If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 72 of 81 FirstFirst ... 22627071727374 ... LastLast
Results 1,776 to 1,800 of 2012
  1. #1776
    Join Date
    Jul 2006
    laurel, MD
    RE: NEW H9 P51 Mustang 60 ARF
    My flaps now is installed but i dont know how to make it move in the same direction. It works now like an aileron when i deploy.
    Yes, race track is still here, i live a mile away. A lot of people still go there but they no longer have races. Thanks
  2. #1777
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: bboytab
    bboytab.
    In one of your post, you said you have a 8ch Tx. You can hook one of the flap to the flap channel and hook the other one to a open channel. Then you must go into the tx and mix and or slave that channel to the flap channel. Now you have to change from the Y-Harness to servo extension for both flaps servos. Check your Tx manual to see how this is done or ask one of your club member for help. I have this setup for the flaps on my H9 Jackal 50 and did have this setup on my H9 P-51. She die hard!![&o][&o] Thanks for the info on the track!! Let me know if this help!!
    Sonny
    aka
    jet22b
    Spitfire Brotherhood #12
    P-40 Brotherhood #52
    Great Planes Citabria DLE 35RA CC
  3. #1778
    Join Date
    Jul 2006
    laurel, MD
    It did work.... Thanks sonny aka jet22b!
  4. #1779
    Join Date
    Feb 2002
    Vestal, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    bboytab, you need a reversing y
    http://www.horizonhobby.com/products...sm-rtf-EXRA325
    Joe
    If it don't fly it wount cetch my eye.
    Personally customizing model aircraft since 1968.
  5. #1780
    Join Date
    Jul 2006
    laurel, MD
    ORIGINAL: paladin
    Joe
    Thanks joe, i was able to make it work by plugging the flap servos to aux 1 and aux 2 on my 8 channel receiver. I have a Spektrum DX8. It now works but i notice that both the flap servos makes a buzzing sound at normal position. It would go away if i touch the flaps or give it a little load. I did check and there is no binding on both.
  6. #1781
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    bboytab.
    Like I said before, I have this set up on my H9 Jackal 50 and my flaps servos are doing the same thing!! Buzzing like bees!! I took the control rods off and the buzzing would stop. Put the rods back on and the buzzing would start again!! I also check for binding and proper center on both servos, but still could not stop the buzzing. So I fly with the buzzing and had no problem putting the flaps up or down!!
    Sonny
    aka
    jet22b
  7. #1782
    Join Date
    Feb 2002
    Vestal, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    bboytab,
    air pressure will take care of the deployed side. I take care of the clean side by reducing the servo travel one click at a time in the TX ATV function till it stops. usually the delta is noticeable.
    i have a 9503 so idk how to do this on your radio.
    Joe
  8. #1783
    Join Date
    Jul 2006
    laurel, MD
    ORIGINAL: paladin
    bboytab,
    Joe
    thanks.....what prop size do most people use with the blue nose P51 - DLE 20 setup? im thinking of a 15x10 or a 16x8
  9. #1784
    tailskid's Avatar
    Join Date
    Nov 2001
    Tolleson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm currently running a 16/8 on mine, but tomorrow I'm going to try a 15/8 which I've heard is a good combo for the DL20.
    We are here on earth to do good unto others. What the others are here for, I have no idea.
    ~ WH Auden
  10. #1785
    Join Date
    Jul 2006
    laurel, MD
    ORIGINAL: tailskid
    i have a 15x8 on hand but was thinking on getting a 16x8. pls let me know the outcome tomorrow if i'll keep this prop...
  11. #1786
    tailskid's Avatar
    Join Date
    Nov 2001
    Tolleson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Will do! Actually I found TWO NIB 15/8 props today......gotta go thru the inventory more often
    ~ WH Auden
  12. #1787
    tailskid's Avatar
    Join Date
    Nov 2001
    Tolleson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sorry, it was a Master Airscrew 15/6 and it flew not so good....way too much RPM as I tacked it at 10836 sitting on the ground. I'll keep looking for a 15/8 as I've heard they work the best with the DLE20.
    ~ WH Auden
  13. #1788
    Join Date
    Feb 2012
    Ardmore, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi there, Are you still looking for canopy for the mustang?
    I have extra canopy and some other spear parts like spinner tail,rudder etc.
    thanks
    john
  14. #1789
    Join Date
    Feb 2012
    Ardmore, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Shick looking setup.
    ORIGINAL: Jason Lewis
    Cockpit
  15. #1790
    Join Date
    Sep 2008
    Fort Walton Beach, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thank you
  16. #1791
    Join Date
    Jul 2006
    laurel, MD
    Finally, maiden flight last week was good. Half a gallon now to the new DLE20. On the ground, plane noses over easily and on take off run. It was a lot better after moving the battery behind the servos. I still have to hold up-elevator while taxiing and for the 1st part of the take off, slowly releasing once airborne. Once in the air, it flies really good, i just keep the speed up to avoid any chance of stalling, landing was also a bit challenging, have to apply up-elevator on touch down.
