Lado retracts, do the really exist?
#1376
My Feedback: (13)
RE: Lado retracts, do the really exist?
ORIGINAL: RACJ
Actuators?? Does this mean if I have Robart air retracts already in a plane I can convert them to electric and do away with tank and lines?? THANKS,RACJ
looks like magnumrc is only going to carry the ESM retrofit units unless they expand there line of products, I would imagine they will but I wouldn't want to speak for them http://magnumrc.com/index.php?main_p...a3ba15fbb382e7
this was just posted on the LADO site as well that the sale has been finalized and production should start etc... http://www.lado-tech.net/
#1377
From the LADO-Tech website:
March 22, 2010:
Great News! The sale of LADO is final and the new owners are working to get production going again. For any NEW inquires about placing NEW orders please contact Chris at [email protected] .
We have just finished shipping all repaired retracts sent in for repair, and now shipping the last of the pending orders placed with the original LADO Owners. For any questions on orders placed with the original owners or a retract sent in for repair please contact [email protected] .
Doug
March 22, 2010:
Doug
#1379
ORIGINAL: Neo gold
Lets get the show on the road Lado!...i need two sets!!..[img][/img]
LOL have you been through this thread ?
#1380
Yes, I have been through this thread. It is the same here as in other parts of the web. People making wise cracks, calling people liars and cheats, stating things that are not facts, generally being unhelpful twits because they have no personal responsibility for what they post. Many posts seem to come from 11 year old children rather than adults. Rather than LOL you might check and find out that there are people that have received their repaired LADO retacts.
I like others want to use the LADO retacts. LADO tried manufacturing and was not very good at keeping up, especially with health and city inspector problems. Do I think he made a mistake. Yes. Do I think the LADOs are a good product. Yes. So much so that I would rather have all my aircraft have LADOs rather than all the plumbing I have to put in with Robarts. LADOs are cheaper too when you consider all you need for pneumatic retracts.
So, I will wait for another month or so and see if everyone receives their retracts.
#1381
UT
A quick question about the max voltage I can use on these. The instruction sheet says that typical voltage is 4.8 to 6.0 and max is 6.7. I'd like to run my A123 batteries with them, but they are closer to 7-7.2 when fully charged. Anybody try these without problems, or do I need to reduce the voltage going to the Lado retracts?
steve
steve
#1382
FL
Steve,
The reason I send mine back was because I use more then 6.0, and they burn......But they are fix now and will be on their way soon....
Cheers,
Pisandro
Cheers,
Pisandro
#1383
I am using A123s in replacement of all of my 5 cell (6V) batteries. So far the LADOs are holding up. Both my A123s and 5 cells max out a about 7.2 volts when fully charged.
Have to check out the owner of LADOs and see what they say on their website.
#1385
... LADOs are cheaper too when you consider all you need for pneumatic retracts.
Hmm... not sure about that... has any one yet confirmed what the NEW prices will be on the Lados if/when they start selling them again? Has anyone also confirmed that Lado has also fixed their issues with their retracts breaking bearing and/or seizing up? (funny how some do not want to talk or even mention these issues) Definitely valid questions to ask!
#1386
ORIGINAL: skubacb
EXACTLY
lets hope so including me nearly six months
#1387
So for you folks using the 60-2 rotating ones. Which robostrut are you using?? I have a set and am looking for some for my H9 Corsair
Also for a Miss America H9 P51
#1388
My Feedback: (13)
I know some guys have used the 7/16 struts with the rotators, you need to make a adaptor for the wire connector,sleve a 5/32 wire with a piece of brass so you can connect them the larger strut only comes with a 3/16 adaptor.
I used the 3/8 robo-strut for my H-9 P-40,its a little chicken legged but it works just fine.
I used the 7/16 struts on my H-9 Mustang, I had to modify them by disassembling the strut, removing the nylon stop,and cutting aprox 3 coils off the spring.
then after cutting the tube down to size and JB welding the adaptor in, you can put them back together, on the Hangar-9 planes at least, you end up cutting the internal stop out when cutting the tube to size, so it just slides up against the adaptor.
I didn't cut the shock portion down and this reduced the amount of travel but they work well, my standard 90o gear I had made with the 3/16 hole so i could use the larger pin.
I bought some piano wire from the LHS and after cutting the pin to size and notching for the grub screws I heat treated them for hardness so there super stiff, and I have loads of extra for when it bends, no need to worry about bending them back I just cut another one to replace it.
had to edit this a bit
#1390
My Feedback: (13)
sure http://www3.towerhobbies.com/cgi-bin...?&I=LXES65&P=0 this is the 3/8 strut
the 7/32 strut http://www3.towerhobbies.com/cgi-bin...?&I=LXES94&P=0
#1393
My Feedback: (13)
ORIGINAL: mike early
80-90 dollars for a pair of struts really adds to the price of a pair of retracts.
of course you can get that price down with the tower discount program etc...
but if the new company keeps prices on par with what lado charged 200 for the rotators http://www.lado-tech.net/proddetail.php?prod=60-2
then the price is on par with most other mfg. sierra precision sells there rotators for 270 as well http://www.sierraprecision.com/prod30.html
there all pretty close in price for quality gear.
#1394
Received my repaired retract a few days ago. Worked great. I will buy more retracts for my other aircraft once Lado gets settled down.
#1395
CA
I received my repaired one also but still waiting my other one I ordered back in Sep 2009. Hope to receive it by the end of this week as LADO said they are filling the backorders now.
MikeV
MikeV
#1396
My Story,
Saw Lados advertisement.
Searched RCU for Lado in topics and found this thread. 9/22/09 Page 17
Read the tread from the beginning and saw the ups and downs.
I was able to communicate with Doug via E-mail, The gear I wanted was in stock.
I placed my order 10/9/09, receive confirmation of order.
10/31/09 I sent a e-mail regarding Status?
11/9/09 I sent a e-mail regarding Status?
11/23/09 ...Status?
11/24/09 Doug replied "waiting on bearings to rebuild inventory..."
11/24/09 Doug posted on web-site the problems and health issues.
12/27/09 Doug posts on web-site he's selling his Manufacturing rights.
12/28/09 Sent e-mail wishing him a fast recovery.
12/29/09 Doug replied thanking me and said they are working on the orders.
2/16/10 Received e-mail Jeremy's intro.
3/10/10 Received e-mail from Jeremy, orders being sent in two waves, 12th and 22nd.
3/25/10 I sent a reply to Jeremy, being his dates had passed without notice.
3/25/10 Jeremy replied, Apologized and said my order was shipped that day with tracking #-
and thanked me for my patience.
3/27/10 Que Heavenly music... They arrived!! Yes I have my order.
I have tested them, and they work so smoooth.
Now to start saving my money for my next order.
11/23/09 ...Status?
#1397
My Feedback: (13)
ON, CANADA
Thats good to hear.
I,ve been watching of late to see if the newly structured company is able to satisfy the demand[back orders etc]
I,ll just wait a while lnger for things to settle down before jumping in.
Dave
Dave
#1398
ORIGINAL: rcyogi
Steve,
Cheers,
Pisandro
Steve,
Cheers,
Pisandro
Isolated from the reciever pack...
