still measure at least 0.5" protrusion for a 85 out of the cowl as shown on the plans. Tell me your secret! haha.
tfarmer96 (09-29-2021)
#1023
Yeah - the propellers....[:@]
Since Solo is out of the picture for right now - I weighing my options here, the scale prop would be - Z38 scale 5.47 - 25.22 inches. I had not made my final decision yet, however ones the DA85 is converted the reverse of the conversion is plain simple. I will order my 85's with the conversion.
I working on a deal about the carbon fiber propellers...no promise here.
To the mufflers, I always make my own - at least on the warbirds. You will see here some custom pipes...
Happy landings
G-Pete
Happy landings
G-Pete
Makes 2, 3, and 4 blade ground adjustable, variable pitch props. I got a 4 blade from him for a O51. Same diameter prop from solo was 100 bucks more expensive.
Out of the box
The hub. Efficient design. Lighter than the solo but strong. You do have to loosen the perimeter screws about one and a half turns to adjust pitch, but once tightened down, its not going to move. Pitch adjudtment is the screw that is in the "block" which is engaged by pins at end of blades. Each blade has an aluminum core support at the base. He has scale paddle blades for warbirds.
Blades in the hub.
All together.
#1024
Hello, I know I'm about 12 years late on this thread, but are the Fritz Fowler Flaps plans still available? I am going to build this airplane and I really like the idea of fowler vs split flaps. They do look a little more complicated, but the reward is worth it.
#1025
I recently purchased everything available for purchase from Ziroli for the 38. I'll be buying the sierra retracts soon. Just a shot in the dark, does anyone have the fiberglass booms that they'd let go of? I'd like to save some time building when I get started. I thought about building the booms so I could mod them. I may still do it. The booms would be nice to have. Please PM me if you have them.
I'm also looking for any advice on a fowler flap system. If anyone has any templates or advice please let me know. I'm thinking of making something out of g10 or buying some from aero-accessories, although I'm not sure if they will work on this plane.