    Anyone have this lying around? Need one for the RIGHT landing gear, I may have thrown mine in the trash.
  17. #1792
    Chris Nicastro's Avatar
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I can see from your photo of plane that the gear is too vertical. The way these warbirds like to work best is if the axle is in front of the wing leading edge. From the top view or side view the wheel should be ahead of the wing.
    One way to fix it might be to shim the back fo the retract mech with a washer or wood shim. Do not bend the strut to fix this.
    Once you adjust this geometry the plane will be very stable in all respects when taking off or landing.
    Also another trick is to add a small amount of toe out at the wheels. What this does is to help keep the plane tracking straight and stable. The wheels will pull in opposite directions and this settles the plane when landing. If you touch down on one wheel first it will not provoke the plane to roll over on to its wing tip. Toe in will do this and zero toe causes some nervouse tracking behavior. You can usually adjust this at the trunion in the mechanism by filing the strut flat spot position or carefully twisting the wire strut, either way.
    Like a midget in a urinal I knew I had to stay on my toes...
  18. #1793
    Join Date
    Jan 2009
    Torrance, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Chris.
    You said, "You can usually adjust this at the trunion in the mechanism by filing the strut flat spot position", how do you do this exactly?
    Mike
  19. #1794
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    In a lot of cases there is a set screw that tightens on to a flat on the strut wire. You can file the flat slightly to change the toe angle. If your not comfortable with this then put the strut wire in a vise at the spring coil if it has one. Twist the strut axle just a little bit and do the opposite to the other one. If the axle is the type thats assembled then the flat on the strut can be filed instead. It just depends on how the H9 struts are built.
    I just looked closer at the struts in the photo, are those Robo Struts or did H9 supply those?
    Are the retracts stock H9 or are they Robart?
    When Ive done this with H9 mechanical retracts and Robo Struts I made the toe angle prior to filing the flats on the mucis wire stub. You can use a Sharpie marker to paint black on the music wire. Using the set screws in the strut you can set the angle and mark the wire. Then you file the flat and adust it as needed until you remove about 0.5-0.75mm to make the flat. This is pretty easy to do and since it requires cutting the supplied music wire struts you will have spare material to make another one if its wrong.
  20. #1795
    Join Date
    Jul 2006
    laurel, MD
    ORIGINAL: Chris Nicastro
    I will definitely try shimming the retract this time, I have maximum toe out with the stock strut flat spot, will also need to file to get more toe out. Thanks Chris!
  21. #1796
    Join Date
    Aug 2008
    Christchurch, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: bboytab
    Finally, maiden flight last week was good. Half a gallon now to the new DLE20. On the ground, plane noses over easily and on take off run. It was a lot better after moving the battery behind the servos. I still have to hold up-elevator while taxiing and for the 1st part of the take off, slowly releasing once airborne. Once in the air, it flys really good, i just keep the speed up to avoid any chance of stalling, landing was also a bit challenging, have to apply up-elevator on touch down.
    Nice to hear that it flys really well (when flown with the speed up).
    How did you go with throttle cable positioning and what route did you take? .... are you able to post pics of the direction you took? (was considering a pivot arm myself, but can't see on on yours)
    Raptor 50 Nitro heli - OS50 Hyper
    56\" Yak54 w/ ASP.61 2 stroke, 73" gas Sbach 342, H9 P51 blue nose in progress (with DLE20)
  22. #1797
    Join Date
    Jul 2006
    laurel, MD
    ORIGINAL: kiwibob72
    ORIGINAL: bboytab
    I just have the setup in the manual, just needed to cut the plastic clevis shorter so I will achieve full throttle/travel by not hitting the firewall.
  23. #1798
    Join Date
    Feb 2012
    Ardmore, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I seen your throttle setup.get a TBM troybuiltmodels carburetor throttle arm for dle-20 its a great buletproof gadget
    you need to cut off the length of the arm some to fit it perfect
    the chep chinese arm got complitlly came got loose from vibration after 10-15 flights.
    ORIGINAL: bboytab
    ORIGINAL: kiwibob72
    ORIGINAL: bboytab
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  24. #1799
    Join Date
    Jul 2006
    laurel, MD
    Any tips on how to avoid this? http://youtu.be/SIXEEpc7OHw
    My blue nose is only 2 weeks old but has been flying really good except its hard/impossible to make a smooth scale like take since i needed to hold elevator and should release at the right time to prevent nosing over. I almost crashed today during my 1st take off, just like on the video, luckily i was able to save it. I think i needed more power/speed during take off and release a bit of elevator at the right time. There was also a bit of crosswind today.
  25. #1800
    Join Date
    Feb 2012
    Ardmore, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Need more speed on take off
    the plane should lift up its own.
    Go to the far end of that field so you won't run out of runway.
    also on that video the engine sound like a small nitro
    bedt setup Dle-20 jtec raparound muffler
    a light 16x8 prop.(powerhouse)
    unless saito 125 (more unforgiving you add more weight to the plane
    good luck!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
