MOKI RADIAL Care and Maintenence
Reply
Old 11-24-2017, 03:24 PM
  #4051
LRFitch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Thanks
Guys, thanks for the info and link. I think Vogelsang is likely my best option.
Larry Fitch
LRFitch is offline
Old 12-09-2017, 08:40 AM
  #4052
x0xorena
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Guys,
I'm new here and would be glad to have your Moki's technical expertise.
I have Moki 215 (install on AMR WACO 33%) that was runs several years without any issue. However few weeks ago when I tried to start the engine I've noticed there's no ignition sparks. I pull off all the plugs out and roll the prop while the ignition is on - but without any sign of sparks.
I also dissemble the central 5 coils with pickup sensor too from the engine body and plugged it direct to the it's original ignition (works with 4.8v Ni-cd battery).
I touched with an external Magnet to the pickup sensor by trying to simulate the signal from each Cylinder hopefully to understand if the problem sticks on the ignition unit or the coils.
Well , after 30-40 sec of playing with external magnet (by touch on the pickup sensor ) I noticed sparks from the plugs each by it's sequencer - I was happy! .Next I plugged the battery out and plugged it again , then again play with the pickup & the magnet - but now without sparks.I did this test many times. sometime there was sparks and sometimes not. So by now I did not reach to any conclusions where is problem came from.The ignition power led is on and so the pickup led is OK.
Appreciate for any advice.
Oren
x0xorena is offline
Old 12-29-2017, 09:54 AM
  #4053
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gents, the answers to my questions are probably somewhere within these 163 pages, so I apologize in advance if these questions have already been answered:
Difference in weight between the 215 and 250? I find conflicting info online.
Much difference in power or will they both spin the same props, just with slightly different top rpms?
Is the new Blue Box Moki ignition an improvement over the old black cylindrical version?
Is it possible to run these reliably on the integral fuel pump, providing the pump line is cleaned every few flights?
Thank you!
RichardGee is online now
Old 12-29-2017, 02:30 PM
  #4054
Remaking
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have had 3 of each so will take a stab:
Not sure of the exact weight but they are close.
The 250 is noticably louder, makes more power but yes they spin the same props.
The blue ignition box is WAY better than the black Top Hat. I've had 3 of 4 black ignitions fail on me. When replacing with the blue its a whole new engine, and you can run any battery.
I run an electric pump on all my Moki's. Turn on the pump and 3-4 flips and it starts. Trying to pull prime with the Piston pump and choke takes forever. Sometimes 20-30 flips. Plus the engine runs more evenly without having to change mixtures with temps.
Remaking is offline
Old 12-29-2017, 02:39 PM
  #4055
msouers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Greg,
Where did you get your bombs and how did you attach them?
Mark
msouers is offline
Old 12-29-2017, 03:40 PM
  #4056
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
GREAT Info. THANKS MUCH
Old 12-30-2017, 05:47 PM
  #4057
IFLYBVM2
My Feedback: (359)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default moki
Thank you!
Hi Richard-
I also have several Mokis-both 250 and 215. Power wise, I have a strong running 215 that turns within a couple hundred of the 250. It depends on the engine if course, but doesn't seem to be that much difference between them.
Weight wise, the 215 should be slightly heavier, as the 250 is a bored out version of the 250 with identical external dimensions, so far as I can tell.
Over the years I have surveyed at least 50 modelers about whether or not they use an external pump: I have found almost an exact 50/50 split. Some guys, including some high time Top Gun caliber pilots I surveyed, have never used them and their Mokis run flawlessly. Important to have the tank position at least even or slightly above the carb if you don't run the pump though. I personally subscribe to this line of thought-if you consider the addition of the pump itself, it's battery and switch, you are eliminating 2 or 3 possible choke points in your setup. Keep it simple...
On the other hand, the other half of guys would not think of running without a pump. At the end if the day, I guess there are no wrong or right answers here-just what you feel comfortable with. I did speak to at least 3 guys who had pump failures-luckily all 3 on the ground.
Just my opinion-your actual mileage msy vary, as they say.
​​​​​​​ Regards-Mike O.
IFLYBVM2 is offline
Old 12-30-2017, 09:04 PM
  #4058
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike O.
Thanks for your response. I too ran a Moki 250 in a CARF P-47 w/o a pump. I was very vigilant to keep the clear pump tube clean of grease and never had a fuel delivery problem as far as I could tell.
I never measured cylinder temperatures, but the engine always started easily and ran well with plenty of power.
Old 01-01-2018, 06:45 AM
  #4059
Greg Wright
Greg Wright's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by msouers View Post
Hi Greg,
Mark
Hi Mark.
I got my Bombs from Ziroli and used the BVM bomb releases to hold them in place.
If i ever decide to make them droppable i will just have to run some airlines to the releases and add a small airtank and valve to make them work.
Greg Wright is offline
Old 01-15-2018, 11:23 AM
  #4060
Papasal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good morning all, Papa Sal here from Reno, NV. Thank you all for this excellent fourm! My question is : do you think a Moki 180 will have enough power to fly a33%Yak 55M @ 28 lbs. Or would the 250 be better? Thank you all for your inputs.
Papa Sal
Papasal is offline
Old 01-15-2018, 11:33 AM
  #4061
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Papa Sal
Absolutely! A 250 would be serious overkill in power and weight. A 33% IMAC plane is a 100cc aerobatic aircraft. A Moki 150, 180 or Evolution 160 are the approximate equivalents of a 100cc two stroke as far as HP. A 250 radial weighs twice what a 100cc twin weighs and spins twice the propeller. Much more appropriate for a 40% aerobat.
