Brian Taylor 83" Spitfire MKIX
RE: Brian Taylor 83
Hi!
I'm also building the Brian Taylor 83" Spitfire. I see that you are using a big 50cc engine, Brian Taylor used a 1.50 four stoke in his... Why such big heavy engine like a 50cc gas engine??? ...and you really sure that it will get enough cooling???
RE: Brian Taylor 83
Another BT spit....wow I don’t mean to speak out of turn here, but the 50 will have plenty of cooling Vic of Vic R/C did it years ago with no problem. Why put the gas 50 in? Well for me it’s because I have been glow free for 2 years. You should start yourself a built thread. I always like to see what others are doing on a bird I am building.
#33
RE: Brian Taylor 83
The Moki 1.8 (30cc) in my BT Spitty gives great performance, that said Iam now leaning toward trying a Saito 200Ti simply for improved "sound effects".....
50cc ?? would be ok if your planning on Space Shuttle like departures and some 3D hovering I guess
#36
RE: Brian Taylor 83
ORIGINAL: Thunderbolt47
Big engines turn big props or little fast ones
#37
RE: Brian Taylor 83
Hey Jet, If your talking about a Glow engine remember I don't run glow anymore. I don't have access to glow fuel where I live. I'm not traveling 60 miles to buy glow fuel and it's to expensive to ship.
BTW my G-62 on my Mustang has spanked several of the Moki 60CCs on other mustangs.
#38
RE: Brian Taylor 83
Well Here's a little progress. still waiting on my order of supplies. So I decided to tackle the gear covers. Just a little bit of putty to blend in the blisters for the axle clearance and that's done.
Kelly
BTW the zip ties are temporary
Kelly
#41
RE: Brian Taylor 83
OK today I worked on the cowling. I had to add some material back to fill in a big hole and make it fit and look better.
I also cut a 2" hole for air to enter the cowl. I put the letter H in the hole to camoflauge the hole. A lot of spitfires had a black circle with a white letter on the cowl so hopefully this will fool the eye. It sure doesn't fool the camera with a flash though. After I put in the baffle and paint it all black it will really look good then. NOTE: this "H" is only a temporary one. Just testing.
I will be (hopfully) venting the hot air out threw the wing. I didn't want to mess up the lower cowling anymore than nessesary, so I came up with this. There is a tunnel in the fuse to channel the air out. The outer holes will get lovers on them ( to help pull the air out) and the holes on the scoop will not have any.
With a good tight baffle it should get plenty of cooling air in (1) and plenty out (3x).
Still haven't dicided on an exhaust yet. (?)
Kelly
Kelly
#42
RE: Brian Taylor 83
I finally worked some more this weekend. I got the canopy mounted. I have to make the rear part of the canopy out of a 2 liter Pepsi bottle. It will get trimed with foil tape to make a "frame".
I will be using button head screws on most of the parts. The allen head servo screws hold up to the in and out of mockup better that the button heads do.
I have all the control surfaces hooked up, except the flaps. hope to get to that this week some time.
Also mounted the ignition switch. sorry no pics of that.
With 3 servos in the tail it is still going to be nose heavy.
17.11 lbs so far.
Kelly
17.11 lbs so far.
Kelly
#44
My Feedback: (9)
CT
RE: Brian Taylor 83
Not to be critical but I noticed the scissors of your struts are in the wrong direction. They should be pointed to the leading edge. Nice work and you can't go wrong with the 50cc, you will have one fast airplane with the weight she is coming in at. Best,
Moggy
Moggy
#46
RE: Brian Taylor 83
Tfarmer, I beleive it's a Tru-turn. That's not what's making it nose heavy. The glass cowl for this thing is heavy. also those copper elbows are pretty heavy. I still haven't installed a muffler yet!
Moggy, I did not know that. I will see if I can swap them out without to much trouble.
Kelly
Kelly
#48
RE: Brian Taylor 83
Hey Moggy, I was looking at some pics this morning, and they are facing forward. (not that I doubted you) Just hadn't ever payed it any attention.
The good new is they swapped around with no problems at all.
Thanks for that one. That would have been sooo embarassing to show up at the field with my sissors pointed the wrong way
Thanks agian.
Kelly
Thanks agian.
Kelly
