Reload this Page >
Meister 1/5 scale P-47
Old 01-24-2015, 03:43 AM
  #1851
freddd
Gary,
at at the end of the process, do you spray clear over the aero-foil or leave it as it is. If clear, is it satin ? If no clear, how fragile is it ?
thanks
frederic
Old 01-24-2015, 08:05 AM
  #1852
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
Originally Posted by Prekin
Hi Gary,
thank for the series of your picture with Aerofoil. How do you apply this foil on the airplane´s surface, with some special glue? Or it is some normal foil as Monocote covering films?
I try to find some this foil but without any success.
Hello. The foil is self adhesive. You simple press it on and then rub it with a tool to 'burnish' it on to the surface.
Here is a link to the area on the Meister web site to find it. There are other sources for similar products but I prefer Dino's service and Areofoil for it is slightly thinner than most other products. Easier to form around compound curves and such.
http://www.aero-accessories.com/Builders.html
Old 01-24-2015, 08:16 AM
  #1853
Prekin
My Feedback: (19)
Prekin's Avatar
It looks like pretty easy. Thank you Gary
Old 01-24-2015, 08:25 AM
  #1854
ram3500-RCU
My Feedback: (221)
Originally Posted by freddd
Gary,
thanks
frederic
Good question Frederic. We debated this 6 years ago when we first started using foil. In the end, we decided NOT to clear it in any way. As a result our aluminum has been able to 'weather' naturally, and IMO, it gets better looking every season. When first applied, you will want to sand it with a good 400 wed / dry to give it an initial weathered look. If you don't, the aluminum looks more like a new F-86 than a WWII fighter in the fight. I mask off panels and sand them in opposite directions. This gives them an individual character.
Now you can clear it and this will give you an instant weathered effect. I have seen it done with satin and flat. I personally don't like it. Might as well paint it with silver IMO.
Nomenclature. Yes, if you don't protect it with clear is is vulnerable. I ask, did they clear over the original? No. Dry transfers are paint anyway. In time, they will get some abuse, but again, so did the real thing! Patina, I think they call it. When we get a rub, scratch, small ding, or loose a letter, great I say!!!!! More Patina!!!! Looks better all the time.
The adheasive on this stuff is tough. You don't want to have to pull it off. It is durable for years of use even in areas around exhaust and fuel. Even more so than some kinds of paint. Plus detailing the surface (rivets, fasteners, panel lines, hatches, etc) is much easier than with paint.
Another debate that raged for awhile was the possibility of radio interference due to the all metal covering. This has been proved a non issue.
Old 01-24-2015, 08:31 AM
  #1855
ram3500-RCU
My Feedback: (221)
Just keep in mind, this stuff is .0012 thick. Thinner than paint. Everything you see or feel on the surface prior to application, will translate right through. You want to prepare the surface just as you would for paint, including the tack cloth or dust removal. Then you are ready to apply the foil.
For access panels, non moving hatches, etc, I use 2" HVAC aluminum tape from the hardware store. It is thicker and does a good job standing out. Goes on the very same way. Look for the kind that doesn't have brand name writing on the outside.
Old 01-24-2015, 10:12 AM
  #1856
freddd
Gary,
thanks for the information. This makes a lot of sense to me. It is interesting that you note how strongly this sticks. I was concerned that paint masks would pull on the foil when removed.
thanks again
Frederic
Old 01-24-2015, 11:31 AM
  #1857
ram3500-RCU
My Feedback: (221)
Gary,
thanks again
Frederic
yes, adhesion is every bit as good as paint, if not better.
Old 01-25-2015, 09:05 AM
  #1858
ram3500-RCU
My Feedback: (221)
Firewall done. Cowl flap assembly done.
ID:	2067618   Click image for larger version
ID:	2067619   Click image for larger version
Old 01-25-2015, 02:26 PM
  #1859
ram3500-RCU
My Feedback: (221)
Bolted the cowl flaps on this time. 2-56 X 1/4 stainless steel machine screws.
Old 01-25-2015, 02:34 PM
  #1860
ram3500-RCU
My Feedback: (221)
BTW, Chromate Green, or Chromate yellow? Here is the way to tell.
The RE units, manufactured at the Farmingdale plant, had Chromate Yellow. The RA units from the Evansville plant had Chromate Green. Some colors were changed in the field, but this is the way they started out.
