Lado retracts, do the really exist?
Reply
Old 07-30-2011, 06:18 PM
  #1776
mirwin
mirwin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Lado retracts, do the really exist?
Quote:
ORIGINAL: chalmrast
Well I have 3 "landings" on my Lado 60-2's now with my CMPro P-40 -73". This E-conversion weighs over 12lbs. Each landing resulted in collapsed gear but not a fault of the Lado units. Here is a brief description of each setup & what happened:
I am using Robart 660 struts that accept 3/16 wire (smallest) and the Lado's accept 5/32"
Pre-Maiden: I made adapters from 5/32 to 3/16 by using 5/32 music wire and 3/16 copper tube. I JB-welded the tube over the portion of the music wire that goes into the Robart strut. This failed even before the maiden because the set screws on the struts only made contact with the copper tube. The JB-weld didn't hold thus allowing the music wire to spin inside the copper.
Landing 1: I made my own wire adapters using 3/16" music wire. I cut a piece to length then inserted it in my drill press. With the wire spinning, I used a dremmel wheel to turn the diameter to 5/32" for the portion that inserts into the Lado trunion. Take-off & flight went great. Landing was smooth but the gear folded up like sticks. Everyone thought the Lados failed but they held without a problem. The wire adapters are what bent at a 90 degree angle. The act of "machining" them down weakened the metal terribly. I tested a piece on my bench at home by sticking one end into a vise and putting the strut on the other end... I could bend the wire with very little effort.
Landing 2: I made new adapters by "soldering" the 3/16" tube to the 5/32" music wire. I put "solder" in quotes because you cant really solder copper to steel. But, it held enough for what I needed. The copper really only needs to act as a second bushing. I then ground a flat spot on the copper/steel side that went all the way through the copper. This allowed the strut set-screw to make contact with the wire, not the copper. I then used a silver Sharpie to mark the set screw locations on the Lado side and ground those areas flat as well. I put blue Loc-Tite on all the set screws. For this flight I was not at my normal flying field, I was up in the mountains at about 6200' elevation. With less lift due to the thinner air, the plane landed a little rough. Once again, the Lado's held strong but the wire bent on the left strut. I have video of this landing and I'll post it as soon as I get it processed.
Landing 3: Same day as Landing 2. Since we were camping out & didn't have access to all my tools, I decided to try an allen wrench as a wire adapater. I figured it's hardened steel so it should have more strength. Also, it already has flat sides! My buddies told me it may be harder, but it will most likely snap instead of bend. I figured "what the heck" so I tried it any way. Once again, a rough landing due to less-dense air & not enough elevator throw. This time both sides bent and one side actually ripped right out of the blocks. The Lado units were un-effected!
I am going to drill out the trunions to 3/16" I have nothing to lose at this point. If it doesn't work I'll just order new trunions. But, everyone at the field was thoroughly impressed with the strength of the units... for them to take that kind of force & not even flinch is impressive.
Normal0falsefalsefalseoNotPromoteQF />EN-USX-NONEontGrowAutofit />ontVertAlignCellWithSp />ontBreakConstrainedForcedTables />ontVertAlignInTxbx />Normal0falsefalsefalseoNotPromoteQF />EN-USX-NONEontGrowAutofit />ontVertAlignCellWithSp />ontBreakConstrainedForcedTables />ontVertAlignInTxbx />
chalmrast,
I haven't paid much attention to this thread lately, and I've not read beyond your post above. I developed a somewhat unique fix for the same problem I was having on my H9 Corsair: bent wires. Having tried everything else I could think of, I finally found the permanent fix. Necessity is the mother of all invention, they say.
[/b]
[/b]Go to the hardware store, and buy a couple smallish screwdrivers. Take a caliper with you, and you’ll find that the shaft of most smaller screwdrivers are the exact diameter that you need to fit the Lados. Screwdriver shafts are made of chrome vanadium. [/b]
[/b] When is the last time you saw a screwdriver bend? Me neither. I’ve had absolutely no more problems with my Lado / RoboStrut combination.[/b]
[/b]
Mike [/b]
mirwin is offline
Old 07-30-2011, 06:21 PM
  #1777
mirwin
mirwin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: chalmrast
Okay, let's try this again -
Normal0falsefalsefalseoNotPromoteQF />EN-USX-NONEontGrowAutofit />ontVertAlignCellWithSp />ontBreakConstrainedForcedTables />ontVertAlignInTxbx />oNotOptimizeForBrowser />
chalmrast,
I haven't paid much attention to this thread lately, and I've not read beyond your post above. I developed a somewhat unique fix for the same problem I was having on my H9 Corsair, bent wires. Having tried everything else I could think of, I finally found the permanent fix. Necessity is the mother of all invention, they say.