Old 01-15-2018, 11:45 AM
  #4062
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A lot depends on the plane's weight. If it's light enough the 180 could work. The 215 would be better with more margin of error and the 250 should leave no doubt about performance.
BobH is offline
Old 01-15-2018, 01:18 PM
  #4063
GeorgiaFlyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with RichardGee, the 180 would be plenty for that size plane. search youtube there are some videos out there of others using the 150 and 180 on that size Yak.
Cheers!
heres a link to one
GeorgiaFlyer is offline
Old 01-15-2018, 01:26 PM
  #4064
Papasal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
AWESOME! Thanks Gents. Just as I thought. Thanks for all the input. My dream just may come true. BTW GeorgiaFlyer GREAT VIDEO! It warmed my heart to see that yak pull out of a hover with power to spare!
Papasal is offline
Old 01-26-2018, 09:12 AM
  #4065
Big1Birdy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Help Please
Hi All
I have a Moki S180 which I bought about 2 years ago, after initial test runs I put the engine away for the winter. When I got it out again the following year I could not get it to run properly. As I live in the UK I sent it back to Airworld in Germany, it was returned to me and they said that they had changed the carburettor! However I still can not get it to run properly.
The engine will start and it picks up speed for a few seconds and then dies back to a poor idle and then stops. What ever I do I cannot get it to run. I am using Stilh premix 50:1 fuel and the engine is a new with no modifications. I have read this forum right from start to finish but nothing I have read so far has helped me. I would really welcome some advice or suggestions from "seasoned" Moki owners.
Many thanks John
Big1Birdy is offline
Old 01-26-2018, 09:58 AM
  #4066
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Big1Birdy View Post
Hi All
Many thanks John
The problem DOES sound like it is related to fuel delivery. I assume you are NOT using an auxiliary fuel pump? With a new carburetor, the pump diaphragm is no longer the most likely suspect... I would suspect the air pump located at the front of the engine, driven off the cam. I am assuming the pump is frozen and not providing the pressure pulses required to activate the carburetor diaphragm. IF you ARE using an electric fuel pump, then my theory is ALL WET
If you add an electric pump and the engine again runs perfect, the problem is the air pump unit.
Old 01-26-2018, 02:06 PM
  #4067
Big1Birdy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Richard, thanks for you reply. I too believe that it could be a fuel delivery problem, I have tried testing the pump by getting it to suck water up and down a long piece of tubing, which it does. I have also tried placing the tank up to 5 feet above the engine, without success. Other than buying an expensive pump I don't know how to test it further.
Old 01-26-2018, 02:19 PM
  #4068
Walter_Mitty
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John ,
where are you ??
I'm 9 miles west of Cambridge , Pm me your numbers , and we can chat
Cheers
Phil
Walter_Mitty is offline
Old 01-27-2018, 12:30 AM
  #4069
snauwaertj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Moki 100 bvt
Hello,
I just bought a used moki 100 flat twin, there don't seem to be many out there and there is very little to find about these flat twins.
Anyone here got some experience with these?
I would like to use it on a 2m40 FW190 A8. Biela makes a nice 24x10 3 blade scale prop and I was wondering if this would be a good choice for this engine.
Is an electric feulpump usefull on this engine?
Kind regards
Johan
snauwaertj is offline
Old 01-27-2018, 12:59 AM
  #4070
Detlef Kunkel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John,
a simple quick test could bring some answers. Blow with all power that your lung has into the vent tube of your tank and close it. A human being can achive something like 0,2 bar of pressure with this.
When your enginge runs great (maybe some high needle adjustment due to the new pressure) with a fuel pressure of 0,2 bar, your pump system has a failure. then we can go on.
Dont unbolt all the engine before you get closer to the problem. Report when you did it.
Detlef Kunkel is offline
Old 01-27-2018, 01:56 AM
  #4071
Big1Birdy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Detlef,
Thank you for your suggestion, it has given me an idea whether I could connect my compressor to my tank vent and set it at about 4psi or 0.3bar to test the the pump. I was hoping that lifting the tank would have the same effect, I will give it a try.
Many thanks for your help.
John
Old 01-28-2018, 09:16 AM
  #4072
Big1Birdy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Detlef
I got the engine running today by pressurising my tank to 5psi using my compressor.
I also have spoken to Phil Elner who has been very helpful and has offered to send me an electric fuel pump for me to try. So hopefully this will sort the problem, but I still don't understand why the engine's own fuel pump does not function correctly as it should.
Kind regards and thank you for your help.
John
Old 01-31-2018, 02:16 PM
  #4073
Lletisso
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by snauwaertj View Post
Hello,
Kind regards
Johan
Hello, I have a Moki 100bvt for four years and is a wonderfull engine! I run it with a 26 10 fiala propeller anb it takes 5400rpm. Also a fiala 3 blade 24 10.
I never instal it a fuell pump, and in four years never had an insue. I have mesured 15,5 kg of static trust. I run it with a 2 in 1 exaust sistem.
Here is mine:
Lletisso is offline
Old 01-31-2018, 07:08 PM
  #4074
GeorgiaFlyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wow that really sound good!
Old 02-03-2018, 12:28 PM
  #4075
snauwaertj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds great indeed!
Do you dive that Corsair full throttle with the 26x10 2blade?
I was considering to put a CFK falcon 26x11 on mine, they are very light and people told me they spin a few 100 RPM more than other brands that are the same size.
