NEW H9 P51 Mustang 60 ARF
#1878
No 3D for me. Just a scale type flyer. And this will be the largest plane I've built & flown. My experience with glow engines went as far as a Precedent Low Boy about 20 years ago!
Just been flying helis & large foamies since so I will need to be on top of my game flying this thing!
#1879
MI
Paul, I did all the mods on mine, and it really flys nice. You have to be carefull on take off, and stay ontop of elevator. Mods included; moved the tank back, shimmed gear forward, put upper mount on tail wheel, reinforced gear and firewall. I did not glue wings together. Also hooked up radiator scoop to throttle servo. Mine's a little underpowered with saito 91, but only small holes in cowl where front of valve covers show. And It's lighter with less motor. would post pics, but can't seem to with my smart phone for some reason.
#1880
Thanks Hemiflyer1
Regards the cowl and engine, I am keen to use the Tony Howard, Pacific Scale Air Filters & Exhaust stacks.
I don't suppose you'd know if the RC Specialties http://www.rcspecialties.net/products.php?model=TH13X1A would fit without cutting the cowl ?
Looks like the Keleo http://www.keleo-creations.com/index...roducts_id=207 exhaust stack system works but expensive & I don't think it looks as neat as Tony's dummy exhausts.
I don't have a problem cutting the cowl for the valve covers (looks cool) but I'm loathe to cut that third ugly hole for the muffler elbow if I can help it.
#1884
TX
i used JR ST47's in all applications on mine and she flew flawlessly. The control sufaces on this plane arent that big, and the control throws arent that big.
#1885
TX
actually yeah i do. they make 43oz torque at 4.8V.
would make even more, just a couple more oz @ 6V
i've been using 6V batterys in my planes for a while.
the 5 cell 2000mh hydramax http://www3.towerhobbies.com/cgi-bin...&I=LXNHS4&P=ML
#1889
My Feedback: (28)
I've been using these in my 30cc MXS-R and they have been solid. Using a power expander to run dual lipos too.
http://www.redwingrc.com/index.php?m...1oc2mr563jk1v5
#1890
#1891
Anyone know if the rudder is all one solid piece or is it sheeted ?
Not game to poke mine around enough to find out.
But if there is enough meat down the bottom I am just going to use CA & three decent SS wood screws to fix the control horn and skip the backing plate.
Would look heaps neater, avoid drilling at that insane angle & also save a tiny bit of weight.
#1892
AB, CANADA
Well mine finally flew it's maiden. Dle20 w/ a 15x10 at about 8400rpm at 3000'asl. I did a lot of whining as I was putting this arf together, however, after today I seemed to have forgotten most of the frustration. I did all the mods and strengthening recommended, thanks all, and it took off and flew excellent with only a few clicks of down elevator. It was blowing somewhat cross wind at 15k so not too bad and the 51 handled it easily. Mine came in at 11.1lbs using one 2500 a123 battery and an Ultra IBEC running ignition. Again, thank you to all the initial builders of this arf and letting us know it's good and bad points.
Paul I'm not sure if the entire rudder is built up, but there is a block, I think balsa, in the bottom corner but I am not sure I would trust screwing into just that. It may work though.
#1893
Hey Danorn;
Congrat on your maiden flight !!! I may have to pickup one of the Hangar 9 Blue Nose P-51, before they take it off the market!!
Again, congrat on your maiden flight!!!
Sonny
aka
jet22b
Sonny
aka
jet22b
#1896
My Feedback: (26)
I read all the posts on this plane and it appears the con's outweigh the likes. I did this knowing that it would be compared to the TF P-51 which I'm getting ready to maiden. It is my opinion that HH is not at fault for all the crashes put the fault lies with the pilot in control. Wing loading has not been addressed by any of the posters and I believe that is the root cause of the all the crashes.
#1897
Hi flycatch,
I've been reading all the disasters people have experienced with this model. Interesting.
I have a spare Co Pilot II that I am tempted to add to this plane. Not sure if that would help or be a bigger hinderance especially on the ground, takeoff & landing.
Works great on my helis but I guess it would only try to counter any tip stall with ailerons and make matters worse!
Haven't tried the Co Pilot II on a plane yet. Tail Draggers are a bit different too as it always attempts to maintain a straight & level attitude
#1898
AB, CANADA
Thanks Paul, the dle performed well swinging the 15x10. Plenty of speed and power if needed.
Flycatch, I believe the majority of cons, certainly mine, were from the construction side and not the flying. Putting it together properly took a lot of work for an arf. I have built and help build many warbird kits and they were not near the pain this girl was. I agree that lots of crashes come from not flying properly and respecting wing loading is vital on a warbird. That being said, I don't like "foamy" feeling planes and appreciate a well flying P51.
#1899
I've heard the DLE20 is a good engine. I almost went with that over the Saito FG-21 but I found a dealer selling the FG-21 at cost price.
Didn't get me far. Now I need to shell out another $100 for an exhaust that will work without cutting the cowl up too much !