Mike
mirwin is offline
Old 07-31-2011, 07:43 AM
  #1778
Magnum RC
Magnum RC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All newer Lado products come with 5mm wire size collets and trunions. This is slightly larger than 3/16. The strength comes from the case design.
Magnum RC is offline
Old 07-31-2011, 08:35 AM
  #1779
m3_express
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guss,
Question. So does the new regulator work for the smaller LADO retracts as well (333 series)? Also, if one were to get the regulator and used it on a 300 series REV B retract, could one use it to speed up the retract or would that only work on rev. C units?
M3
m3_express is offline
  #1780
show871
show871's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Magnum RC
Quote:
ORIGINAL: show871
What are my lado options if wanting to convert a ESM Hellcat to Lado?
Your options are easy, You can buy an ESM retrofit kit for 219.95 and it comes with all the parts you need to convert and do it yourself or send it in to us for retrofit for a $50 labor charge on top of the kit cost. ESM's Gen 5 gear are a great retract to convert.
I would like to do this.....could you please send me a link on what items I need to place in my cart with you? And is everything in stock for this??? Thanks!
show871 is offline
Old 07-31-2011, 12:35 PM
  #1781
Magnum RC
Magnum RC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The regulator was designed for the REV B retract so that one may use the 6 volt on board pack. The regulator will allow 5.2 volts to pass to the retracts unabated; The maximum voltage allowed without having to worry about overdriving the unit. A six volt pack can overdrive the Rev B electronics because sometimes it spikes to 7.2 volts after it comes off the charger so the regulator is the solution to that. On REV B, there isn't any two speed option, it will just increase the speed some by allowing the voltage to increase to 5.2 volts. On the rev C, the regulator offers two speed operation because the retract electronics can take the additional power and one just switches off the regulator to allow the entire voltage of the on board battery to pass through. I hope that helps
And yes, the regulator works for any Lado product.
Old 11-22-2011, 08:11 PM
  #1782
dawhale
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have just received two sets of LADO retracts RS 333-RB & RS 333-85. Both say Rev D. What voltage are they good for?  I also got 5mm struts and wire wheel adapters. The axles are to short and large in diameter for my Hangar 9 wheels. What Axel will allow me to use my Hangar 9 wheels?
dawhale is offline
Old 11-22-2011, 11:53 PM
  #1783
christophe31
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The REV D are the new ones in digital, so you can program delay if you want in.
you can supply them with 4,8v, 6v , 6,6v , 7,4V, in fact any normal power supply for your receiver.
christophe
christophe31 is offline
Old 11-23-2011, 08:59 AM
  #1784
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: christophe31
christophe
Good morning christophe31,
I've gotten good service out of the 4 sets of Lado retracts I've purchased. The only complaint is the sets in my H9 Corsair and H9 Hellcat only extend 90 degrees and both those planes are flown from grass fields. They really would benefit greatly if the gear moved 100 degrees. Do you have any plans to offer rotating retracts that extend greater than 90 degrees? Even on paved runways, 90degree geared models have been known to nose over. The tires are simply too far back, too near the CG.
Wingspan retracts are presently offering 100 degree rotators. So it's obvious there is a market for "long arc" gear.
Any plans?
da Rock is offline
Old 11-27-2011, 12:13 AM
  #1785
christophe31
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi Da rock,
yes we plan to doing the 100° rotating in 2012, and for those who already have the 90° , it'll be possible to change only one piece to have the 100° version.
like on our RS333, if you want another angle you simply need the separate parts with the different angle , and that's done.
many other good things will appears in 2012.... and as me ( i'm a modeler who try to fly all week end with my products.... ) you'll love it.
Old 11-27-2011, 07:05 AM
  #1786
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi Da rock,
Now that is really great news. I've got two sets that really, really would help the model taxi, takeoff, and land better if the wheels rotated farther forward. I've already moved the CGs back about as far as I'm willing to fly those two planes.
