MOKI RADIAL Care and Maintenence
Reply
Old 05-20-2017, 05:44 PM
  #3951
badangle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Having problems with rC universe....what changed?
badangle is offline
  #3952
badangle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not getting notifications?
badangle is offline
Old 05-20-2017, 05:45 PM
  #3953
badangle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Couldn't find my way here at first
badangle is offline
Old 05-28-2017, 12:51 AM
  #3954
docgboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does anyone know the size and length of the bolts that hold the head to the crankcase. Also Mcmaster carr shows vibration resistant bolts that appear to be a good idea for this situation.
Scott
docgboy is offline
Old 06-06-2017, 07:35 AM
  #3955
badangle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Mounting Moki 180 ?
I have been reading a post on building the Meister Scale Zero. Unfortunately post ends before engine install. I would like to know if kit must be modified at firewall to accept Moki 180 radial.
the post shows an engine box up front but I think it was a modification...not sure as I am waiting for kit and plans. Any photos of Moki 180 mounted to firewall would help me to visualize hookup.
Thank. george
badangle is offline
Old 06-06-2017, 01:13 PM
  #3956
TimD.
TimD.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank. george
Hi George. I am building the same plane combo. Yes I had to build the firewall out. Mine has the glass fuse. The firewall is a flat blank piece of plywood. I will get you a picture tonight. Mine is about 2/3 built at this point.
TimD. is offline
Old 06-06-2017, 02:07 PM
  #3957
badangle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the reply Tim.
do you have any general advice for first time GIANT scale project? I fell in love with moki sound and always wanted a big fighter....so as a retirement present to myself i decided to go for it
Before I'm too old. ..I just finished ziroli Stearman with 7 cyl. Glow radial but have not flow it yet....want to practice flying as I do more building than flying..but I have no experience with retracts or dual batteries and servos...nothing on this scale...want to check it off my "bucket list" and build this beauty
badangle is offline
Old 06-07-2017, 10:27 AM
  #3958
GeorgiaFlyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank. george
Here is a link to a build I did on a 96" Bearcat with a Moki 180. check it out starting on post #61 https://www.rcgroups.com/forums/show...-Bearcat/page5
Here is a link to a mod I did to a Balsa USA Stearman adding a Moki 250 but you can get the idea of the motor mount. Check it out starting at post #30 https://www.rcgroups.com/forums/show...Stearman/page2
Hope this helps
GeorgiaFlyer is offline
Old 06-07-2017, 03:44 PM
  #3959
badangle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks georgiaflyer ....the pics were very helpful. ...when I built stearman with 7cyl i shortened nose a bit to comp for extra weight of engine....cg came out ok
badangle is offline
Old 06-13-2017, 05:24 PM
  #3960
GeorgiaFlyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a spring break on the #4 cylinder exhaust valve on a Moki 250. I had about 35 flights on it, its just over a year and half old. Called Gotz where I purchased it. He sent me two new springs no charge. I had to make a air stem to pump air into the cylinder to get the spring retention cap and C clip re-installed. It work great, keep the pressure down to 35 lbs.
ID:	2220029   Click image for larger version
ID:	2220030   Click image for larger version
Old 06-18-2017, 09:39 AM
  #3961
docgboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys. need some help. Brand new Moki 250 Cylinder at 2 o'clock position not firing. reeding 115 degrees and same when I disconnect plug wire and rpm is down. I had about 1 min when it was firing and rpm was 500 higher. Any suggestions?
docgboy is offline
Old 06-19-2017, 07:04 PM
  #3962
Supermod56
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I put the new Rainbowtronic ignition on all 3 of my Moki's, solved all the problems of dead cylinders. Gotz has them for the 250's now.
Tom
Supermod56 is offline
Old 06-20-2017, 12:29 AM
  #3963
docgboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I spoke with Gotz yesterday and he instructed me to lean the low end needle to bring on the cylinder and then the high end. He suggested starting at 1,2 turns on low and 1.6 on the high. He also gave me a lesson on the Comp-arf prop and this engine which is making feel like I waste $600. I will break this engine in with the 32x18 prop I have used on all my other Moki 250s
docgboy is offline
Old 06-21-2017, 01:41 PM
  #3964
Growler84
Growler84's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Regarding the Solo/CARF propeller combination, I offer a two data points to counter the notion that you wasted your money. I personally have over 200 problem free flights worth of experience (Corsair and Jug) using the Moki 250 with either a 3-blade or 4-blade Solo/CARF propeller. My friend Mike, has over 100 on his CARF Jug with the same prop combo. I am confident there are more guys out there with the same experience. The 32 X 18 is a solid approach, but once the engine is dialed in to your satisfaction don't be afraid to use the Solo/CARF propeller setup.
