NEW H9 P51 Mustang 60 ARF
#251
TX
RE: NEW H9 P51 Mustang 60 ARF
i changed the tail wheel too...it was just way to wobbly for my taste.
used a Dubro semi scale tail wheel.
it has the right sort of look to it.
i didnt use it in the scale location however because that hook up is just to much of a PITA.
besides....on a fast fly by....who the hell see's the tailwheel.....lol
soon i will move it farther foward tho.
Maidened mine Ssaturday morning..and was thrilled with how solid it was in the air.
im a bit heavy in the nose, very very easy to tip it over. will move the 5 cell RX battery back into the fuse and out from under the cowl.
the retracts are just works of art.....the dont work all sudden like....not a scale speed, but not a slam bam either.
and doesnt seem to land any hotter than the OLD mustang i had. also considering a mini-servo and the radiator cooling door
#252
My Feedback: (16)
TX
Ok a problem i have when i turn on my radio & plane my retracts go up & then down. Also the flaps go down & up, then reset. Iam using a DX-7 radio. What is causing this problem. Any ideas....Is there a setting in the radio thats causing this condition.
#253
AZ
After setting up the radio, you need to re-bind in with the sticks in the failsafe position, and the gear switch down. Once you do that it will behave.
#254
My Feedback: (12)
Thanks Pete, this will certainly help and gives me more confidence for the first flight which, being in the Seattle area will probably be next spring.
John.
John.
#255
My Feedback: (12)
Full down elevator sure indicates a tail heavy airplane but with your CG at 4 1/2 inches back it should be nose heavy - moving the CG back will add tail weight so you may have another issue.
#256
My Feedback: (12)
MT
ORIGINAL: bradyb
Does anyone have install pics of a SA125 yet, I’m wondering how much cowl would need to be cut and where to put the exhaust.
Shane
#257
Thanks Shane, let me know if you find a flex muffler with a nipple and I'll do the same. Anything that comes with a nipple should be great.
#258
ORIGINAL: bradyb
[link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAI450R3D74]header and nipple[/link]
#259
Charlie,
Check out those links ,this will help you to get your retracts to go slower
this is a Sequancer
EMO1042 Gear & Door Sequencer JR/Hitec/Z
www.myatomic.com/catalog/viewsku
MCD881 Go Slo III 3Channel
I ordered both of those I will use go slo for flaps and the sequancer for retracts.
Like every one else I had issues getting this plane together. I still work on it. I broke a rod too,they are dardend,The spinder aluminum part is big time out of balance I spend couple hours to balce it.I will have to add more glue to all points that I can get. and also to reinforce the landing part at the wings.
I have a sugestion for all of us here that deals with this beautiful plane.
I am sure that we will find diffrent things to do this and that. I am working to make the landing gear to be curved like on real scale and use some of the original parts,to put doors at the landing gears. and who knows.
Lets Open a thred whit same name and add How Tooand we will post pictures and how exactly to do it.and directions.
This trad is going to get biger and biger as time goes and will be hard to find what XYZ did for landing gear or how it reinforced the wings.We will have
our little corner of goodies.All the modifications I make I kep record and when I am done I will post the final result .
Thank you all
Adrian
this is a Sequancer
Thank you all
Adrian
#260
Hang in there, I had some of your problems. Iknow is frustrating,and you aspect for every thing to fall in place.But...where will be the chalange.
I curse ,I *****...but looking back on all I did so far...I am happy.I have things to remember when I look at the plane. If all will fall in place....what you'll have to remember.
Your paint job is great I like it. What engine you are using and what proppeler .I will be interested in a 4 blade.I am using a Saito FG20 in mine.
Thank You
Adrian
Thank You
Adrian
#261
RI
Thanks I am going to stick it out I just need a break-Thanksgiving will take care of that for me. I am going electric! Power 110 on 8s, prop is a zinger 17X8.
The paint scheme is my uncles plane, which is another thing that kills meas I have been waiting to do this project for so long i am doing everything in my power and budget to make this right and its killing me slowly.
Like I said I need a break from her-wish i had a cheap simple arf to throw together-maybe time for a foamy to throw together real quick as a break.......
#262
TX
All i did to reinforce my gear bays was mix up 30 min. epoxy and pour it in and roll the wing around to coat the inside.
Up into the leading edge and as far back as it would flow. Both sides of the ribs. I fly off a grass field so it needs to as strong as possible.
As far as the trim....3 clicks on down elly-vader and it was hands off level.
Needed no aileron trim whatsoever.
Was no balloning with the flaps used either.
#264
My Feedback: (12)
MT
ORIGINAL: bradyb
[link]http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAI100T74[/link]
Could write them to be sure which one to use.
Shane
#265
BradyB, If I remember is using an FA125 , and FG20 is based on this,the exhaust is 13x1mm thread.
My guess is to get this and add the little thing for back pressure
Also does any one had a issue with the nut for the prop that come with the plane. My FG20 shaft is M8x125 and I thing that FA125 is same way.The nut that come is standard .In this case you'll need to make one.
Check the aluminum disk for balance.Mine was out and was real shakey.
DO NOT ORDER the recomaded for the right 90 angle ,that is WRONG part #
Correct part is:
http://www.myatomic.com/catalog/view...er_w_nut_ag_ah
And with that in mind BradyB I guess the right exhaust # has to have SAI125
Check below
http://www.myatomic.com/catalog/view...1&q=SAI125A111
Correct part is:
Check below
#269
This looks pretty awsome for the 125 and FG20:
[link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAI125A157]shiny header[/link]
There's a longer version as well.
[link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAI125A156]cooling header long[/link]
#270
OK, what's the trick to finding accesories like that on the horizon site? I could use a header like that for an FG-36, but the site stinks as far as finding anything if you don't already know that it exists or have a part number. Would be nice if there was a tab on the engine page that said 'accessories'.
Sorry for the side-track rant, but if there's a trick to finding this stuff it would be nice to know. Do you have to go to the saito site first, see what's available and get a part number, then go back to the horizon site to find it?
#271
ORIGINAL: ampeater
#272
ORIGINAL: ampeater
http://saito-engines.info/mufflers.html
"The Saito-220 (FG-36) has a 15mm thread. SAI220A143 is the flex pipe part."
#273
ORIGINAL: bradyb
#275
ORIGINAL: Pit-Viper 1
Maybe I'm just not seeing it but how does that mount to the 1.25/FG-20. I see the thread adapter but, hmmm lol
Shane
Shane