You are talking about the Corsair/Hellcat/Warhawk rotating gear, right?
da Rock is offline
Old 11-27-2011, 07:20 AM
  #1787
dawhale
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gentlemen, I am a newbie needing a little help. I just bought  two sets of LADO retracts. One is for my Hangar 9 Hellcat. The other is for my Hangar 9 P-51 Mustang. Little confused as to what to buy, struts, in order to install wheels. How are you folks doing it?  I bought the 5mm wire legs and wire leg adapters. My Hangar 9 wheels are not going to work on these adapters. I have not been able to find much info out their.
dawhale is offline
Old 11-27-2011, 10:42 AM
  #1788
Magnum RC
Magnum RC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Call Magnum RC, and we will advise you. We do have Oleo struts that are designed for the RS333 series retrats. 541-603-0528
Old 12-01-2011, 10:51 AM
  #1789
FlyandMighty
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's what you get with Lado.  No help
FlyandMighty is offline
Old 12-01-2011, 11:12 AM
  #1790
Joespeeder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi FlyandMighty,
It was very difficult to get an answer before Lado was sold to Christopher. However since the sale both Christopher and the guys at MagnumRC have been very quick to help with any question or order I've had. The turn around is as fast as any you'll find and each time I've seen a question they can help with either Christopher or MagnumRC have chimed in very quickly here to respond.
I waited over 4 months for my first set from Doug. Once he sold out to Christopher you can now easily see what's in stock and where to get it from.
I will be using Lado for my ESM LA-7 and look forward to the improvements in programing you can now do right inside the retract unit.
Looks like Magnum responded about 3 hours after dawhale asked about his setup. That seems pretty good to me.
Joe
Joespeeder is online now
Old 12-01-2011, 11:18 AM
  #1791
christophe31
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: FlyandMighty
i think you don't want me to help you.
i've done all i can ,and cannot do more sorry, if you don't make any effort.
and yes , everyone of my customer get answer like you when you have asking me how to tap the hole of the slider.
i'm 10000km far away from you, don't forget that.
@ joe:
and i'll continue, i cannot let say that customer will not have answer from me, yesterday i 've sending mail to greece customer at midnight, i don't think you will found someone answering at this time in other factory.
but unfortunatly, i cannot make happy FlyandMighty[&o]
Old 12-01-2011, 11:40 AM
  #1792
Joespeeder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Christopher,
I have really enjoyed watching the progress you've made both in service and changes in th product line since you acquired Lado.
The possible combinations of retracts and struts is second to none including nose wheels and rotators.
Now the addition of being able to program features directly into the retract unit gives us controll and simplicity not available anywhere else. Great additions.
Thanks for all your work and keep up the great work.
Joe
Old 12-01-2011, 11:57 AM
  #1793
christophe31
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Joespeeder
Hey Christopher,
Joe
and is just the beginning....
as i'm firstly modeler , before business man, i do what i dream for, and fpr sure you'll love 2012...lol
the complete legs for all our retracts will be here soon.
and just to make you see what will be 2012, look this:
[youtube]http://www.youtube.com/watch?v=dRk97k73xFs[/youtube]
sorry for my froggies english.... as some blame me for.
Old 12-01-2011, 06:54 PM
  #1794
funkymeter2003
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was one of the folks that Doug took the money and ran from. New ownership has been very helpful in a timely fashion since they took over, I would stand by their service!
funkymeter2003 is offline
Old 12-01-2011, 11:28 PM
  #1795
bigtim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have done business with both Doug(the original owner) and MagnumRC ,now that Magnum is selling the units there service and communication on availability and shipping of the parts was great.
Doug was on such a shoe string budget and just wasn't prepared to handle the business side of things great product lousy businessman thankfully he sold the company
bigtim is offline
Old 12-02-2011, 06:32 AM
  #1796
scale only 4 me
scale only 4 me's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awesome,, when will Magnum have these?
scale only 4 me is offline
Old 12-02-2011, 12:27 PM
  #1797
Magnum RC
Magnum RC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Soon....
Old 12-03-2011, 07:24 AM
  #1798
N1EDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a Robart tailwheel that I wish to put into a TF P-51 Gold Edition Mustang.
If you are making a list to announce when these are ready for sale, would you put me on it? I presume this will mate up to the Robart tailwheel?
Bob
N1EDM is offline
Old 12-03-2011, 07:37 AM
  #1799
dawhale
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How are the LADO struts in comparison to the Robarts? Any one tried both?
dawhale is offline
Old 12-20-2011, 09:09 PM
  #1800
4DFlyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh Yeh!
http://www.robart.com/robarts-new-electric-retracts
4DFlyer is offline
Reply
Display Modes