Growler84 is offline
Old 07-19-2017, 12:29 PM
  #3965
midastouch_73
midastouch_73's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It took a lot of sacrifice and patience but it feels great to be a proud owner of a MOKI 300. I'm happy to have found this thread. I'm still a ways away from firing this beauty up but I'm closer to making it happen now that I have the engine in hand..... I've been working on my Bates scale dauntless for a few years now and its getting close to completion. I've already run into an unforeseen issue with the solo prop hub not fitting the 300. I'm pretty heartbroken over that revelation!
ID:	2225029   Click image for larger version
ID:	2225030   Click image for larger version
ID:	2225031   Click image for larger version
midastouch_73 is offline
Old 07-20-2017, 06:05 AM
  #3966
Scott Prossen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
I get my hubs from this guy in Germany for all my 300's, he's been nothing short of fantastic!
https://www.sl-propeller.de/modellba...lemmnaben-hub/
Scott Prossen is offline
Old 07-20-2017, 10:08 AM
  #3967
midastouch_73
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I actually found him as well. I'm waiting the arrival of my new hub and prop from him: ) Hopefully its delivered really soon...
Old 07-24-2017, 12:01 PM
  #3968
bigmikew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys, new to radials and bought a used Moki 150 as my first.
I'm trying to find a couple of answers, as my engine didn't come with manufacturing dates. Is there a serial number catalogue to look up and date my engine? my serial number is 150181. My engine came with CH ignitions, blue box ignitions, top hat and old coils/wires. Also came with pump and turbulator. The seller he bought the turbulator to have on hand, but was told he didn't need it as the engine was post 2009. I sent the serial number to Gotz, but he never got an answer back to me on dates.
Second, what is the arrangement with the stock carb attachment,My engine has an extra white plate with vanes,much like the ones from the turbulator. Since it was disassembled when I got it, I'm trying to see if this plate and vanes goes between the carb and intake, or if it's even needed for stock setup. I'd prefer to stay with stock, so that I don't have to try and make a hatch for adjustment of the carburetor inside the fuselage, as would be the case if I use the turbulator.
I'm installing on a Ziroli corsair and believe it will be a slightly tight fit in the cowl, but should clear. It will be baffled for cooling.
Any other hints, tips or advice would be great. I've only ran the engine a couple of times on a stand, and was running very rich. My #3 wasn't coming up to temp, but again it was rich, and I had the turbulator installed.
Mike
bigmikew is offline
Old 07-24-2017, 12:02 PM
  #3969
bigmikew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
duplicate post....
bigmikew is offline
Old 07-24-2017, 12:22 PM
  #3970
Maxam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike, I have not seen the "little turbulator" (white plate) you mention. Can you supply a picture? It is likely placed between the carb and the engine. -Tom
Maxam is offline
Old 07-24-2017, 12:47 PM
  #3971
bigmikew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tom,
I'll be home in a couple of hours and post a photo. I haven't seen one on any of the forums or Moki website either, but again I'm new to the radial scene. Also, I'm trying to decide between 3 and 4 blade prop for the plane, since I have enough engine to turn either. Just not sure what size/pitch would be best in either blade configuration. Don;t want to spend a ton trying different props.
Mike
bigmikew is offline
Old 07-24-2017, 04:50 PM
  #3972
bigmikew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a pic of the extra parts I have. Upon closer inspection, I believe the vane is an extra for the turbulator and the white part may be an insulator/heat spacer for the carb.
Any ideas?
thanks,
mike
bigmikew is offline
Old 07-25-2017, 03:50 AM
  #3973
Maxam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes the white object is the normal carb spacer/ insulator. The other thingy is new to me. However it is supposed to go, make sure it cannot fall into the engine!!! Do not use it until someone can clearly explain how it is installed. When a walbro carb is at partial throttle settings the gas /air stream is not symmetrical entering the engine thus causing a lopsided unequal distribution to the cylinders. This is a greater issue with the 150. That metal object may serve to disrupt the asymmetric flow of gas/ air.
Maxam is offline
Old 07-25-2017, 06:12 AM
  #3974
bigmikew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the confirmation on the white insulator. I'm gonna try the engine without the turbulator and see what the results are. I'll run it leaner, as prescribed earlier in this thread and see if the #3 cylinder wakes up. Hopefully it will.
I'm pretty sure the vane is an extra for the turbulator, but we'll see if anyone chimes in.
Any suggestions on prop size in 3 and 4 blade Corsair type configuration?
Mike
bigmikew is offline
Old 07-25-2017, 03:36 PM
  #3975
Maxam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike, I am not able to suggest a three or four blade prop. I liked the performance of the two blade 28x14. -Tom
Maxam is offline
Reply
Display Modes
