Don Smith Ki-84 plan sheeet help
My Feedback: (81)
It appears I am missing my Ki-84 plan sheet portion for the horizontal stab and stab ribs. Does someone have a sheet I can borrow to make a copy of just the stab? I ahve everything else I need. That's what I get for cutting the plans up. Any help appreciated.
Jeff
Jeff
RE: Don Smith Ki-84 plan sheeet help
Hi- go to aviastar.org/pictures/japan/kawasaki_ki84.gif or use any good 3 view to generate your own. Divide 3 view tailspan by 3 view wingspan and take this number and multiply it to your plan wingspan. You will now know your plan tailspan. Take 3 view of stab and either hand draw using dividers or copier to this plan dimension. Use hollow core method to build stab. Any ???'s just ask. You will find it more fun to draw your own plans to build airplanes no one else has! I am currently finishing a 1/4 DH-5, 80" Boeing B-9 and have started drwings for a 1/4 1928 Prufling glider, all from my own plans. I am gathering data for a Mitsubishi G3M Nell, now! I don't know whether to build 1/12 or sl larger.
ORIGINAL: F4u5
Jeff
Jeff
RI
Hi Don,
I have been looking for a 3 view or set of plans for the Prufling Glider, I did a Google search and your post came up on RCUniverse. Did you ever get a chance to finish up the plans and build 1? There are several
members of RCGroups that would like to build this glider this winter.
My name is Steve Shope, President of the
Rhode Island Soaring Club up here in cold RI.
Any information you could pass along would be welcome.
Thank you,
Steve
401-619-3145
Thank you,
Steve
401-619-3145
