Reload this Page >
ATTENTION: All Top Flite Corsair, P-40, ROBART 615 & CJM Retract Owners !PLEASE READ!
Old 10-08-2004, 03:18 PM
  #676
Robinaire
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Reponse from Sierra
Hello Don et al; I have known Bill at Spring Air for many years, and had dealings with him, with never a problem! He's "good people"!! Lee Robinson; Robinaire
Robinaire is offline
Old 10-08-2004, 11:54 PM
  #677
Tsutomu Mabuchi
Tsutomu Mabuchi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Update
I have not read all of this thread thoroughly, but CJM TF P-40 I just
received moves 95 degrees to extend which Bruce Sanders from CJM
modified instead of 90 degrees. You need to specify 95 deg. of move
when ordering, though. Even 100 deg. will be accepted I guess. but
he said 100 deg. is too much.
And one of two pressure nipples seems to have been modified lately.
Tsutomu Mabuchi
ID:	180889   Click image for larger version
Tsutomu Mabuchi is offline
Old 10-09-2004, 06:18 AM
  #678
LDM
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Update
Tm Hows is your P40 coming along ? Nice tip on the gear
LDM is offline
Old 10-09-2004, 07:36 AM
  #679
juvatwad
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Update
Those plastic nipples on the cylinders really annoy me. I have broken several simply slipping tubing on them. I wish all the fittings were brass.
juvatwad is offline
Old 10-09-2004, 09:08 AM
  #680
Tsutomu Mabuchi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Update
ORIGINAL: juvatwad
Have you? I worried about such things when I saw the plastic fitting instead of brass.
Old Robart 615 had also plastic base fittings on the cylinder. I have broken one of them
when I pulled the tubing off the fitting. The fitting came off together from the cylinder.
I don't know why CJM replaced it with plastic one.
I placed an order for this retract to CJM directly requesting 95 degrees movement.
Mr.Bruce Sanders, CJM, accepted the modification with pleasure.
None of distributors have this CJM 95 degrees retract, only 90 degrees one.
By the way, how did you fix the broken plastic fittings or did you need to replace the
whole cylinder?
Tsutomu Mabuchi
Old 10-09-2004, 09:14 AM
  #681
Richard L.
My Feedback: (24)
Richard L.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Update
Actually, the CJM retracts on my Corsair and Hellcat are around 92-93 degrees.
Richard L. is offline
Old 10-09-2004, 10:02 AM
  #682
juvatwad
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Update
I purchased brass nipples to replace the plastic fittings. You can buy them from CJM or Robart, but I believe they should be standard equipment.
juvatwad is offline
Old 10-09-2004, 08:28 PM
  #683
Tsutomu Mabuchi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Update
ORIGINAL: Richard L.
My CJM for Wing Mfg. F6F Helcat which I perchased several years
ago looks just perpendicular to the base mount. ( my F6F is still in the
box so I don't know if the retract needs more than 90 degrees)
CJM retracts may be developping year after year.
( I'm sorry my english may not be correct)
Tsutomu Mabuchi
Old 10-10-2004, 05:08 AM
  #684
LDM
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Update
I agree with the plastic fittings as a problem , its my only issues with CJ gear .
I am curious to see how spring air will compare in this market . I have not heard one thing bad about any of there gear . Many pattern flyers have used them for years .
LDM is offline
Old 10-10-2004, 08:27 AM
  #685
cap10fan
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have seen the Sierra gear mounted in the Corsair. They retract at 100 degrees. This puts the axle at or just forward of the leading edge of the wing, just like the real thing. It should also help with any nose over tendency.
Todd Coleman
cap10fan is offline
Old 10-13-2004, 08:26 AM
  #686
ffdq
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
can any one tell me if darrell,s new gear work on a giantscale planes hellcat.thanks fred
ffdq is offline
Old 10-13-2004, 09:28 AM
  #687
Richard L.
My Feedback: (24)
Richard L.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What we need is the distance from the front edge of the retract mechanism to the axle, and I will be able to tell you if the gear will fit the GSP Hellcat.
Old 10-15-2004, 05:50 PM
  #688
strnglvr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello All, I just recieved my retracts from Darrell (sierra), I keep slobbering on them, in oneword,....WOW! I do believe the retract problems are over. Darrell, GREAT WORK!!!! i don't have a pic. but you know what they look like,.....Thank You Darrell, you did a fantastic job,...well worth the wait, I'd be putting them in now, but my son's engine bit it,....priority's,.............I'll let you all know how they work when i can get to it,....Later,........Paul
strnglvr is offline
Old 10-19-2004, 08:56 AM
  #689
nauticom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
strnglvr
That sounds great.
I am one of the first 20+ people who signed up with a deposit (actually, I'm # 13), it seems like 2 years ago. Anyway, my question--does that mean I would be getting the 13th set from Darrell (Sierra)?
