NEW Top Flite .60 P-47D Gold Edition ARF
#226
RE: NEW Top Flite .60 P-47D Gold Edition ARF
*LOL* I'd have to compare the weight of the motors. The E-Flite Power 90 is pretty heavy, but I make my own motor mounts out of aluminum. Attached to the motor mount is my Turnigy 100amp ESC. Like you, I'm using the shelf and sliding the batteries to the firewall - using the two Turnigy 5000ma 4s and 1 Turnigy 3000ma 2s (For the BEC).
With that configuration - I haven't checked the weight that needs to be added, but it won't be much - it's very close, but especially with the maiden flights I prefer to be safe and adjust later... made that mistake once and won't repeat it..
Plus the Power 90 has plenty of power running 8 cells.. Sitting here with 3 planes waiting to be maidened... and getting ready to start the build on a Ziroli Stuka and Ziroli P40... (crossing to the dark side on those and going gas).. Trying to avoid flying the P47 until after a Feb static display show...
Chuck
Chuck
#227
My Feedback: (22)
Ok now I feel better chuck!
are motors are very close to the same wieght and I have a heavy motor mount... sounds like I'll be fine
Thanks Chuck
good luck when you maiden her.. it looks great
Top Flight has done an amazing job with there ARF's... make my hanger 9's look silly
Ron
Thanks Chuck
Ron
#228
ORIGINAL: kurrikan
Hi everybody ,here i let you some pics of my favourite plane,waiting for the electronic devices and retracts.
#229
ON, CANADA
Sierra,
I have not done detailing myself on monocoat however from what others have done I've seen marker lines and dots to represent panel lines and rivets. Also some people have done very well at creating weathering.
See Top-Flite.com for some tools and try the RCU search engine for some threads.
Dave
Dave
#232
ORIGINAL: maddingo
Sierra,
Dave
Sierra,
Dave
#233
ORIGINAL: Sierra11861
Do they not have a delete your own post option on this board?
#235
ORIGINAL: bushong572
I test flew mine yesterday.......... This could be the best flying warbird I've owned. I was worried that a .91 would not be enough engine. I think it's perfect.
Thunder Tiger .91 four stroke
APC 14x7
10.4 lbs dry
APC 14x7
10.4 lbs dry
Ed
#237
Just finishing up the wing construction. So far this ARF is very impressive. I am knid of taking my time building to savor the moment
#238
Woah, finially finished the wing. That seemed like it was a lot of work for a ARF wing. I suppose it was the flaps servos and landing gear that added a lot.
I hollowed out the center rib downward about 3/8" and installed the servo tray much lower in the hole so that you did not have to bend the wire to attach to the servo arm. I think it works better than if you had to bend it, but I don't know since I did not install it with the bends as the directions show to do. There was definiately some confusion on where the servo arm needed to start out. Directions a little vague but I got it handled. My advice is to operate the servo arm gently by hand to get it in the ballpark before you hook it up to your transmitter.
#239
ON, CANADA
Hey guys,
Im slapping a G20EI on my bird and of course this engine has its own mounting plate and the holes dont line up with those put in the firewall. So I have two challenges.
1. How do I know where to exactly mount my engine? What do I use to line it all up perfectly?
2. Once my holes are in the fire wall are made, there are those metal screw holders inside the firewall, how do I get ride of those???
Any help would be great.
Thanks.
Dave
Thanks.
Dave
#240
For the electrics I just line the center of motor dead center with the large hole in the firewall. Draw a vertical and horizontal line on the firewall dead center through the hole... then you can square the lines to match your new motor mount holes..
You can remove those metal thingys.. (LOL for the life of me I can't remember what they're called now) with a screw driver - they may have some epoxy on them too - but they'll pop out easily enough.
#241
ORIGINAL: maddingo
Hey guys,
Thanks.
Dave
Hey guys,
Thanks.
Dave
#243
My Feedback: (90)
Looks like the other 'build thread' got trumped by this one. If iterested, more details of mine can be found here:
http://www.rcuniverse.com/forum/m_88...tm.htm#8886011
A well hidden Saito 1.00 GK swings a Master Airscrew 15 x 7. This setup is really more power than I need, let alone use (servo not setup to fully open throttle). A .91 would have worked just as well, I just happened to get a really great deal on the 1.00.
All 3 wheels retract, mains have #650 RoboStruts (no offset/ scale), functional Vortac bomb drops, and still just ever so slightly over 10 lbs (without fuel and 'ordinance'). Main retract units are stock ones, it uses 1 hi torque/ lo profile PROPORTIONAL servo per retract, which are realistically slowed down via Futaba 12FG programming.
First flown in August, 2009, it depicts a P-47D-28-RA (Evansville, IN built) flown by Lt. Robert A Laho.
[youtube]http://www.youtube.com/watch?v=3LJxPYYiKFo[/youtube]
[youtube]http://www.youtube.com/watch?v=H7_qtPhTD9s[/youtube]
#245
Finally finished! Nothing too exciting here, pretty much a spec build. I did paint the cockpit, no pilot though but I can add one later on. Will post some pics when I get a chance. Just snowed 6 inches so it looks like I will have a while before maiden flight..
#246
Hey Maddingo,
Let us know how the G20 works out in this thing. I'm really interested as I have an RCFG 20cc gasser, rear carb that has no home at this time. I'm a little concerned that the TF P-47 with a 63" wing span might be too small for this engine. I've seen gassers installed in the Hanger 9 P-47 but it is bigger with a 65" wing span.
#247
ON, CANADA
RBEAN,
At this time my build is going well. The fuse is glassed and the wings are now together being glassed this week with tail feathers, ailerons etc.
To make it all fit in the cowl the G-20 is fitted with a 90 degree carb intake bend from TONI CLARK and the muffler from Bisson here in canada. Now the two are up against each other and Ill have to make some kind of adjustment.
However being up north and the time I am away from home I can only hope this model will fly this year. But I would bet on 2011.
Any how im now playing with flite metal and I plan on making this a Jackys Revenge P-47. The cowl with diamonds will be tough. CJM retracts in the wings.
Best.
Best.
#249
ORIGINAL: rino
Hi,
Can anyone comment on the stock retracts. I'm not worried about scale looks. Do the stock retracts hold up. Do they work well?
Thanks!
Hi,
Thanks!
#250
My Feedback: (121)
CA
Thanks. That's great news. If this plane can fall in the 10 pound range it might be a really nice flyer. I was thinking of the OS 120 AX for power.
