CMP F4U Corsair 50 Build Log
Reply
Old 02-22-2011, 08:02 AM
  #101
SHEPSTER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: CMP F4U Corsair 50 Build Log
i have a brand new tower hobbies starter but it junk as it has no power to it and also i cant get to spin cause of small nut spinner .it wont turn it.
SHEPSTER is offline
Old 02-22-2011, 02:44 PM
  #102
SHEPSTER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i got fuel in line but i dont think its going in carb.pulled line and fuel at tip.its definatly not fooded.as if it cant get any fuel
SHEPSTER is offline
Old 02-22-2011, 09:59 PM
  #103
w1nd6urfa
w1nd6urfa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Shep,
I would break in the engine on the bench first. Buy an engine test stand, its sound investment, will save hours of frustration. And sort out the starter, you won't get anywhere without it.
w1nd6urfa is offline
Old 10-06-2012, 04:41 PM
  #104
cwalke32477
cwalke32477's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I just got my cmp corsair 50 today.
I will say, upon unboxing, I knew this plane is going to be a bit of a project.
I'm taking the Saito FA90-R3 radial, I was using in a hangar9 corsair 60, and putting it in this bird.
I hope my fancy radial will power this one much better than my 9 pound 60.
I had "upgraded" to a dle 20cc gasser for the hangar 9. Which is just perfect BTW
Since the radial is a heavy motor, I hope it will balance this model perfectly without adding extra weight.
cwalke32477 is offline
Old 10-06-2012, 04:52 PM
  #105
cwalke32477
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ordered the same retract set for mine. I noticed the same thing you , apparently, did.
The spar interferes with the retract motor.
I see you cut your spar to make them fit. Is this safe?
I was thinking about adjusting the oleo further down the wire to get the extension that I need.
I found i can barely stuff the whole mechanism in the wing, far forward, without cutting the spar.
But then the wheels do not reach the wells.
Old 10-06-2012, 09:04 PM
  #106
w1nd6urfa
w1nd6urfa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Which retracts cwalke32477 ?
Old 10-07-2012, 11:47 AM
  #107
mike early
mike early's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: cwalke32477
This tread just got serious.
mike early is offline
Old 04-14-2013, 08:40 PM
  #108
DYORD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi! Do you have to angle the glow engine to have down-right thrust?! If Ido that, i might have to cut the dummy engine cowling.
DYORD is offline
Old 04-15-2013, 01:08 AM
  #109
w1nd6urfa
w1nd6urfa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DYORD
IIRC down-right thrust is built in the airframe, you don't need to change anything
Old 04-21-2013, 06:10 PM
  #110
harleyman1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WELL, I READ THIS ARTICALE ON THIS CORSAIR, WELL, I WILL TELL YOU, ITS A PIECE OF JUNK, NOTHING IS DESIGNED RIGHT, YOU HAVE TO MODIFY THINGS  TO MAKE IT WORK, EVERY TIME YOU FLY IT, YOU HAVE TO BRING IT HOME TO REPAIR IT AND FLY IT AGAIN, CMP SHOULD BE ASHAMED TO PRODUCE SOMETHING LIKE THIS, I KNOW, I HAVE HAD TWO OF THESE AND THEY JUST FALL APART ON LANDING OR TAKING OFF, THERE IS NO QUALITY IN THESE ,THE DESIGN IS POOR , BAD WOOD, THE WING IS WEAK, WILL BREAK ON  LANDINGS SOMETIME, FOR THE TIME AND MONEY, GET A HANGAR NINE 50 CORSAIR OR ANOTHER TOP LINE BRAND WHERE THERE IS GOOD CRAFTMANSHIP AND GOOD DESIGN THAT WILL HOLD UP AND NOT FALL APART, ID RATHER BE FLYING THAN PATCHING IT UP SO YOU CAN FLY IT AGAIN, CMP IS NOT WORTH THE MONEY, THEY ARE CHEAP JUNK, GOOD LUCK  FLYING
harleyman1 is offline
Old 04-21-2013, 06:39 PM
  #111
Capt Easy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
....other than that how was the play Mrs. Lincoln?
Capt Easy is offline
Old 04-21-2013, 09:01 PM
  #112
BubbasanJohn
BubbasanJohn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hmmmm.  Love my cmp planes.  Wait he might not be able to see that typed that way.
I LOVE MY CMP PLANES. SOME OF THE BEST ARFS EVER.
BubbasanJohn is offline
Old 04-22-2013, 04:22 AM
  #113
Capt Easy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a highly modified CMP Spitfire 50-54 converted to EP and it's definately a fantastic ARF. I even bought a spare NIB I liked it so much. I would have bought a Corsair 50 based on the qaulity of the Spit but after reading several disappointing experiences with it I changed my mind. Some of their other stuff seems to be pretty good but I'm not familiar.
Dick
Old 04-22-2013, 10:46 AM
  #114
w1nd6urfa
w1nd6urfa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HarleyMan1
If you're wondering about CMPro quality, have a look here: [link=http://www.rcuniverse.com/forum/fb.asp?m=11461046]CMP Bf-109F[/link]
Old 04-22-2013, 05:01 PM
  #115
harleyman1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
now i agree, thats a nice looking plane, any problems building that, not like the corsair i hope.
Old 04-22-2013, 07:57 PM
  #116
w1nd6urfa
w1nd6urfa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I got it 2nd hand already built but not flown, the only mod done to the ARF by the previous owner was to replace the elevator fork pushrod with a 2-servo setup and I fitted ESM scale 80-degree retracts and struts.
The rest was done with an airbrush ...
Reply
Display Modes
