MOKI RADIAL Care and Maintenence
Reply
Old 11-06-2017, 01:45 PM
  #4026
Lletisso
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Greg, everyday I learn something new for me!
Jordi
Lletisso is offline
Old 11-08-2017, 12:21 PM
  #4027
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check out the new Moki clone...
https://tomahawk-aviation.com/eu/acc...al-engine.html
RichardGee is offline
Old 11-08-2017, 06:04 PM
  #4028
GeorgiaFlyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by richardgee View Post
nice!!
GeorgiaFlyer is offline
Old 11-09-2017, 02:12 PM
  #4029
retro92777@hotmail.com
My Feedback: (32)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my first MOKI on a 40% WACO what are some general guidelines for care and maintenance my others i use 40:1 redline racing oil is this ok to use in a MOKI 400 ?
retro92777@hotmail.com is offline
Old 11-11-2017, 11:05 AM
  #4030
Maxam
My Feedback: (62)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That looks just like the UMS "updated" 260 7 cylinder UMS sent me to evaluate in a 5 cylinder version. Hmmm -Tom
Maxam is offline
Old 11-11-2017, 07:16 PM
  #4031
marksp
My Feedback: (9)
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oil brand (Redline vs Stihl HP) is a matter of personal preference, but general consensus is recommended ratio of 50:1
Other maintenance tips & tricks -
After every flying session (or every hour or so) clean and lightly oil the rockers, push rod ends and valve stem, or if you prefer a good squirt with WD40 will clean and lube them for you. The valve stem under the spring is important as without a regular lube carbon build up on the valve stem could eventually cause the valve to stick resulting in the possible loss of a pushrod.
Lube the exhaust valves by depressing the valve rocker, removing the pushrod then filling the pocket around the top of the exhaust valve with TRI-FLOW and depressing the valve spring to allow the lube to migrate down the valve stem.
Valve clearance with the engine cold is 0.05mm to 0.08mm and the plug gap is 0.3mm to 0.4mm.
Check all external nuts/bolts especially the exhaust collector ring nuts as they take ages to bed in due to the Teflon seal.
marksp is offline
Old 11-12-2017, 09:06 AM
  #4032
Lletisso
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello MarkSp, do I have to lubricate this zone marked in red in the picture..?
Do you see the new "cover spark plugs" now are platstic, not metalic.
Thank you!
Jordi
Lletisso is offline
Old 11-12-2017, 10:41 AM
  #4033
My Feedback: (32)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oil brand (redline vs stihl hp) is a matter of personal preference, but general consensus is recommended ratio of 50:1
other maintenance tips & tricks -
after every flying session (or every hour or so) clean and lightly oil the rockers, push rod ends and valve stem, or if you prefer a good squirt with wd40 will clean and lube them for you. The valve stem under the spring is important as without a regular lube carbon build up on the valve stem could eventually cause the valve to stick resulting in the possible loss of a pushrod.
Lube the exhaust valves by depressing the valve rocker, removing the pushrod then filling the pocket around the top of the exhaust valve with tri-flow and depressing the valve spring to allow the lube to migrate down the valve stem.
Check all external nuts/bolts especially the exhaust collector ring nuts as they take ages to bed in due to the teflon seal.
thank you for your response i dont seem to have anyone close to me in michigan that i can speak with about the moki 400 as it is my first im hoping to find someone that could possibly work with me my 40% waco is ready to go just want to be certain ive taken all precautions with the moki thank you bob 616-291-27eight,five
Old 11-12-2017, 11:31 AM
  #4034
jchorak
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All,
Need a lubing and valve clearance video, does not seem to be any out there.
jc
jchorak is offline
Old 11-15-2017, 04:53 AM
  #4035
DocYates
My Feedback: (102)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a few questions for the Moki experts. I just acquired my first Moki, a 250 which I purchased used to go onto a 1/3 scale BUSA Stearman. The engine came with the blue ignition system, and the Emcotec 380HV fuel pump. The fuel pump, however, has no instruction in the box. I am assuming the "P" port on the top of the pump is the pressure return port to the tank, is this correct? Also I plan to connect the pump to the battery (2100 mAh Life 6.6 which I will use for the ignition) and run this thru an optical cutoff switch. Agin, is this the correct way to do it, and does it just plug into the back of hte pump where it says "IGN", or does it go to "BAT".? Also there is a jumper in the box which is labeled for programming, what type of programming of the pump is needed and how do you do this?
Thanks for the help, this thread is a wealth of information.
Tommy
ID:	2245145   Click image for larger version
DocYates is offline
Old 11-15-2017, 05:20 PM
  #4036
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would think that the Ignition Battery plugs into the battery socket. The Radio socket gets the Rx plug and the Onboard ignition gets the Ignition socket.
BobH is offline
Old 11-15-2017, 11:12 PM
  #4037
Lletisso
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone knows if we have to lubricate the zone shown in the foto, post #4032?