Anyone know his distribution plan(s)
strnglvr, Were you a early joiner in this long birth?
Bob Masterson
nauticom
nauticom is offline
Old 10-19-2004, 09:17 AM
  #690
voyager_663rd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: nauticom
Bob Masterson
nauticom
Bob, I think you got your deposit in before strnglvr.
voyager_663rd is offline
Old 10-19-2004, 11:50 AM
  #691
dionysusbacchus
My Feedback: (25)
dionysusbacchus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow, looks great. Now if he can offer a pair without the training wheels I'll take them, the forward rake is far to much and would look silly on a Corsair. Still waiting....
Dion
dionysusbacchus is offline
Old 10-19-2004, 12:01 PM
  #692
nauticom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
voyager_663rd
Thanks for the input. I just sent off an email to Darrel regarding my slot in the production line/process. Hope he responds. I'm assuming I owe him another $150. He also make a comment to the original people who signed up that he would make it very much worth our while with some kind of freebie. Thats all I remember
Here's hoping I can get this product during this fall's building season.
Bob Masterson
nauticom is offline
Old 10-19-2004, 01:54 PM
  #693
cap10fan
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was in to see Darrel this afternoon. He is packing and shipping retracts just as fast as he get them assembled. Without the use of any cast plastic parts, there is quite a bit of hand assembly work involved in the gear. They are worth the wait, as those that have received theirs can attest.
Todd Coleman
cap10fan is offline
Old 10-19-2004, 03:35 PM
  #694
hattend
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: nauticom
voyager_663rd
Bob Masterson
You got an answer to your email? I guess those of us who bailed out after a year are on a "do not answer" list until he gets caught up with those of you who stayed the course.
Oh well, come on SpringAir
Don
hattend is offline
Old 10-19-2004, 04:22 PM
  #695
voyager_663rd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: hattend
Don
Hey, Lee is closer to the finish line than Spring Air
Old 10-19-2004, 05:03 PM
  #696
hattend
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: voyager_663rd
ORIGINAL: hattend
Don
Heheheheh...point taken.
Come on Lee (and SpringAir)
Don
PS: Lee, please PM me. I want to get on your wait list, if you have one.
hattend is offline
Old 10-19-2004, 09:03 PM
  #697
strnglvr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello All, I don't know what number I was, but i was pretty close to the first 20 if not in it, but I sent darrell 250.00 from the begining for a complete set, did anyone else pay for a complete set up front? and let it ride for a year and ahalf, then reading all the bashing of darrell, i got cold feet, and he sent it back, then within a couple of days darrell posted the food for thought pictures, and sent it right back to him, and waited tell he finished them, Paul
strnglvr is offline
Old 10-20-2004, 03:57 PM
  #698
nauticom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hattend
No, I have not heard from Darrel yet; I'll wait the course, after all this much. I'm assuming he will contact me for my additional $ when he is about to ship! Or maybe the squeaky wheel gets all the attention?
I'll keep the faith.
strnglvr
thanks for the FYI
Bob Masterson
nauticom
nauticom is offline
Old 10-20-2004, 04:59 PM
  #699
Robinaire
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Voyager & gang; I talked to my friend Bill Watten up at SpringAir today, and you all sort of caught him off guard. He wasn't sure how genuine the need was. I assured him that you were all looking for alternate sources, in spite of Darryl getting out first. So he will look into it further, including revisiting one he did some time back, albeit smaller. So we will both be working on alternatives. I went down to the cnc shop Monday, and Jay & I had quite a discussion on a variety of parts, not just this project. I am just getting snowed trying to do everything myself, so must get help!! I believe my lack of 4 arms and 48 hour days may have something to do with it! I'll keep all posted. I posted this answer here because I got a msg. Maybe I should put it over on my thread. But I figure you would all see it anyhow. Will keep all posted on progress. Lee Robinson
Old 10-20-2004, 06:38 PM
  #700
voyager_663rd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lee, you know that I'll wait for what you have got coming. I've put my building on hold for many many months so I can build around the gear and sp I started other stuff while waiting so this gear is not too much of a priority (although EVERY plane really is a priority--you know what I mean). We all waited for so long for Darrell to get with it and with no comms, I think most just wrote that option off. Now that he's back with something, well it's difficult to know which way to go.
I'm sure I speak for quite a few when I say that after you stepped up to the plate, we certainly owe you. You talked to us, you answered questions, and have been out in front with the community. And because of that, I"ll stick with you. WIth the type of community that this is, I would hope that Darrell accepted the (negative) comments that people posted and not turn sales away because of that.
I don't have a bird to put your (or any) gear in because I stopped building till something was available. And I will still wait to hear about results of installing either Darrells or your gear when they are made available to the community before I make a buying decision.
Thanks for your comms and status reports Lee. In my opinion, that would be a deciding factor, everything else being equal.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