Old 01-28-2015, 11:13 PM
  #1861
ram3500-RCU
My Feedback: (221)
Thought I would post a link to the new Solo Prop company. The new owner is Patrick Wallace. I sent him an email to inquire about his new operation, in the middle of the night (some of you know my hours :-)), hoping for a responce maybe the next day. It came in just a few minutes!!!!! A very thorough explanation of his new operation, what he can do for owners of the older props, and his lead time goals. all very promising.
http://soloprops.com/meet-the-new-owners
Old 01-30-2015, 08:01 AM
  #1862
Caveira80
Caveira80's Avatar
I´ve done an entire P-47 (top Flite) with Aero-Foil and the result was great... no clear or any other finishing just burnishing with a steel wool in several directions as RAM did.
I´ve also used waterslide decals which found out very durable, only the USAF stars were painted. all the other markings are decals and they were perfect
the only issue is that the surface must be very strong using fiberglass & hobbico cloth... I dont know what I did wrong at that time but my surface was not 100% rigid... so, the aerofoil would wrinkle in few parts, and even small bumps and scratches would scratch it...
but the finishing itself was awesome!
Brazilian Air Force... =)
ID:	2069111   Click image for larger version
Old 01-30-2015, 05:45 PM
  #1863
ram3500-RCU
My Feedback: (221)
Thank you Caveira80 for the information. Helpful I'm sure.
We use 1/4oz glass cloth from Ziroli. Good price and good quality.
Old 01-30-2015, 05:52 PM
  #1864
ram3500-RCU
My Feedback: (221)
Hinged the main service hatch on the fuselage.
ID:	2069217   Click image for larger version
ID:	2069218   Click image for larger version
Old 01-30-2015, 05:56 PM
  #1865
ram3500-RCU
My Feedback: (221)
tail wheel unit with the Down and locked electric conversion before it is glued it with Hysol.
ID:	2069220   Click image for larger version
Old 01-30-2015, 06:18 PM
  #1866
tailskid
My Feedback: (34)
tailskid's Avatar
Nice work!
Old 01-30-2015, 07:09 PM
  #1867
ram3500-RCU
My Feedback: (221)
Originally Posted by tailskid
Nice work!
Thanks tailskid. I labored on whether to hinge on the top, for more scale appearance, or on the bottom, to be more user friendly. opted for the top hinge, and I am going to include a prop.
Old 01-30-2015, 07:24 PM
  #1868
tailskid
My Feedback: (34)
tailskid's Avatar
How are you going to keep it closed? And what are you going to use to open it?
jerry
Old 01-30-2015, 07:31 PM
  #1869
ram3500-RCU
My Feedback: (221)
jerry
Good question Jerry. Thank you. Normally, I would make some sort of mechanical latch. However, in this case, I'm going to use earth magnets and a small bump of aluminum at the bottom as a finger grip to pull it open. I hesitate to use magnets where air pressure in the fuselage can push the hatch open, but in this case, the area is completely sealed from inside air pressure.
Old 01-30-2015, 07:36 PM
  #1870
ram3500-RCU
My Feedback: (221)
Some pictures as the tail went together. Horizontal stab being glued in.
ID:	2069241   Click image for larger version
ID:	2069242   Click image for larger version
Old 01-30-2015, 07:38 PM
  #1871
ram3500-RCU
My Feedback: (221)
Got the HV valve that Dino sells for the air system. This micro processor controlled air valve will plug directly into the Down and locked control box and control the main gear doors. Pictures soon.
Old 01-30-2015, 07:59 PM
  #1872
ram3500-RCU
My Feedback: (221)
Remember the rudder install earlier.
ID:	2069250   Click image for larger version
Old 01-30-2015, 10:41 PM
  #1873
ram3500-RCU
My Feedback: (221)
Ran across this picture of Zombie in the hanger from a couple years ago.
Old 01-31-2015, 12:06 AM
  #1874
ram3500-RCU
My Feedback: (221)
More of the tail group before it was mated.
ID:	2069282   Click image for larger version
ID:	2069283   Click image for larger version
ID:	2069284   Click image for larger version
ID:	2069285   Click image for larger version
Old 01-31-2015, 08:12 AM
  #1875
ram3500-RCU
My Feedback: (221)
Video on setting up the tail gear with the Down and Locked electric conversion.
http://www.youtube.com/watch?v=iYOCJ...ature=youtu.be