Thank you
Jordi
Lletisso is offline
Old 11-16-2017, 06:57 AM
  #4038
Greg Wright
Greg Wright's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Jordi,
To answer your question i usually spray the entire top of the head with the lubricant that i use. That's the rocker arms, valves, and pushrod ends.
Greg Wright is offline
Old 11-16-2017, 07:58 AM
  #4039
Greg Wright
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DocYates,
Vogelsang has instructions for this new style pump.
You will just be using the two side plugs and you don't want to do anything with the PRG/IGN plug. The REC plug goes to an open channel in your receiver to set up a switch to turn the pump on and off and then the BATT plug gets tied into the ignition in parallel with the ignition battery. I usually solder an extension in to the lead that you will make up for the ignition module. I have always just used a Heavy Duty JR switch as a kill switch for the ignition and i have mounted that as close to the ignition as possible. then i use heavy gauge wire as a battery lead so it doesn't drop to many amps to the ignition. I also run everything on 7.4 VOLTS. I wouldn't use an optical switch to the ignition if possible. Ive seen those fail one too many times.
Old 11-16-2017, 11:31 AM
  #4040
DocYates
My Feedback: (102)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Greg, I found a partial instructions similar to what you are referencing. Says to set the channel to 0% and about 60% as a starting point. Figured since I was doing this I would just use a separate battery and switch, since I can turn the pump on and off from the radio, and then just link it to the ignition switch so when the ignition is engaged, the pump will be on. Does the small jumper plug need to be plugged into the "PROG" port, or does it just remain open?
TOmmy
DocYates is offline
Old 11-16-2017, 02:04 PM
  #4041
Lletisso
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks again Greg!
Jordi
Lletisso is offline
Old 11-17-2017, 06:27 AM
  #4042
Greg Wright
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Doc,
leave the jumper out of the port. Does not need to be plugged in.
Old 11-17-2017, 06:42 AM
  #4043
Greg Wright
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Doc,
Your making life a little harder on yourself with the extra switch and battery. I'm able to get at least 5 to 6 flights a day on a 4000 mah lipo battery with it running both the ignition and the pump at the same time.
My set-up is simple as i have the ignition and pump wired in series to one switch. The switch turns both the ignition and pump on and then i arm the pump with a switch from the radio so that its not running the whole time before i start the motor. When i'm ready to fly i turn on the ignition which also powers up the pump. Then i flip the switch on the radio to turn the pump on and i choke it till it pops. I then un-choke it and flip till its running.
Old 11-17-2017, 09:51 AM
  #4044
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Greg,
In your opinion is the pump helping with starting your engine? Could a similar prime be accomplished using the Choke?
Just wondering here. I have an EVO 160 and Gotz remarked that the pump would be good for that engine as well as others.
BobH is offline
Old 11-17-2017, 12:09 PM
  #4045
DocYates
My Feedback: (102)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Greg. I had already bought two batteries (2100 mAh each, so I might as well use them, but your method sounds much simpler.
Thanks for the help.
Tommy
DocYates is offline
Old 11-23-2017, 09:20 AM
  #4046
LRFitch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Moki cylinder cutout?
Guys, I have a Moki 215 that I am installing in a 41% Pitts Model 12 airplane. Does anyone know of a source for a template that I can use to cut a air cooling disc to force the cooling air through the cylinder fins? I am likely not using the correct terminology, and hope this makes sense.
Happy Thanksgiving,
Larry Fitch
LRFitch is offline
Old 11-23-2017, 10:09 AM
  #4047
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Larry,
I don't know of a template but you can make your own. Take the frontal drawing of the 215 and resize it to match the real engine size. Then place that drawing on some ply and cut out the area for the cylinders. The rest can go inside your cowl. You'll need to size that too. It should make a good air-dam for your cylinders. Keep the ply walls close to the cylinder walls to force air through the cylinder fins.
BobH is offline
Old 11-23-2017, 11:19 AM
  #4048
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Happy Thanksgiving,
Larry Fitch
Vogelsang sells the pre made baffles. Look under Moki Accessories.
http://www.vogelsang-aeroscale.com/
Old 11-23-2017, 12:18 PM
  #4049
Jaketab
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Happy Thanksgiving,
Larry Fitch
Made an inner cowl ring for my Turner W4X and then attached 5 individual cut out baffles to the ring.
ID:	2246081   Click image for larger version
Jaketab is offline
Old 11-24-2017, 03:17 PM
  #4050
IFLYBVM2
My Feedback: (359)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Baffle
+1 on buying the one from Vogelsang-It fits like a glove and is nicely done. A little pricey, but it will save you HOURS of cutting and sanding, and the finished product looks very nice. I have seen some home made baffles that were very poorly done, and actually drew your eye to them. The object is for it to as un noticeable as possible. Just my opinion-
Mike O.
IFLYBVM2 is offline
Contact Us Archive Advertising Cookie Policy
